Текущее время: Пт, июн 07 2024, 18:23
 Заголовок сообщения: Сообщение остановилось в статусе HOLDING
СообщениеДобавлено: Пт, ноя 29 2013, 12:45
Чт, ноя 22 2012, 10:25
Добрый день, коллеги!
Вот появилась проблема, нужна подсказка, как искать причины. Есть сообщение, передаваемое из САП (IDOC) во внешнюю систему (SOAP). в RWB видно, что оно в статусе HOLDING. Вот что в АудитЛоге после нескольких попыток ресенда:
28.11.2013 18:59:11.232 Information Using connection SOAP_http://sap.com/xi/XI/System. Trying to put the message into the receive queue.
28.11.2013 18:59:11.232 Information Processing child message of multi-message with message Id 90238d52-b4a6-273e-e100-0000c0a80083.
28.11.2013 18:59:11.249 Information Message successfully put into the queue.
28.11.2013 18:59:11.254 Information The message was successfully retrieved from the receive queue.
28.11.2013 18:59:11.257 Information The message status was set to HOLD.
29.11.2013 10:48:13.505 Information Trying to retry the message because of administrative action of user "USER.N".
29.11.2013 10:48:13.512 Information Admin action: Trying to redeliver message.
29.11.2013 10:48:13.534 Information The message status was set to TBDL.
29.11.2013 10:48:13.543 Information The message was successfully retrieved from the receive queue.
29.11.2013 10:48:13.545 Information The message status was set to HOLD.
29.11.2013 10:53:39.109 Information Trying to retry the message because of administrative action of user "USER.N".
29.11.2013 10:53:39.110 Information Admin action: Trying to redeliver message.
29.11.2013 10:53:39.112 Information The message status was set to TBDL.
29.11.2013 10:53:39.118 Information The message was successfully retrieved from the receive queue.
29.11.2013 10:53:39.121 Information The message status was set to HOLD.
29.11.2013 10:54:18.314 Information Admin action: Trying to redeliver message.
29.11.2013 10:54:18.314 Information Trying to retry the message because of administrative action of user "USER.N".
29.11.2013 10:54:18.318 Information The message status was set to TBDL.
29.11.2013 10:54:18.319 Information The message was successfully retrieved from the receive queue.
29.11.2013 10:54:18.321 Information The message status was set to HOLD.
Где найти причину, почему так получилось? причем, если принимающий сервис выключен, система реагирует сообщением, что READ TIMEOUT. Если при приеме ошибка, то она появляется и в логе. Что же тут случилось?
 Заголовок сообщения: Re: Сообщение остановилось в статусе HOLDING  Тема решена
СообщениеДобавлено: Пт, ноя 29 2013, 14:53
Сб, фев 25 2012, 02:52
Ощущение, что в очереди адаптера что-то стоит c ошибкой - поэтому все последующие сообщения встают в статус HOLD.
Вот тут посмотрите:
http://scn.sap.com/people/stefan.grube/ ... -framework
Сажаем самолеты по телефону. :)
SAP - фрилансер.
sap.pitroff.ru
СообщениеДобавлено: Пт, ноя 29 2013, 15:40
Да, именно так и получилось. Просто я недостаточно далеко искал ;-)
