Текущее время: Сб, апр 27 2024, 05:45
 Заголовок сообщения: structure SCREEN_DEP
СообщениеДобавлено: Чт, ноя 21 2013, 14:00
Пн, дек 07 2009, 16:36
Уважаемые гуру, подскажите пожалуйста, как создать признак со ссылкой на структуру SCREEN_DEP? Во всех хелпах написано одно и тоже:
1. Create a characteristic with a reference to structure SCREEN_DEP.
Enter a field in the structure.
2. Create an action or procedure that refers to the reference characteristic.
Instead of a value, you assign a characteristic for the display option to the reference characteristic.
3. You allocate the action or procedure to the configuration profile of the configurable material or the characteristic.
Example Process Flow
a) You create reference characteristic INVISIBLE with a reference to structure SCREEN_DEP, field INVISIBLE.
b) You create an action with the following source code:
$SELF.NO_DISPLAY = ‘SADDLE’ IF MODEL = ‘STANDARD’
In the action, you assign characteristic SADDLE to the characteristic. The condition is that characteristic MODEL must have the value ‘Standard’.
c) Allocate the action to either characteristic SADDLE or the configuration profile of the material.
d) If characteristic MODEL has another value, you do not see characteristic SADDLE.
Как выполнить первые три пункта?
Задача: при значении признака SIZE2=2000 признак SIZE1 не выводить.
