Текущее время: Чт, сен 24 2026, 17:13
Начать новую тему Ответить на тему  [ Сообщений: 24 ]  На страницу Пред.  1, 2
 Заголовок сообщения: Re: В созданной Z таблице расширить поле до 7 знаков после запятой
СообщениеДобавлено: Пт, фев 04 2011, 16:43
Пн, июн 25 2007, 17:37
Динамическая ошибка BCD_FIELD_OVERFLOW
Особая ситуация CX_SY_CONVERSION_OVERFLOW
Возникла: 04.02.2011 в 15:16:07
A calculation field is defined too small.
Что произошло?
Error in ABAP application program.
The current ABAP program "%_T01JR0" had to be terminated because one of the
statements could not be executed.
This is probably due to an error in the ABAP program.
Что Вы можете сделать?
Print out the error message (using the "Print" function)
and make a note of the actions and input that caused the
error.
To resolve the problem, contact your SAP system administrator.
You can use transaction ST22 (ABAP Dump Analysis) to view and administer
termination messages, especially those beyond their normal deletion
date.
Анализ ошибки
An exception occurred. This exception is dealt with in more detail below
. The exception, which is assigned to the class 'CX_SY_CONVERSION_OVERFLOW',
was neither
caught nor passed along using a RAISING clause, in the procedure "DEF_MAP"
"(FORM)"
Since the caller of the procedure could not have expected this exception
to occur, the running program was terminated.
The reason for the exception is:
A value generated during processing is too large for the
field "QCM8ZFM_VISA_LDO_WA-NETWR" of the program "%_T01JR0".
Указания по устранению ошибки
The exception must either be prevented, caught within the procedure "DEF_MAP"
"(FORM)", or declared in the procedure's RAISING clause.
To prevent the exception, note the following:
It may be possible to divide the current process into
smaller units, so that only smaller values occur.
Otherwise, as a long-term solution, define the field
larger.
You may able to find an interim solution to the problem
in the SAP note system. If you have access to the note system yourself,
use the following search criteria:
"BCD_FIELD_OVERFLOW" CX_SY_CONVERSION_OVERFLOWC
"%_T01JR0" or "%_T01JR0"
"DEF_MAP"
If you cannot solve the problem yourself, please send the
following documents to SAP:
1. A hard copy print describing the problem.
To obtain this, select the "Print" function on the current screen.
2. A suitable hardcopy prinout of the system log.
To obtain this, call the system log with Transaction SM21
and select the "Print" function to print out the relevant
part.
3. If the programs are your own programs or modified SAP programs,
supply the source code.
To do this, you can either use the "PRINT" command in the editor or
print the programs using the report RSINCL00.
4. Details regarding the conditions under which the error occurred
or which actions and input led to the error.
Системная среда
SAP Release.............. "620"
Application server....... "sap-qr3-n01"
Network address.......... "0.0.0.0"
Operating system......... "SunOS"
Release.................. "5.10"
Hardware type............ "sun4u"
Character length......... 8 Bits
Pointer length........... 64 Bits
Work process number...... 7
Short dump setting....... "full"
Database server.......... "sap-qr3-n01"
Database type............ "ORACLE"
Database name............ "QAS"
Database owner........... "SAPQAS"
Character set............ "ru"
SAP kernel............... "640"
Created on............... "Sep 20 2010 21:42:04"
Created in............... "SunOS 5.9 Generic_122300-13 sun4u"
Database version......... "OCI_102 "
Patch level.............. "347"
Patch text............... " "
Supported environment....
Database................. "ORACLE 8.1.7.*.*, ORACLE 9.2.0.*.*, ORACLE
10.1.0.*.*, ORACLE 10.2.0.*.*, ORACLE 11.2.0.*.*"
SAP database version..... "640"
Operating system......... "SunOS 5.8, SunOS 5.9, SunOS 5.10"
Пользователь, транзакция...
Client.............. 200
User................ "USER"
Language key........ 8
Transaction......... "SEU_INT "
Program............. "%_T01JR0"
Screen.............. "SAPMSSY0 1000"
Screen line......... 6
Информация о месте прерывания
The termination occurred in the temporary subroutine pool "%_T01JR0" in
"DEF_MAP".
The main program was "RADGENREP ".
The point of termination in the source code is in line 146 of
the temporary subroutine pool "%_T01JR0".
Processing was terminated because the exception "CX_SY_CONVERSION_OVERFLOW"
occurred in the
procedure "DEF_MAP" "(FORM)" but was not handled locally, not declared in the
RAISING clause of the procedure.
The procedure is in the program "%_T01JR0 ". Its source code starts in line 131
of the (Include) program "%_T01JR0 ".
Фрагмент исходного текста программы
001160 * *
001170 * FORM DEF_MAP *
001180 * *
001190 * ........ *
001200 * *
001210 * > SOURCE_TAB_TAB *
001220 * > DEST_TAB_TAB *
001230 * > CLIENTLIST *
001240 * > SRC_NAME *
001250 * > DST_NAME *
001260 * > C_ADDED *
001270 * > PRID *
001280 * > RC *
001290 * *
001300 FORM DEF_MAP tables CLIENTLIST STRUCTURE DDCLIENT
001310 using QCMZFM_VISA_LDO_TAB type QCMZFM_VISA_LDO_t
001320 QCM8ZFM_VISA_LDO_TAB type QCM8ZFM_VISA_LDO_t
001330 SRC_NAME LIKE DD02L-TABNAME
001340 DST_NAME LIKE DD02L-TABNAME
001350 C_ADDED " client added
001360 PRID LIKE SYST-TABIX
001370 RC LIKE SYST-TABIX.
001380 DSTRUC_DEF QCM8ZFM_VISA_LDO : QCM8ZFM_VISA_LDO_WA.
001390 FIELD-SYMBOLS <WA> type QCMZFM_VISA_LDO.
001400 FIELD-SYMBOLS <f> type c.
001410 CLEAR RC.
001420 LOOP AT QCMZFM_VISA_LDO_TAB ASSIGNING <WA>.
001430 MOVE-CORRESPONDING <WA> TO QCM8ZFM_VISA_LDO_WA.
001440 APPEND QCM8ZFM_VISA_LDO_WA TO QCM8ZFM_VISA_LDO_TAB.
001450 ENDLOOP.
> ENDFORM.
001470 * *
001480 * FORM DEF_OPEN *
001490 * *
001500 * ........ *
001510 * *
001520 * > C *
001530 * > RC *
001540 * *
001550 FORM DEF_OPEN USING C TYPE CURSOR
001560 RC LIKE SYST-SUBRC.
001570 OPEN CURSOR WITH HOLD C FOR SELECT * FROM QCMZFM_VISA_LDO
001580 CLIENT SPECIFIED BYPASSING BUFFER.
001590 RC = SYST-SUBRC.
001600 ENDFORM.
Содержимое системных полей
SY-поле Содержание................... SY-поле Содержание...................
SY-SUBRC 0 SY-INDEX 1
SY-TABIX 43 SY-DBCNT 109
SY-FDPOS 0 SY-LSIND 0
SY-PAGNO 0 SY-LINNO 1
SY-COLNO 1 SY-PFKEY
SY-UCOMM SY-TITLE
SY-MSGTY I SY-MSGID SF
SY-MSGNO 616 SY-MSGV1 RADGENREP
SY-MSGV2 RE SY-MSGV3 EN
SY-MSGV4
Активные вызовы/события
№..... Тип......... Имя...........................
Программа
Include Строка
Класс
3 FORM DEF_MAP
%_T01JR0
%_T01JR0 146
2 FORM DATA_COPY
%_T01JR0
%_T01JR0 77
1 EVENT START-OF-SELECTION
RADGENREP
RADGENREP 80
Выбранные переменные
3 FORM DEF_MAP
%_T01JR0
%_T01JR0 146
RC 0
0000
0000
QCMZFM_VISA_LDO_TAB Table IT_26[109x198]
<WA> 20060000000000006201145001610680001029.5
3333333333333333333333333333333333333323
20060000000000006201145001610680001029E5
... + 40 1.12.700.0061 Автомат пескострельный L6
32332333233332BDEDDDE2DDEDDEEEDDEDED2243
1E12E700E00610022EC020F51AE1205BCDB900C6
... + 80 5 #######ST #1g#####4##D####
3222222222222200000005520360000038140000
50000000000000000010C340017000C345340C00
... + 120 ###3HQ4L #######3912012702
0003453422222222220000000333333333322222
C003814C0000000000000000C391201270200000
... + 160 20110105##3HQ4L##############
22222222233333333003453400000000000000
00000000020110105003814C000000C000000C
<%_TABLE_QCM8ZFM_VISA_LDO> ???
QCM8ZFM_VISA_LDO_WA-MENGE #######
0000000
000100C
<WA>-MENGE #######
0000000
000010C
QCM8ZFM_VISA_LDO_WA-NETPR 1g#####
3600000
170000C
<WA>-NETPR #1g####
0360000
017000C
QCM8ZFM_VISA_LDO_WA-NETWR #######
0000000
000000C
<WA>-NETWR #4##D##
0381400
345340C
QCM8ZFM_VISA_LDO_TAB Table IT_27[42x221]
QCM8ZFM_VISA_LDO_WA 20060000000000006201145001610680001029.5
... + 80 5 #######ST 1g##############
3222222222222200000005523600000000000000
50000000000000000100C340170000C000000C00
... + 120 #####1P# #######
0000035022222222220000000222222222222222
C000010C0000000000000000C000000000000000
... + 160 105018 #######20101215
2333333222222222222222222000000033333333
0105018000000000000000000000000C20101215
... + 200 ####7################
000038000000000000000
000070C000000C000000C
2 FORM DATA_COPY
%_T01JR0
%_T01JR0 77
C_ADDED
2
0
PRID 0
0000
0000
RC 0
0000
0000
%_PRINT 000
2222333222222222222222222222222222222222
0000000000000000000000000000000000000000
... + 40
2222222222222222222222222222222222222222
... + 80 0 ########
2222222222320000000022222222222222222222
... + 120
... + 160 0 ####
222222222222223222222222222222220000
LOAD-MAPREPID %_T01JR0
2553345322222222222222222222222222222222
5F401A2000000000000000000000000000000000
LOAD-MAPFORM DEF_MAP
444544522222222222222222222222
456FD1000000000000000000000000
SYST ###########+###m########################
0000000000020006000000000000000000000000
00010000000B000D000000000000000000000000
... + 40 ###m###################################Ц
000600000000000000000000000000000000000C
000D000000010000000100000000000000000006
... + 80 ###################н####################
0000000000000000000D00000000000000000000
... + 120 ###################################2###Ў
000000000000000000000000000000000003000A
000000000000000000000000000000000002000E
... + 160 ############### u############# 80 X1
0000000000000012270000000000000222332253
00000000000000C0050050000C0000C000800081
... + 200 000 ####__S 200
3332222222220000555222222222222222223332
0000000000000000FF3000000000000000002000
... + 240 00
222223322222222
000000000000000
CLIENTLIST[] Table IT_25[1x3]
CLIENTLIST 200
333
200
RSJOBINFO 00000000
2222222222222222222222222222222233333333
... + 40 000000
3333332222222222222222222222222222222222
... + 80 ####
0000
0000
SY-ONCOM S
5
3
%_SPACE
2
0
СообщениеДобавлено: Пт, фев 04 2011, 16:44
RADGENREP
RADGENREP 80
%_ACT_MODE_%_APP_% ACT_MODE
445544442222222222222222222222
134FDF450000000000000000000000
%_DUMMY$$
2222
0000
REPID %_T01JR0
%_PRINT 000
... + 40
... + 80 0 ########
... + 120
... + 160 0 ####
WITHLOCK X
5
8
COM_SIZE 16777216
0000
1000
CLISTATE
2
0
LOADER DEF_OPEN
2222222222444545442222222222222222222222
0000000000456FF05E0000000000000000000000
... + 40 %_T01JR0
... + 80 DEF_FETCH %_T01JR0
4445445442222222222222222222222553345322
456F654380000000000000000000005F401A2000
... + 120
... + 160
... + 200 DEF_CLOSE
2222222222222222222244454445422222222222
00000000000000000000456F3CF3500000000000
... + 240 %_T01
222222222225533
00000000005F401
ACT_MODE I
422
900
STAT-ROW_CNT 0
0000
0000
STAT-DUP_CNT 0
0000
0000
STAT-INSERT_CNT 0
0000
0000
STAT-COM_CNT 0
0000
0000
STAT-ARRAY_SIZE 2372
0004
0094
STAT-TAB_WIDTH 221
000D
000D
PROTOCOL
%_SPACE
2
0
RSJOBINFO 00000000
... + 40 000000
... + 80 ####
0000
0000
DUP_CNT 0
0000
0000
STAT ###########D###############н############
000000000004000000000000000D000000000000
000000000094000000000000000D000000000000
... + 40 ####
0000
000C
SCREEN %_17SNS0000193940_%_%_%_%_%_%_
2533545333333333352525252525252222222222
5F173E30000193940F5F5F5F5F5F5F0000000000
... + 40
... + 80
... + 120 SRI00001#00000 ####
2222222222222222222225543333303333320000
0000000000000000000003290000100000000000
Вызовы приложения
Относительно этого в дампе нет информации.
Информация по приложению
Внутренние указания
The termination occurred in the function "ab_Story" of the SAP
Basis System, specifically in line 2200 of the module
"//bas/640_REL/src/krn/runt/abmove1.c#7".
The internal operation just processed is "MOVE".
The internal session was started at 20110204151607.
Активные вызовы в SAP-ядре
[0] DoStack2 ( 0x10048be58, 0x0, 0xffffffff7fffa350, 0x733000, >
> 0x102952678, 0x104958b00 ), at 0x10048be58
[1] CTrcStack2 ( 0x104958b00, 0x0, 0x69800, 0x24c6cc4, 0x102952678, >
> 0x2 ), at 0x10048ba04
[2] __1cQrabax_CStackSave6F_v_ ( 0x0, 0x2b88400, 0x10321a0c8, >
> 0x101ef8a17, 0x101ef8800, 0x104958b00 ), at 0x100a438b4
[3] ab_rabax ( 0x4b3c800, 0x103219400, 0x1, 0x104b3c800, 0x2000000, >
> 0x1 ), at 0x100a34960
[4] ab_Move ( 0x0, 0xfffffffdaa5add60, 0xfffffffe58c54847, 0xfffffffdaa5add74, >
> 0x7, 0xfffffffe58c5df6b ), at 0x1006e168c
[5] __1cIab_jmove6F_v_ ( 0xfffffffe58c5df6b, 0xfffffffe58c54847, >
> 0xfffffffdaa5add60, 0x10495a180, 0x104b3fef0, 0xfffffffdaa5ae390 ), at 0x1006df9a4
[6] __1cIab_extri6F_i_ ( 0x10497cc00, 0x4b3fc00, 0x497cc00,0x1a8, >
> 0x1, 0x0 ), at 0x1006badd0
[7] __1cJab_xevent6Fpkc_i_ ( 0xfffffffd9986fc88, 0xfffffffd998718b8, >
> 0xfffffffd99871b1c, 0x1049591b4, 0x104b3fef0, 0x264 ), at 0x100890b6c
[8] __1cIab_trigg6F_i_ ( 0x100000000, 0x495a000, 0x10495a180, >
> 0x0, 0x98, 0x0 ), at 0x100890368
[9] ab_run ( 0x104a2bc00, 0x491b400, 0x4a2bc00, 0x10495a180, >
> 0x100000000, 0x101efd677 ), at 0x100a9f504
[10] dynpmcal ( 0xfffffffe58c69380, 0xfffffffe58c69f30, 0x1, >
> 0x100000000, 0xc, 0xc ), at 0x10051ec1c
[11] dynppai0 ( 0xfffffffe58c69380, 0x0, 0x0, 0x453, 0x1, 0x1023cf290 >
> ), at 0x10051baf4
[12] dynprctl ( 0xfffffffe58c69380, 0xfffffffe58c69612, 0x102e15a78, >
> 0x102999ce4, 0xfffffffe58c69cd0, 0x1029be640 ), at 0x100519570
[13] dynpen00 ( 0x0, 0x0, 0x0, 0x23ce000, 0x0, 0x1 ), at 0x100515524
[14] TskhLoop ( 0x0, 0xffffffff78f018d8, 0x0, 0x102998800, 0x1, 0x1 ), at 0x10026fa20
[15] DpMain ( 0x2, 0xffffffff7ffffb08, 0xffffffff7ffffb20, 0xffffffff7c249488, >
> 0x2, 0x2998800 ), at 0x100188848
Список задействованных АВАР-программ
Тип Программа ДатаГен Время РазмЗагр
Prg RADGENREP 26.12.2010 16:12:10 35840
Prg SAPMSSY0 26.07.2008 14:15:29 67584
Prg SAPMSSYD 05.06.2002 17:09:33 16384
Prg SAPFSYSCALLS 14.02.2002 14:22:47 6144
Prg RSDBRUNT 26.12.2010 16:19:59 227328
Typ RSSCR . . : m:15 4096
Prg RSDBSPBL 07.01.2003 18:47:02 59392
Prg SAPDB__S 14.02.2002 14:22:47 15360
Typ VARID 12.05.1997 16:51:30 4096
Prg %_CSYDB0 14.02.2002 14:22:46 28672
Prg RSDBSPVA 24.01.2009 06:33:23 113664
Typ RSVAMEMKEY 07.05.1997 13:07:49 2048
Typ DDLOAD 28.08.1997 08:44:03 3072
Prg RSDBSPMC 05.06.2002 17:09:26 66560
Typ DDSHDESCR 03.09.1997 03:05:16 3072
Typ SPPARAMS 07.05.1997 13:10:38 2048
Prg SAPLICON 02.07.2003 13:17:13 23552
Prg %_CICON 14.02.2002 14:22:46 65536
Prg SAPLSABE 14.02.2002 14:22:47 11264
Prg SAPLSECU 26.12.2010 16:10:30 64512
Typ RSSUBINFO 14.10.1999 22:01:03 3072
Prg SAPLDSYA 26.12.2010 16:26:30 41984
Prg SAPFSDS1 07.01.2003 18:32:17 47104
Typ TDCLD 02.11.1998 09:51:35 5120
Prg SAPLSDOD 12.10.2009 09:29:32 39936
Typ DOKIL 12.05.1997 16:46:17 3072
Prg SAPCNVE 14.02.2002 14:22:47 6144
Prg SAPLLANG 23.09.2006 09:54:37 8192
Typ T002 23.09.2006 09:53:58 2048
Typ RSEXFCODE 13.08.1997 12:52:57 1024
Typ RSPARINT 10.04.1995 09:58:38 1024
Typ RSSELINT 04.04.1995 16:12:37 2048
Prg SAPLSCNT 14.02.2002 14:22:47 24576
Typ DYCBOX 20.08.1998 11:16:53 2048
Prg SAPLSVSM 12.08.2007 11:29:35 24576
Prg SAPLSGUI 12.08.2007 11:29:16 31744
Prg SAPLSTTM 06.04.2006 20:56:21 75776
Prg SAPLSBDC 06.04.2006 21:53:48 38912
Prg CL_DATAPROVIDER===============CP 14.02.2002 14:22:46 40960
Prg %_CCNTL 14.02.2002 14:22:46 13312
Typ OBJ_RECORD 14.02.1998 08:30:43 2048
Prg SAPLSTUP 12.10.2009 09:29:33 65536
Prg SAPLCNDP 26.12.2010 16:26:15 172032
Prg SAPFGUICNTL 09.01.2003 17:18:52 20480
Prg SAPLOLEA 12.10.2009 09:30:34 79872
Prg SAPLSFES 26.12.2010 16:26:31 227328
Prg SAPLSPLUGIN 14.02.2002 14:22:48 6144
Typ ARFCRDATA 09.11.2000 14:04:16 6144
Prg SAPLGRFC 14.02.2002 14:22:47 13312
Typ SWCBCONT 15.11.2000 17:55:11 3072
Typ OLE_VERBS 04.04.1995 16:02:20 2048
Typ OLE_PA 04.04.1995 16:02:19 2048
Prg SAPSHDTV 26.03.2003 09:03:16 28672
Typ SSCRTEXTS 03.09.1997 03:12:33 2048
Typ SSCRFIELDS 13.05.1997 12:54:26 4096
Prg SAPLSDB2 12.10.2009 09:29:32 393216
Typ DDCLIENT 28.10.1998 13:07:02 1024
Typ QCM8ZFM_VISA_LDO 03.02.2011 12:01:56 5120
Typ QCMZFM_VISA_LDO 03.02.2011 12:01:56 4096
Prg SAPLSBUF 26.12.2010 16:11:38 122880
Prg %_T01JR0 04.02.2011 15:16:07 19456
Prg CX_SY_CONVERSION_OVERFLOW=====CP 06.06.2001 13:11:16 8192
Typ SCX_SRCPOS 09.11.2000 14:12:15 1024
Prg CX_SY_CONVERSION_ERROR========CP 06.06.2001 13:11:16 8192
Prg CX_DYNAMIC_CHECK==============CP 14.02.2002 14:22:47 8192
Prg CX_ROOT=======================CP 14.02.2002 14:22:47 9216
Prg CX_NO_CHECK===================CP 14.02.2002 14:22:47 8192
Prg CX_SY_NO_HANDLER==============CP 14.02.2002 14:22:47 8192
Prg %_CRSDS 14.02.2002 14:22:46 8192
Prg %_CSYLDB 14.02.2002 14:22:46 6144
Typ ETCF_SVARS 11.05.2004 09:51:35 1024
Typ CAT_SVARS 11.05.2004 09:51:39 2048
Typ SYST 04.12.2000 14:54:51 27648
Typ DDCPYSTAT 07.05.1997 12:48:48 3072
Список внутренних таблиц
\PROGRAM=%_T01JR0\FORM=DATA_COPY\DATA=QCMZFM_VISA_LDO_TAB
Table reference: 23
TABH+ 0(20) = FFFFFFFE58CD2A20FFFFFFFE58CB98F000000000
TABH+ 20(20) = 000000170000001A0000006D000000C600000018
TABH+ 40(16) = 0400003F00000610001024C401000000
store = 0xFFFFFFFE58CD2A20
ext1 = 0xFFFFFFFE58CB98F0
shmId = 0 (0x00000000)
id = 23 (0x00000017)
label = 26 (0x0000001A)
fill = 109 (0x0000006D)
leng = 198 (0x000000C6)
loop = 24 (0x00000018)
xtyp = TYPE#000018
occu = 16 (0x00000010)
access = 1 (ItAccessStandard)
idxKind = 0 (ItIndexNone)
uniKind = 2 (ItUniqueNon)
keyKind = 1 (default)
cmpMode = 8 (cmpManyEq)
occu0 = 1
collHash = 0
groupCntl = 0
rfc = 0
unShareable = 0
mightBeShared = 0
sharedWithShmTab = 0
isShmLockId = 0
gcKind = 0
isUsed = 1
>>>>> Shareable Table Header Data <<<<<
tabi = 0xFFFFFFFE58C87F70
pghook = 0xFFFFFFFE58CB9718
idxPtr = 0x0000000000000000
refCount = 0 (0x00000000)
tstRefCount = 0 (0x00000000)
lineAdmin = 112 (0x00000070)
lineAlloc = 112 (0x00000070)
store_id = 20 (0x00000014)
shmIsReadOnly = 0 (0x00000000)
>>>>> 1st level extension part <<<<<
regHook = 0xFFFFFFFE58CB9750
hsdir = 0x0000000000000000
ext2 = 0x0000000000000000
>>>>> 2nd level extension part <<<<<
tabhBack = Not allocated
delta_head = Not allocated
pb_func = Not allocated
pb_handle = Not allocated
\PROGRAM=%_T01JR0\FORM=DATA_COPY\DATA=QCM8ZFM_VISA_LDO_TAB
Table reference: 24
TABH+ 0(20) = FFFFFFFE58C899D0000000000000000000000000
TABH+ 20(20) = 000000180000001B0000002A000000DDFFFFFFFF
TABH+ 40(16) = 0400003F000006B8001024C401000000
store = 0xFFFFFFFE58C899D0
ext1 = 0x0000000000000000
id = 24 (0x00000018)
label = 27 (0x0000001B)
fill = 42 (0x0000002A)
leng = 221 (0x000000DD)
loop = -1 (0xFFFFFFFF)
xtyp = TYPE#000021
occu0 = 1
collHash = 0
groupCntl = 0
rfc = 0
unShareable = 0
mightBeShared = 0
isShmLockId = 0
gcKind = 0
isUsed = 1
tabi = 0xFFFFFFFE58C88BE8
pghook = 0xFFFFFFFE58C89A28
lineAdmin = 48 (0x00000030)
lineAlloc = 48 (0x00000030)
store_id = 21 (0x00000015)
regHook = Not allocated
hsdir = Not allocated
ext2 = Not allocated
\PROGRAM=%_T01JR0\FORM=DATA_COPY\DATA=CLIENTLIST[]
Table reference: 22
TABH+ 0(20) = FFFFFFFE58CD2BA0000000000000000000000000
TABH+ 20(20) = 00000016000000190000000100000003FFFFFFFF
TABH+ 40(16) = 0400003F000007600021249401000000
store = 0xFFFFFFFE58CD2BA0
id = 22 (0x00000016)
label = 25 (0x00000019)
fill = 1 (0x00000001)
leng = 3 (0x00000003)
xtyp = TYPE#000024
occu = 33 (0x00000021)
cmpMode = 2 (cmpSingleMcmpR)
occu0 = 1
collHash = 0
groupCntl = 0
rfc = 0
unShareable = 0
mightBeShared = 0
isShmLockId = 0
gcKind = 0
isUsed = 1
tabi = 0xFFFFFFFE58CD2B20
pghook = 0x0000000000000000
lineAdmin = 33 (0x00000021)
lineAlloc = 33 (0x00000021)
store_id = 19 (0x00000013)
Каталог прикладных таблиц
Программа
Имя................. Содержимое1....+....2....+....3....+....4....+....5....+....
RADGENREP
SYST \0\0\0\0\0\0\0\0\0\0\0\x01\0\0\0m\0\0\0\0\0\0\0\0\0\0\0\0
RSJOBINFO 00000000000000
SSCRFIELDS
SSCRTEXTS
RSDBRUNT
RSVUVINT
VARID
SAPFSDS1
TDCLD RE DOKU 8R XX XXLIMUDOKUX \x1E\0XR3TRPROGX
SAPLSDOD
DOKIL
SAPLLANG
T002 ES1EN
Каталог прикладных таблиц (административная информация)
Программа
Имя.......................... Время......... Длина...
SAPLLANG
SYST 20010612125650 00002404
RSJOBINFO 00000084
SSCRFIELDS 20000323224119 00000854
SSCRTEXTS 00000371
RSDBRUNT
RSVUVINT 00000047
VARID 00000132
SAPFSDS1
TDCLD 00000050
SAPLSDOD
DOKIL 00000076
SAPLLANG
T002 00000005
АВАР-контрольные блоки CONT
Include Строк ИсходнТекст
Индкс Имя Фл Co Пар01 Пар2. Пар3. Пар4. Таблица
%_T01JR0 131
340 PERP 10
%_T01JR0 144
341 CLEA 00
%_T01JR0 145
342 LOOP 00 0000
346 TUTL 0E C001
348 LOOP 03 43 C001 0000
352 LOOP 05 C001 0000
356 BRAN 05
%_T01JR0 146
357 MVCO 00
358 mvqk 5E 8A
360 MOVE FF 34 C003
362 mvqk 03 8A 0065
364 MOVE FF 34 C005
>>>>> MOVE FF 34 C007
368 mvqk 1B 8A 0076
370 mvqk 18 8A 0091
372 mvqk 1D 8A 00A9
374 MVCO 01
%_T01JR0 147
375 TAPP 00 43 C000
%_T01JR0 148
377 BRAX 01
%_T01JR0 150
378 ENDF 00
Конец анализа динамической ошибки
СообщениеДобавлено: Сб, фев 05 2011, 18:03
Пн, окт 11 2004, 20:32
В QAS'е должна остаться таблица QCMZFM_VISA_LDO - это копия (с данными) вашей таблицы до расширения, ну и новая таблица, видимо ZFM_VISA_LDO. Проверьте там поле NETWR, точно ли они с теми доменами что нужны.
Если все нормально - то можно попробовать через утилиту БД продолжить адаптацию таблицы - мало ли, мож был какой случайный глюк.
- Настоящий мастер может все!
СообщениеДобавлено: Пн, фев 07 2011, 10:09
ArmAnn написал:
Да я уже выше пример приводил там где пересылка, это и есть в утилитах базы данных при активации на 5 этапе!
-> MOVE-CORRESPONDING <WA> TO QCM8ZFM_VISA_LDO_WA.
ENDLOOP.
СообщениеДобавлено: Пн, фев 07 2011, 20:12
Valeriy написал:
тогда поглядите в QAS'е таблицу QCMZFM_VISA_LDO - это копия (с данными) вашей таблицы до расширения, ну и новая таблица, видимо ZFM_VISA_LDO. Проверьте там поле NETWR, точно ли они с теми доменами что нужны
СообщениеДобавлено: Вт, фев 08 2011, 15:05
ArmAnn написал:
Valeriy написал:
Это динамически созданная таблица. Но при дампе можно ее просмотреть ну как вы не поймете там нету доменов там тип "P" !
ENDLOOP.
<WA>
1   MANDT   C   3    200
2   BUKRS   C   4    6000
3   BELNR   C   10    0000000002
4   GJAHR   N   4    2011
5   EBELN   C   10    4500161068
6   EBELP   N   5    00010
7   MATNR   C   18    29.51.12.700.0061
8   TXZ01   C   40    Автомат пескострельный  L65
9   MENGE   P   7             1.000
10   MEINS   C   3    ST
11   NETPR   P   7     3302791.46000
12   NETWR   P   7           0.00000
13   PEINH   P   3        0
14   SUMPR   P   7        3302791.46
15   KOSTL   C   10
16   FACTP   P   7             0.000
17   FISTL   C   16
18   FIPEX   C   24    3912012702
19   DISCS   P   13                       0.00000
20   EEIND   D   8    20110106
21   SSNDS   P   7        3302791.46
22   SFNDS   P   7              0.00
23   SFBND   P   7              0.00
QCM8ZFM_VISA_LDO_WA
1   MANDT   C   3    200
2   BUKRS   C   4    6000
4   GJAHR   N   4    2011
6   EBELP   N   5    00010
9   MENGE   P   7             1.000
10   MEINS   C   3    ST
11   NETPR   P   7      1500.0000000
13   PEINH   P   3        0
14   SUMPR   P   7           1500.00
15   KOSTL   C   10    610611-20
16   FACTP   P   7             0.000
17   FISTL   C   16
18   FIPEX   C   24    10814
20   EEIND   D   8    20101222
21   SSNDS   P   7           1800.00
22   SFNDS   P   7              0.00
23   SFBND   P   7              0.00
СообщениеДобавлено: Вт, фев 08 2011, 20:23
Valeriy написал:
блин... при адаптации таблицы в вашем случае происходит примерно следующее:
1. ваша таблица ZFM_VISA_LDO была переименована в QCMZFM_VISA_LDO
2. заново создана таблица ZFM_VISA_LDO, с новой структурой
3. данные из QCMZFM_VISA_LDO копируются в ZFM_VISA_LDO
4. таблица QCMZFM_VISA_LDO дропается
На этапе 3 у вас дамп, поэтому QCMZFM_VISA_LDO пока жива.
Таки попробуйте ее поглядеть в QAS через SE11, может что нибудь и нароется. Обязательно проверьте что элементы данных и домены находятся в активном состоянии и именно такие какие должны быть.
Хотя судя по структуре рабочих областей все нормально, но мало ли...
СообщениеДобавлено: Пт, фев 11 2011, 18:46
Чт, май 11 2006, 12:07
Вчера сталкнулась с такой же проблемой при адаптации САП-таблицы.
Помогло привлечение базиса.
Сказали, что в se14 по кнопке информация показано пошагова что делать.
Созданные Q-таблицы через SE11 не посмотреть :( их можно посмотреть только на уровне СУБД.
Абапер...
Продолжаю удивляться SAPу!
СообщениеДобавлено: Ср, фев 16 2011, 13:18
Valeriy, чем у вас закончилось то? Напишите плиз, если не сложно
