Текущее время: Ср, сен 23 2026, 21:21
 Заголовок сообщения: Flex - ABAP (MM/SD, FI/CO), PP/PI, Logistic InfoSystem Analyst - 26.09.2008
СообщениеДобавлено: Пт, сен 26 2008, 20:31
SAP ABAP Developer (SD & MM modules)
Job Role
Perform full range of support and development activities in the area of ABAP for our Sony Electronics branch in Moscow, focusing on the SD and MM modules.
Job Responsibilities
Working with the SD/MM Designer on implementation of technical solutions for the SAP SD/MM applications
Taking responsibility for development requests from the end of Functional Design through Development, all stages of testing, Go-Live and eventual on-going support
Resolve incoming Production SAP support calls
Consider system performance and possibilities for standardisation when developing solutions
Adhere to SOX guidelines by following the established development and test procedures
Maintain quality Technical Specifications and update documentation repository
Work closely with the designer to identify possible improvements to existing solution and suggest appropriate designs
Liaise with designer and provide accurate estimate of work involved
Provide guidance to solution designers to ensure that thorough testing is carried out
Adhere to existing processes and procedures
Competencies / Skills / Attributes
Communication
Identifies and keeps informed all parties interested in the development taking place. Explains technical information to Designer without using jargon. Documents decisions clearly. Keeps communication channels open within geographically dispersed team members.
Analytical Skills
Needs to be a first-class problem solver – able to boil complex problems down to their constituent elements, and then formulate and evaluate a range of alternative solutions. Must have excellent conceptual design skills – an instinctive feel for which solutions ‘fit’ and which need rethinking.
Technical Skills
Shows broad understanding of ABAP as it relates to SAP SD/MM and acts as key source of expertise in this field. Maintains and regularly updates knowledge of processes, products and best practice principles in own area. Able to identify appropriate technical solutions. Must have a good understanding of key system design principles (documentation, testing, Change Request procedure, SDLC, etc.).
Service Focus
Helps the Designer to understand and define their requirements. Considers situation from customer perspective and tailors communication accordingly. Sensitive to customer satisfaction, always looks for ways of improving level of service.
Personal Responsibility and Achievement Orientation
Exhibits desire to make things happen. Obtains results, guaranteeing quality and timeliness, even in case of setbacks. Able to multi-task effectively, and cope with pressures from multiple directions. Seizes opportunities and maintains a positive approach.
Teamwork and Co-operation
Actively contributes to teamwork, sharing experiences and ideas. Shares information as a member of the group by keeping the other members informed of everything, which is relevant or useful for the group. Provides personal support to other team members in times of trouble.
Experience & Specific Job Requirements
2+ years of ABAP experience specific to SAP SD/MM modules including analysis, design, development, testing, compliance & implementation (ideally project experience)
Key expertise in the areas of developing Reports, SAPSCRIPT, Interfaces (outgoing, incoming), Conversions (data migration), Extensions (Customisations, e.g. User Exits, RFC development, BAPI’s), Idocs, ALE/EDI.
A reasonable broad functional understanding of SAP SD/MM
Experience in the following areas is a plus:
- Business Warehouse
- Smartforms
- Workflow
Excellent communication skills – ability to interpret business issues to provide solution
Ability to prioritise and escalate issues
Analytical mindset with an strong eagerness to learn
Speaks Russian fluently
Speaks English well
М. Полежаевская
Заработная плата обсуждаема
SAP ABAP Developer (FI & CO modules)
Job Role
Perform full range of support and development activities in the area of ABAP for our Sony Electronics branch in Moscow, focusing on the FI and CO modules.
Working with the FI/CO Designer on implementation of technical solutions for the SAP FI/CO applications
Communication
Analytical Skills
Technical Skills
Shows broad understanding of ABAP as it relates to SAP FI/CO and acts as key source of expertise in this field. Maintains and regularly updates knowledge of processes, products and best practice principles in own area. Able to identify appropriate technical solutions. Must have a good understanding of key system design principles (documentation, testing, Change Request procedure, SDLC, etc.).
Service Focus
2+ years of ABAP experience specific to SAP FI/CO modules including analysis, design, development, testing, compliance & implementation (ideally project experience)
Key expertise in the areas of developing Reports, Interfaces (outgoing, incoming), Conversions (data migration), Extensions (Customisations, e.g. User Exits, RFC development, BAPI’s), Idocs, ALE/EDI.
A reasonable broad functional understanding of SAP FI/CO
- Smartforms
- Workflow
Speaks English well
М. Полежаевская
SAP PP/PI Application Analyst
PURPOSE
System Analysis, Participation in PP/PI implementation, maintenance of SAP PP/PI and related modules,
Maintenance of XI interfaces, Documentation and user support, work-out of reporting required.
MINIMUM REQUIREMENTS
EDUCATION - High School
YEAR EXPERIENCE - 4 - 7
SPECIFIC KNOWLEGE - Extensive experience with SAP PP/PI, experience in FI/MM/CO is a plus, good knowledge of ABAP/4
AREAS of RESPONSIBILITIES and related ACTIVITES
SAP PP/PI implementation assistance and maintenance
• Participation in PP/PI implementation project, functional analysis,
• Maintenance of SAP PP/PI and related modules
• Maintenance of XI interfaces
• Documentation of processes
• Work-out of required reporting
SAP User assistance
• Service Desk
• Support to existing SAP applications in MM/FI/CO areas per request
• User training
соц. пакет:
м. Маяковская
1. доплата на питание 2,200 плюс к з/п
2. Мед. страх. вкл. стоматолога
3. Гибкие льготы ( можно на выбор компенс. фитнеса, страховка на родственника.
4. тренинги 1-2 раза в год
5. изучение на выбо англ. либо итальянского яз.
6. 10 дней полностью оплачиваемого больничного в год
Оклад обсуждается на интервью: в районе от 130 000 т.р – 150 000 т.р
PURPOSE
Design and implementation of logistic related applications, interfaces, Databases administration and maintenance. Data exchange maintenance among various partners. Reporting. User support. Assistance to IT with implementation of new MM/SD processes in SAP R/3.
SPECIFIC KNOWLEGE - Knowledge of modern software development methods, application design patterns, Microsoft .NET development (C# or VB.NET), XML, web applications basics, Microsoft SQL Server. Basic knowledge of SAP MM/SD is a plus
LOGISTIC APPLICATIONS MAINTENANCE
• Design and implementation of logistic related applications
• Interfaces to various systems
• Data exchange design and maintenance among various partners
• Relevant reporting
BUSINESS APPLICATIONS SUPPORT
• Assistance to IT with implementation of new MM/SD functionality in SAP R/3
• On-going support to existing SAP R/3 modules
DATABASE ADMINISTRATION /
• Maintenance of SQL Server and relevant databases /
USER TRAINING and SUPPORT/
• Performing training of personnel /
соц. пакет:
м. Маяковская
Оклад обсуждается на интервью: в районе от 90 000 т.р. – 100 000 т.р.
Alena Starichenkova
Recruitment Consultant
Starichenkova@flexsearch.ru
Flex
Pls check our www.flexsearch.ru
Main: +7 495 933 7152
Fax: +7 499 246 10 27
18 M. Pirogovskaya str., off. 104
Moscow 119435
Russia
