Можно. Общая логистика – Основные записи материалов – Параметры для торговли – Параметры настройки для просмотра данных экрана – Обработать параметры данных экрана В разделе Серия экранов указываете путь на сервере, где будут храниться картинки к товару, расширение (JPG), максимальное количество и разделитель в имени файла. Если, например, разделитель "-", то по указанному пути нужно положить файлы с именами КодТовара-1.JPG КодТовара-2.JPG. Почитать об этом можно в соответствующей справке SPRO:
Series images Server path: Enter the path to the image data server in the following format: file://\\dir1\dir2\dir3\dir\_ File type: JPG - Image data format BMP - Image data format GIF - Image data format Max. images: Defines the maximum number of series images that will be displayed in the generic structure of the URLs. When constructing the URLs for series images, the system forms the corresponding file names using an index, which starts with 00 and counts consecutively, to find the corresponding image file in the server path. The system terminates the search or increment of the index when this maximum value is reached - that is, the last image file has an index of (maximum value) - 1. If the system does not find any image files for the determined index, it resumes the search with the next index. In this case, the maximum number of displayable images is reduced by the number of image files that were not found, which means the system does not continue the search for image files until the specified maximum value is reached. If you choose the Read from Table option for URL determination, this parameter has no effect. Instead, the system reads all the URLs saved for an object (such as a material) and displays the images. The setting is only used for generic determination of the URL, to keep the number of searches to a sensible number for performance reasons. Separator: Separator for series images (for example: #,%,&,#)
