Текущее время: Чт, май 02 2024, 02:40
 Заголовок сообщения: BACKUP HANA
СообщениеДобавлено: Вт, июл 19 2016, 14:28
Вс, фев 08 2015, 23:20
HANA версия 1.00.73 к ней прикручена BW.
При запуске бекапа через HANA Studio пишет:
Could not back up system <SID>
backup could not be completed, RootKeyStoreReader::read(): Record "HDB_SERVER/DPAPI" was inserted with an encryption key
that was different from the current one; when you still know the old one, you can try the "migrate" operation of the "rsecssfx" utility
Через hdbsql:
hdbsql <SID>=> BACKUP DATA USING FILE ('SCHEDULED_19072016')
* 2: general error: Backup error: RootKeyStoreReader::read(): Record "HDB_SERVER/DPAPI" was inserted with an encryption key that was different from the current one; when you still know the old one, you can try the "migrate" operation of the "rsecssfx" utility SQLSTATE: HY000
hdbsql <SID>=>
Что посоветуйте делать?
 Заголовок сообщения: Re: BACKUP HANA
СообщениеДобавлено: Пн, янв 07 2019, 12:25
Ср, апр 07 2010, 19:15
SAP Note 2215993 - During Take Over the Following Error Occurs 'Record "HDB_SERVER/DPAPI"
