SAPфорум.RU
https://sapboard.ru/forum/
Режимы оценки для методов выборочного контроля (англ.)
https://sapboard.ru/forum/viewtopic.php?f=7&t=76284
Страница 1 из 1
Автор:  Admin [ Пн, апр 23 2012, 17:39 ]
Заголовок сообщения:  Режимы оценки для методов выборочного контроля (англ.)
От коллег с sapfans.com - разъяснение по режимам оценки, используемых в методах выборочного контроля (англ.)
Attributive inspection nonconf. units Used in Valuation mode 100 (Attributive inspection nonconf. units), 110 (Attributive inspection nonconf. units/manual)
If you set this indicator, you define the valuation mode using the attributive valuation based on the nonconforming units.
For a sampling procedure with this valuation mode, valuation occurs using a sampling plan consisting of sample size and acceptance number. The acceptance number and the number of nonconforming units are compared.
Attributive Inspection by Number of Defects Used in Valuation mode 200 (Attributive inspection number of defects), 210 (Attributive inspection number of defects/manual)
If you set this indicator, you define the valuation mode using the attributive valuation based on the number of defects.
For a sampling procedure with this valuation mode, valuation occurs using a sampling plan consisting of sample size and acceptance number. The acceptance number and the number of defects are compared.
Variable Inspection by S-Method Used in Valuation mode 300 (one Limit), 310 (two limits)
If you set this indicator, you define the valuation mode for the variable inspection according to the s-method (ISO 3951).
For a sampling procedure with this valuation mode, valuation occurs using a sampling plan consisting of sample size and k-factor. A quality score is calculated from the measured values of a sample and compared with the k-factor.
Valuation by Code Used in Valuation mode 400
If you set this indicator, you define the valuation mode using a valuation according to a code.
For a sampling procedure with this valuation mode, valuation occurs using a code that is assigned a valuation (selected set).
Manual Valuation Used in Valuation mode 500
If you set this indicator, you define the valuation mode using a manual valuation.
For a sampling procedure with this valuation mode, valuation occurs manually.
During results recording you set an inspection characteristic or a sample manually to "Accept" or "Reject".
Without Valuation Parameters Used in Valuation mode 510
You set the indicator in:
The sampling scheme that is used in the following:
- Sample-drawing procedure
- Sampling procedure that you define for sample determination without a task list
Customizing for the valuation mode
You select the valuation mode "without valuation parameters" in a sampling procedure that you define for sample determination without a task list.
Inspection by Tolerance Used in Valuation mode 700
Inspection Against Specification Limits (k = 0)
Quality control chart: Action Limits Used in Valuation mode 800
Acceptance Using Control Chart
Страница 1 из 1 Часовой пояс: UTC + 3 часа
http://www.phpbb.com/
