Текущее время: Вс, июл 22 2018, 03:00
Часовой пояс: UTC + 4 часа
 Заголовок сообщения: Старый сап, нет right oute,как оптимизировать?
СообщениеДобавлено: Пт, апр 27 2018, 10:27
Пн, июл 17 2017, 15:11
Старый сап
есть только left outer и inner
мне надо как-то оптимиизровать этот код:
SELECT-OPTIONS: so_matnr FOR zppmrp5-matnr, "Изделие
                so_mat1 FOR zppmrp5-matnr_1, "ДСЕ
                so_mat2 FOR zppmrp5-matnr_2, "Узел
                so_arb1 FOR zppmrp5-arbpl_1, "Цех изготовитель
                so_arb2 FOR zppmrp5-arbpl_2. "Цех потребитель
SELECT zppmrp5~matnr_1 zppmrp5~DATUV zppmrp5~matnr_2 zppmrp5~matnr zppmrp5~gamng zppmrp5~gamng_1 zppmrp5~WERKS zppmrp5~arbpl_1 zppmrp5~arbpl_2 zppmrp5~datuv zppmrp5~seqnr zppmrp5~elevel zppmrp5~pbdnr
       zppmrp5_tmp1~matnr_1 zppmrp5_tmp1~DATUV zppmrp5_tmp1~matnr_2 zppmrp5_tmp1~WERKS zppmrp5_tmp1~gamng as gamng_L  zppmrp5_tmp1~gamng_1 as gamng_1_L zppmrp5_tmp1~matnr zppmrp5_tmp1~arbpl_1 zppmrp5_tmp1~arbpl_2 zppmrp5_tmp1~datuv zppmrp5_tmp1~seqnr
zppmrp5_tmp1~elevel zppmrp5_tmp1~pbdnr
  INTO CORRESPONDING FIELDS OF TABLE gt_result_tab
  FROM zppmrp5
  LEFT OUTER
    JOIN zppmrp5_tmp1 on zppmrp5_tmp1~matnr = zppmrp5~matnr
        AND zppmrp5_tmp1~matnr_1 = zppmrp5~matnr_1
        AND zppmrp5_tmp1~matnr_2 = zppmrp5~matnr_2
        AND zppmrp5_tmp1~arbpl_1 = zppmrp5~arbpl_1
        AND zppmrp5_tmp1~arbpl_2 = zppmrp5~arbpl_2
  WHERE zppmrp5~elevel = 1.
SELECT zppmrp5~matnr_1 zppmrp5~matnr_2 zppmrp5~matnr zppmrp5~WERKS zppmrp5~arbpl_1 zppmrp5~gamng zppmrp5~gamng_1 zppmrp5~arbpl_2 zppmrp5~datuv zppmrp5~seqnr zppmrp5~elevel zppmrp5~pbdnr
       zppmrp5_tmp1~matnr_1 zppmrp5_tmp1~matnr_2 zppmrp5_tmp1~WERKS zppmrp5_tmp1~gamng as gamng_L  zppmrp5_tmp1~gamng_1 as gamng_1_L zppmrp5_tmp1~matnr zppmrp5_tmp1~arbpl_1 zppmrp5_tmp1~arbpl_2 zppmrp5_tmp1~datuv zppmrp5_tmp1~seqnr zppmrp5_tmp1~elevel
zppmrp5_tmp1~pbdnr
  FROM zppmrp5_tmp1
  LEFT OUTER
    JOIN zppmrp5 on zppmrp5~matnr = zppmrp5_tmp1~matnr
        AND zppmrp5~matnr_1 = zppmrp5_tmp1~matnr_1
        AND zppmrp5~matnr_2 = zppmrp5_tmp1~matnr_2
        AND zppmrp5~arbpl_1 = zppmrp5_tmp1~arbpl_1
        AND zppmrp5~arbpl_2 = zppmrp5_tmp1~arbpl_2
  WHERE zppmrp5_tmp1~elevel = 1.
это тупо как то выглядит дальше
я не понимаю как мне сделать рабочими селекты?
два раза описать в WHERE?
подскажите пожалуйста
 Заголовок сообщения: Re: Старый сап, нет right oute,как оптимизировать?
СообщениеДобавлено: Пт, апр 27 2018, 10:50
версия наша ABAP - 7.00
СообщениеДобавлено: Ср, май 02 2018, 11:50
еще и проблема появилась, после удаления дублей, показывает пустую строку :( и несколько цифр в норм. потребности...
но ни названия, ни каких других данных нет.
СообщениеДобавлено: Чт, май 03 2018, 17:24
Чт, мар 29 2007, 12:51
декомпозицией лефт-запроса на два отдельных массива данных (потребуется доп.внутренняя таблица) и программная проверка попадания записей одной вн.таблицы в другую (можно по предварительно-отсортированному одинаковому ключу, поиск совпадений будет быстрее - пример есть в Примерах абапкода).
СообщениеДобавлено: Чт, май 10 2018, 11:40
Чт, дек 20 2007, 19:21
right outer и не нужен. достаточно таблицы поменять местами в запросе и будет такой же эффект.
я твой сап эфай внедрял
BAdI-позитив
СообщениеДобавлено: Пн, май 14 2018, 14:00
pberezin написал:
а конкретнее как программа demo называется, не подскажете?
СообщениеДобавлено: Ср, май 16 2018, 12:47
Пн, апр 15 2013, 15:49
Уточните пожалуйста какой результат нужно получить.
Разве при такой последовательности запросов результат оказавшийся в таблице gt_result_tab после того как отработает первый SELECT
не будет затерт результатом второго?
Если результаты должны быть объединены:
То во втором SELECT вместо INTO должно быть APPENDING.
Если записей в результатах ожидается относительно немного меньше (сотен тысяч записей), я бы "не парился"
После второго запроса отсортировал бы результат по условно ключевым полям и DELETE ADJACENT DUPLICATES FROM gt_result_tab.
( Помнится в стародавние времена в FoxPro была в SELECT-ах директива FULL JOIN для таких целей :)) )
