Текущее время: Чт, сен 24 2026, 18:32
 Заголовок сообщения: Enhancement point  Тема решена
СообщениеДобавлено: Пт, окт 23 2009, 15:09
Пт, апр 07 2006, 22:15
Коллеги, возник спор. А затирается ли subj при установке сапочких патчей?
Для явных и неявных subj.
 Заголовок сообщения: Re: Enhancement point
СообщениеДобавлено: Пт, окт 23 2009, 15:14
Пт, июн 16 2006, 00:43
Пятничная тема?
:rtfm:
СообщениеДобавлено: Пт, окт 23 2009, 15:18
Пятничная тема?
:rtfm:
Слуште, я прекрасно знаю что есть курс. Но неужели тяжело написать?
СообщениеДобавлено: Пт, окт 23 2009, 15:26
Какой курс, вы об чем щас? Инофрмация должна быть общедоступной ;)
Просвящайтесь http://help.sap.com/erp2005_ehp_04/help ... ameset.htm.
Даже упрощу задачу:
SAP написал(а):
ABAP source texts can be enhanced through ABAP source code enhancements to implicit and explicit enhancement options. The following changes to ABAP source code have the effect that they are included in the set of objects to be adjusted.
· A program (compilation unit) with enhancement options was deleted.
· A procedure (method, function module, subroutine) with enhancement options was deleted.
· The definition of an enhancement option with ENHANCEMENT-POINT or ENHANCEMENT-SECTION was deleted.
· The coding of an explicit enhancement option defined between ENHANCEMENT-SECTION and END-ENHANCEMENT-SECTION has changed.
· In a processing block that contains an enhancement option, the coding before the enhancement option has changed.
· A function module with enhancement options has been moved to another function group.
· A processing block with enhancement options was moved within its program into another Include program.
· A conflict has occurred between source code plug-ins for enhancements defined with ENHANCEMENT-SECTION.
· An enhancement option that referred to the framework program has become a point that refers to the Include program, or vice versa.
· A static enhancement option has become a dynamic enhancement option, or vice versa.
SAP написал(а):
The adjustment tools are integrated into the Enhancement Builder. You can select one of them if an enhancement implementation is processed that is part of the set of objects to be adjusted.
Procedure
1. Call an enhancement implementation from the set of objects to be adjusted in change mode.
2. Select the additional tab page Adjustment.
3. The conflict list displays the adjustment status.
4. Perform the kind of adjustment suited for the enhancement technology:
a. Tool-aided adjustment
b. Adjustment without tools
5. Set the enhancement implementation to the state Adjusted.
6. Activate the enhancement implementation.
The edited enhancement is removed from the set of objects to be adjusted after the adjustment is complete.
СообщениеДобавлено: Пт, окт 23 2009, 17:07
Я не понял.
Эту фразу надо понимать как "ломает точку расширения"?
СообщениеДобавлено: Пт, окт 23 2009, 17:10
Вверху описаны ситуации, когда требуется дополнительное вмешательство для адаптирования (adjust) энхансментов к изменениям в стандарте. Внизу - как это делается.
Если вы не понимаете значения некоторых слов, есть другая общедоступная ссылка http://translate.google.ru/ ;)
P.S.: В принципе можно считать что и ломает. Так как до адаптации реализации таких расширений будут неактивными.
СообщениеДобавлено: Вт, ноя 24 2009, 23:55
Вт, июл 10 2007, 10:57
Для выяснения какие из расширений затёрлись есть транзакция SPAU_ENH .
