Текущее время: Чт, авг 27 2026, 06:22
 Заголовок сообщения: SAP Note 712916
СообщениеДобавлено: Пн, окт 16 2006, 13:12
Пытаюсь запустить начальный пакет обновления ОДС -> Куб.
Вылетает сообщение RSM1 188, со следующим объяснением.
Delete init. request REQU_43CGV5Q03XKS3KZ828TLK8SQG before running init. again with same selection
Message no. RSM1188
Diagnosis
If you receive message RSM1 105 as well as this message and you have chosen the automatic mode Automatic Update for the ODS object, it is probable that there are no data targets connected to the ODS object. Therefore the system cannot automatically update data after it has been activated.
System response
After each activation, the system automatically tries to update the data that has been activated to the subsequent data targets. The system generates InfoPackages for this purpose. These check whether a successful initialization has already been performed. If an initialization has already taken place the system tries to update the data with a delta request. If no initialization has yet taken place, the system tries to perform the initialization.
If no data targets have been connected to the ODS object, the system cannot update the data from the ODS object.
This system behavior does not have any effect on the consistency of the data.
Procedure
If no data targets are connected to the ODS object, switch off Automatic Update for this ODS object in the ODS object maintenance or ODS object administration.
Procedure for System Administration
SAP Note 712916 describes the system behavior above.
Смотрю ноту:
Symptom
If you have activated the automatic function 'Automatic Update' foran ODS object, BW automatically tries, after each activation process, to update the data that has just been updated into the data targets behind the ODS.
Generated InfoPackages are used for this purpose.
These InfoPackages check whether a successful initializationhas already been performed and then execute a delta update request or try to perform an initialization without selections.
If this fails, error message RSM1 105 appears in the monitor on the Detail tab under the 'ODS Activation' node:
'Error in generated init. package ZPAK_.... for ODS XXXZ; no update'
In addition, message RSM1 188 usually appears also:
'Delete init request &1 before further inits with overlapping selections'.
This occurs with each new request that you load into the ODS and activatebut the request itself if GREEN ini the monitor and the request is also GREEN and active in the ODS administration, but it is not not updated.
In most cases, this occurs because there are no data targets BEHIND the ODS into which the activated requests of this ODS can be updated.
This is NOT checked if the automatic update function starts but only if the generated InfoPackage is executed.
No incorrect data is created as a result and only these two error messages are written to the monitor.
You can ignore these two messages, but it is preferabletoswitch off the automatic update for this ODS, since there are no data targets behind the ODS into which the data can be updated.
Other terms
Automatic function, automatic update, ODS, RSM1 188, RSM1 105
Reason and Prerequisites
This problem is caused by a program error.
Solution
Switch off the automatic function of the automatic update of the ODS if there are no data targets behind the ODS that are updated.
Цель данных для ОДС существует.
Запрос, который система просит удалить, был неудачным запросом предыдущей попытки загрузки, из администрирования кубика я его пофиксила; в мониторе статус "красный", изменить на зеленый не дает собственно система.
Собственно функцию 'Automatic Update' в ОДС отыскать мне не удалось.
Сняла галочки 'Activate ODS object data automatically' и 'Update data targets from ODS object automatically' в изменении ОДС.
Все равно загрузку данных выполнить не удается, по прежнему вылетает RSM1 188.
При этом сообщение RSM1 105, о котором сказано в ноте - не появлялось.
Где собака порылась?
СообщениеДобавлено: Пн, окт 16 2006, 14:24
Пт, июн 24 2005, 15:18
Так ты инициализацию дельты из ОДС к КУБ удалила ? Попробуй зайди в инфо-пакет, который инициализирует дельту и удалить инициализацию оттуда.
"Если ты в молодости не испытал трудности, их стоит купить за большие деньги". (с) Даймо
СообщениеДобавлено: Пн, окт 16 2006, 14:35
Убрать Initializе delta process? - не могу, недоступна
СообщениеДобавлено: Пн, окт 16 2006, 14:40
LadyWind написала:
Даже в инфо-пакете ?
Menu-> Scheduler -> Initializations options for source system ?
СообщениеДобавлено: Пн, окт 16 2006, 14:43
Попробуй зайти в администрирование куба/ОДС -> Reconstruction.
Там выбери request и попробуй манипулировать там. Хинт: Даже если он красный, его надо В ЯВНОМ ВИДЕ делать красным (или зелёным)
То есть, он может быть в состоянии "Delete status, back to request status"
СообщениеДобавлено: Пн, окт 16 2006, 15:23
Прокатило по первому методу. =)
А во в Reconstruction уже удаленного мной запроса не было :( А те что были, не те, и все зеленые-е-е :cry:
