SAPфорум.RU https://sapboard.ru/forum/ |
Как снять операцию в MDM? https://sapboard.ru/forum/viewtopic.php?f=80&t=83481 |
Страница 1 из 1 |
Автор: | alex61 [ Чт, авг 01 2013, 10:42 ] |
Заголовок сообщения: | Как снять операцию в MDM? |
clix mdsMonitor localhost Admin: -W -C -T 5 -# 59950 Выдает например лог Server Time, Thread Id, State, User, Protocol, Command, Locks, Wait Time ms, Run Time ms, Start Time, Connection, Repository, Remote Host 2013.06.19 08:50:04 GMT, 19790, R, INMakiyova, Web, GetSearchResultSet2, - S - - , 93, 3307, 08:50:01 GMT, MDM WD Framework, EOS_NSI, rppdb01 2013.06.19 08:50:04 GMT, 31355, W, Core-as-SAPS, Web, AddRecord, - X* - - , 3285, 0, 08:50:01 GMT, MDM Java API, EOS_NSI, rppap02 2013.06.19 08:50:04 GMT, 11823, W, Core-as-SAPS, Web, AddRecord, - X* - - , 3284, 0, 08:50:01 GMT, MDM Java API, EOS_NSI, rppap01 2013.06.19 08:50:04 GMT, 22617, W, Core-as-SAPS, Web, AddRecord, - X* - - , 3284, 0, 08:50:01 GMT, MDM Java API, EOS_NSI, rppap01 2013.06.19 08:50:04 GMT, 29042, W, SVPorodina, Web, GetSearchResultSet2, - S* - - , 3284, 0, 08:50:01 GMT, MDM WD Framework, EOS_NSI, rppap03 2013.06.19 08:50:04 GMT, 25444, W, SVDelman, Web, GetMatchingRecords2, - S* - - , 3264, 0, 08:50:01 GMT, MDM Java API, EOS_NSI, rppdb01 2013.06.19 08:50:04 GMT, 12594, W, Core-as-SAPS, Web, GetSearchResultSet2, - S* - - , 3084, 0, 08:50:01 GMT, MDM Java API, EOS_NSI, rppap02 2013.06.19 08:50:04 GMT, 33411, W, OLStarostina, MDSAdmin, GetUserRoles, S S* - - , 3067, 0, 08:50:01 GMT, MDM WD Framework, EOS_NSI, rppap03 2013.06.19 08:50:04 GMT, 22103, W, YVSorokina, Web, GetRecordsById, - S* - - , 2119, 0, 08:50:02 GMT, MDM WD Framework, EOS_NSI, rppap02 2013.06.19 08:50:04 GMT, 7968, W, Core-as-SAPS, Web, GetRecordsById, - S* - - , 1564, 0, 08:50:03 GMT, MDM Java API, EOS_NSI, rppap01 2013.06.19 08:50:04 GMT, 15935, R, , Itsam, GetActivityInfo, - - - - , 0, 0, 08:50:04 GMT, , , 127.0.0.1. Первая операция 2013.06.19 08:50:04 GMT, 19790, R, INMakiyova, Web, GetSearchResultSet2, - S - - , 93, 3307, 08:50:01 GMT, MDM WD Framework, EOS_NSI, rppdb01 блокирует последующие с состоянием W Подскажите, пожалуйста, как снять первую операцию, которая блокирует остальные? |
Автор: | strateg [ Сб, авг 24 2013, 05:34 ] |
Заголовок сообщения: | Re: Как снять операцию в MDM? |
Перегрузить репозиторий. Судя по всему это операция поиска через web-service |
Страница 1 из 1 | Часовой пояс: UTC + 3 часа |
