Специалист |
Добрый день! Есть признак "Код ценной бумаги". Добавил в него новый атрибут и доработал правила переноса. Но теперь при просмотре данных этого признака валится в дамп. Хотя загрузка прошла нормально данных. ДинамОшибка UC_OBJECTS_NOT_CHARLIKE Дата и время 13.11.2014 11:36:01
Краткий текст The current statement is only defined for character-type data objects.
Что произошло? Error in the ABAP Application Program The current ABAP program "SAPLSLVC" had to be terminated because it has come across a statement that unfortunately cannot be executed.
Анализ ошибки For the statement "CONVERSION_EXIT_ALPHA_OUTPUT" only character-type data objects are supported at the argument position "INPUT".
In this case. the operand "INPUT" has the non-character-type "?". The current program is a Unicode program. In the Unicode context, the type 'X' or structures containing not only character-type components are regarded as non-character-type.
3259 if not <ls_fcat>-indx_field is initial. 3260 assign component <ls_fcat>-indx_field 3261 of structure <ls_data> to <l_f 3262 else. 3263 assign component <ls_fcat>-fieldname 3264 of structure <ls_data> to <l_f 3265 endif. 3266 >>>>> macro_cell_data_get 3268 <ls_fcat> 3269 <ls_data> 3270 <l_field_value> 3271 ls_lvc_data-value. 3272 3273 *>>> new API 3274 if ir_salv_adapter is bound. 3275 clear ls_lvc_data-style. 3276 3277 * color 3278 if g_gui_type ne 1. 3279 if <ls_fcat>-key eq abap_true. 3280 ls_lvc_data-style = alv_style_color_int_key 3281 elseif l_style_color is initial
