Текущее время: Ср, авг 26 2026, 20:21
 Заголовок сообщения: 0FIAA_CHA01 activation contains some errors
СообщениеДобавлено: Вт, июн 25 2013, 08:26
Вт, ноя 09 2010, 19:59
всем доброго времени суток!
уже больше месяца (с перерывами) активирую BI_CONT (74704) с акцентом на PS
NW73106 + пачка нот сверху =>
NW73107 + пачка нот сверху =>
NW74002 + пачка нот сверху
начинаешь активироваться, ловишь траблу, накатываешь ноту, откатываешься на чистый бэкап
и так уже несколько итераций
после очередной ноты охладел недели на 2, подождал и продолжил
сейчас при проверке транспорта вываливаются ошибки в основном из 0FIAA_CHA01
   Object ISMP 0ART_PLANT_ATTR SEDCLNT200 was set to 'inactive'
   Object ISMP 0ASSET_AFAB_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0ASSET_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0CLASS_NUM_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0DEPRAREA_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0DEPREC_KEY_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0EVALGROUP1_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0EVALGROUP2_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0EVALGROUP3_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0EVALGROUP4_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0EVALGROUP5_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0FC_CLEARR_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0IM_LEAF_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0IM_SIZE_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0MAT_PLANT_ATTR SEDCLNT200 was set to 'inactive'
   Object ISMP 0NEW_OLD_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0PRODCAT_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0SHEET_GRP_TEXT SEDCLNT200 was set to 'inactive'
   Object ISMP 0STATUSIQMS_TEXT SEDCLNT200 was set to 'inactive'
   Object ISTS 0ART_PLANT_ATTR_SB was set to 'inactive'
   Object ISTS 0FC_CLEARR_TEXT_SB was set to 'inactive'
смущает например
25.06.2013                     Dynamic List Display                            1
|Type|Message text                                                   |LTxt|
|    |Transfer rules 0EVALGROUP1_TEXT SEDCLNT200                     |    |
|    |Filtering fields                                               |    |
|    |Field KEY1 not delivered by source system -> Deleted from rule |    |
|    |Field LANGU not delivered by source system -> Deleted from rule|    |
|    |Field TXTLG not delivered by source system -> Deleted from rule|    |
|    |Field TXTMD not delivered by source system -> Deleted from rule|    |
|    |Field TXTSH not delivered by source system -> Deleted from rule|    |
да, ну не содержатся поля в source...
а начинаешь активировать rule вручную - дает
Error while creating table 'EDISEGMENT' entry '/BIC/CISB0EVALGROUP1_TEXT'
Message no. EA201
Diagnosis
An attempt was made to create the entry '/BIC/CISB0EVALGROUP1_TEXT' in table 'EDISEGMENT'. The attempt failed.
System Response
The operation was canceled.
Procedure
Please check whether the relevant entry already exists.
стою на асфальте в лыжах обутый - то ли лыжи не едут, то ли я долбанутый... :(
что-то уже идеи временно закончились...
может кто намекнёт, в какую сторону метаться ?
 Заголовок сообщения: Re: 0FIAA_CHA01 activation contains some errors
СообщениеДобавлено: Ср, июн 26 2013, 07:48
или это просто ошибка - нужно писать в саппорт ?
