Текущее время: Вс, сен 13 2026, 05:07
 Заголовок сообщения: Динамические источник и приемник
СообщениеДобавлено: Пн, авг 06 2007, 13:06
Пт, авг 04 2006, 20:56
Добрый день, у меня такой вопрос к знающим людя:
Создал динамически внутреннюю таблицу:
FORM f_create_dyn_table .
  PERFORM f_dyn_list USING 'LEDNR'.
  PERFORM f_dyn_list USING 'OBJNR'.
  PERFORM f_dyn_list USING 'GJAHR'.
  PERFORM f_dyn_list USING 'KSTAR'.
  PERFORM f_dyn_list USING 'WRTTP'.
  PERFORM f_dyn_list USING 'HRKFT'.
  PERFORM f_dyn_list USING 'VRGNG'.
  PERFORM f_dyn_list USING 'PARGB'.
  PERFORM f_dyn_list USING 'PAROB'.
  PERFORM f_dyn_list USING 'USPOB'.
  PERFORM f_dyn_list USING 'BEKNZ'.
  PERFORM f_dyn_list USING 'TWAER'.
  PERFORM f_dyn_list USING 'PERBL'.
  PERFORM f_dyn_list USING 'MEINH'.
  PERFORM f_increment USING p_periv p_perib.
  WHILE p_n LE p_k.
    CLEAR: fieldname.
    CASE p_curtp.
      WHEN '10'.
        CONCATENATE 'WOG' p_n INTO fieldname.
        PERFORM f_dyn_list USING fieldname.
      WHEN '30'.
        CONCATENATE 'WKG' p_n INTO fieldname.
    ENDCASE.
    ADD 1 TO p_n.
  ENDWHILE.
  WHILE p_n LE p_k.
    CLEAR: fieldname.
    CONCATENATE 'MEG' p_n INTO fieldname.
    ADD 1 TO p_n.
  ENDWHILE.
  ASSIGN it_data TO <fs_data>.
  CALL METHOD cl_alv_table_create=>create_dynamic_table
      it_fieldcatalog           = it_dyn
    IMPORTING
      ep_table                  = <fs_data>
    EXCEPTIONS
      generate_subpool_dir_full = 1
      OTHERS                    = 2.
  ASSIGN <fs_data>->* TO <dyn_table>.
* Create dynamic work area and assign to FS
  CREATE DATA dy_line LIKE LINE OF <dyn_table>.
  ASSIGN dy_line->* TO <dyn_wa>.
ENDFORM.                    " f_create_dyn_table
Создал динамичски список полей:
FORM f_build_field_list USING value(tabname) TYPE any.
  REFRESH field_list.
  CLEAR field_list.
  PERFORM f_list USING 'LEDNR'."FROM COSS and COSP
  PERFORM f_list USING 'OBJNR'."FROM COSS and COSP
  PERFORM f_list USING 'GJAHR'."FROM COSS and COSP
  PERFORM f_list USING 'KSTAR'."FROM COSS and COSP
  PERFORM f_list USING 'WRTTP'."FROM COSS and COSP
  PERFORM f_list USING 'HRKFT'."FROM COSS and COSP
  PERFORM f_list USING 'VRGNG'."FROM COSS and COSP
  IF tabname = 'COSP'.
    PERFORM f_list USING 'PARGB'."FROM COSS
  ENDIF.
  IF tabname = 'COSS'.
    PERFORM f_list USING 'PAROB'."FROM COSP
    PERFORM f_list USING 'USPOB'."FROM COSP
  ENDIF.
  PERFORM f_list USING 'BEKNZ'."FROM COSS and COSP
  PERFORM f_list USING 'TWAER'."FROM COSS and COSP
  PERFORM f_list USING 'PERBL'."FROM COSS and COSP
  PERFORM f_list USING 'MEINH'."FROM COSS and COSP
  WHILE p_n LE p_k.
    CLEAR: fieldname.
    CASE p_curtp.
      WHEN '10'.
        PERFORM f_list USING fieldname.
      WHEN '30'.
    ENDCASE.
    ADD 1 TO p_n.
  ENDWHILE.
  WHILE p_n LE p_k.
    CLEAR: fieldname.
    ADD 1 TO p_n.
  ENDWHILE.
ENDFORM.                    " f_build_field_list
При выполнении запроса, программа валится в дамп:
FORM f_get_data .
*........build field list from COSP....................................*
  PERFORM f_build_field_list USING 'COSP'.
  SELECT (field_list)
         APPENDING CORRESPONDING FIELDS OF TABLE <dyn_table>         FROM cosp
         FOR ALL ENTRIES IN it_obj
         WHERE objnr = it_obj-objnr
         AND lednr = '00'
         AND gjahr = p_gjahr
         AND wrttp IN ('01', '04')
         AND versn = p_versn
         AND perbl = '016'.
  PERFORM f_build_field_list USING 'COSS'.
  SELECT (field_list)
      FROM coss
        AND lednr = '00'
        AND gjahr = p_gjahr
        AND versn = p_versn
        AND perbl = '016'.
ENDFORM.                    " f_get_data
Пишет ошибку:DBIF_RSQL_INVALID_RSQL
Сразу хочу сказать в field_list находятся только те поля, которые содержатся в БД.
 Заголовок сообщения: Re: Динамические источник и приемник
СообщениеДобавлено: Пн, авг 06 2007, 15:18
Вт, сен 07 2004, 17:47
ROKO написал:
Хочется знать больше подробностей из дампа
СообщениеДобавлено: Пн, авг 06 2007, 15:32
Прошу
Error in the module RSQL accessing the database interface.
Что произошло?
Error in ABAP application program.
The current ABAP program "Z_TEST" had to be terminated because one
of the
statements could not be executed.
This is probably due to an error in the ABAP program.
Что Вы можете сделать?
Print out the error message (using the "Print" function)
and make a note of the actions and input that caused the
error.
To resolve the problem, contact your SAP system administrator.
You can use transaction ST22 (ABAP Dump Analysis) to view and administer
termination messages, especially those beyond their normal deletion
date.
Анализ ошибки
An exception occurred. This exception is dealt with in more detail below
. The exception, which is assigned to the class 'CX_SY_OPEN_SQL_DB', was
neither
caught nor passed along using a RAISING clause, in the procedure "F_GET_DATA"
"(FORM)"
Since the caller of the procedure could not have expected this exception
to occur, the running program was terminated.
The reason for the exception is:
The data read during a SELECT access could not be inserted into the
target field.
Either conversion is not supported for the target field's type or the
target field is too short to accept the value or the data are not in a
form that the target field can accept
СообщениеДобавлено: Пн, авг 06 2007, 15:52
ROKO написал:
Прошу
Отлично, судя по:
target field.
следует внимательно проверить соответствие типов используемых полей.
СообщениеДобавлено: Пн, авг 06 2007, 16:06
ROKO написал:
Прошу
Отлично, судя по:
target field.
Не могу понять при чем здесь типы полей?
Как опеределить типы полей, которые я не знаю до выборки?
СообщениеДобавлено: Пн, авг 06 2007, 16:28
ROKO написал:
Типы при том, что они должны соответствовать: тип поля из таблицы должен соответствовать типу поля во внутренней таблице (с учётом допустимых неявных преобразований) - что и надо учитывать при динамическом формировании таблицы.
СообщениеДобавлено: Пн, авг 06 2007, 17:32
Пт, апр 13 2007, 17:15
sy-uname дело говорит. Огласи код f_dyn_list, а то непонятно как fieldcatalog заполняется, возможно поля в динамической таблице типа char(1) получаются.
СообщениеДобавлено: Пн, авг 06 2007, 17:38
Чт, авг 19 2004, 17:37
Так и было, он уже разобрался. :)
