Текущее время: Пн, сен 14 2026, 05:35
 Заголовок сообщения: DMS соединение объектов
СообщениеДобавлено: Чт, мар 29 2007, 06:37
Чт, авг 26 2004, 05:04
Разбираюсь с присврением документу DMS объекта, в хелпе указано следущее:
    Adding Other Objects
    Purpose
    You can also link documents with SAP objects for which no linking is supported in the standard
    SAP System.
    Prerequisites
    In Customizing for the Document Management, you must maintain the key fields for the SAP
    objects that you want to link to document info records, by choosing Control Data  Maintain key
    fields.
    Process
    1. Program two screens for the following module pools for the SAP object that is to be
    linked additionally:
    – SAPLCV00
    – SAPLCVIN
    The process logic must be according to that of screen 0204 in program SAPLCV00 and
    must not be changed.
    2. Create the function module OBJECT_CHECK_XXXX (XXXX = name of the SAP object).
    If this object can be classified, this function module already exists in the standard
    system. Otherwise, copy the existing function module OBJECT_CHECK_EQUI (linking of
    equipment) and change it to suit the new object.
    Result
    After you have completed the above, documents can be linked with the SAP object that you have
    added. You define the settings for this in Customizing for the Document Management System
    (see: Object Links [Seite 62]).
Создал функцию, скопировал экран, и ничего....
Видимо должна быть настройка данных объектов.
При настройке вида документа в DMS, объекта нет.
Все будет хорошо...
http://sap-blog.ru/
СообщениеДобавлено: Вт, апр 17 2007, 15:36
Чт, дек 02 2004, 15:20
up!
В справке по настройке что-то похожее:
Object links to other SAP objects
You can make an object link to SAP objects that are not shown in the possible entries list. To do this, proceed as follows:
1. In the standard system, there are already two special screens for the module pools SAPLCV130 and SAPLCV140 for the linked SAP object. You must create two new screens with the same number for the module pools SAPLCV130 and SAPLCV140. The processing logic must follow that of screen 1204 in program SAPLVC130.
2. Create function module OBJECT_CHECK_XXXX (XXXX = object name)
- If the object can be classified, this function module already
exists.
- Otherwise copy the function module for linking equipment DOCUMENT_CHECK_EQUI and change it as required for the new object.
Сам не абапер, если не прав, поправьте меня. OBJECT_CHECK нужен для проверки объекта при присвоениии ч/з экран в cv130?
Экран в cv130 добавлять только ч/з ломание (использование SAP-ключа) объекта или есть другие способы?
СообщениеДобавлено: Вт, апр 17 2007, 22:14
Чт, окт 06 2005, 16:44
z13 написал:
Только через модификацию стандарта (создание экранов 9xxx).
Там даже нота есть по-моему. Завтра точнее скажу.
artyom написал:
Настройка в SPRO должна быть.
Удав.
СообщениеДобавлено: Ср, апр 18 2007, 05:13
Нашел я как это делается, просто забыл описать тут.
А все делается именно как описал z13, плюс некоторые настройки в spro :)
Удачи всем!!!
Все будет хорошо...
http://sap-blog.ru/
СообщениеДобавлено: Ср, апр 18 2007, 10:25
Итого:
Настройки (Компоненты\СУД\Управляющие данные\):
-Определение видов документов
-Ведение экрана соединения объекта
Сначала в первой настройке делаем текст для нового объекта, потом во второй добавляем объект.
После этого система разрешает сделать OBJECT_CHECK_XXXX.
Потом делаем экран 9xxx в cv130. Тут жива ещё надежда - может есть какой-нибудь хитрый ход, который разрешает или генерит экраны без получения ключа на cv130?
В настройке определения видов документов для вида документа добавляем сделанное соединение объекта.
Вроде так.
СообщениеДобавлено: Ср, апр 18 2007, 17:12
z13 написал:
Нет.
Мало того, необходимо еще создать экраны в группе функций CV100 для корректной работы транзакции CV04N по аналогии с нотой 850135
Удав.
