Текущее время: Пн, сен 14 2026, 23:45
 Заголовок сообщения: выгрузка в фоновом режиме через RFC, кодировка ####
СообщениеДобавлено: Чт, ноя 24 2011, 16:55
Ср, дек 02 2009, 15:40
Задача: необходимо выгрузить данные в фоновом режиме в текстовый файл. Решила попробовать через RFC. Создали RFC, версия librfc32.dll - 7000.0.319.7009.
Вот код: 1 вариант перекодировки
data: F_XTAB LIKE TABLE OF W_BUFFER.
data: F_XLINE LIKE  W_BUFFER occurs 1 with header line.
data: F_SIZE type I.
data: F_VALUE(120).
data: G_STRING type STRING.
data: G_STRING1 type STRING.
data: G_STRING2 type STRING.
data: G_BUFFER type XSTRING.
data: G_BUFFER1 type XSTRING.
data: G_BUFFER2 type XSTRING.
data: GCL_CONV_TO_X type ref to CL_ABAP_CONV_OUT_CE.
loop at P_FINAL.
G_STRING1 = P_FINAL-text1.
*G_STRING2 = P_FINAL-text2.
CONCATENATE G_STRING1 G_STRING2 INTO G_STRING.
call method CL_ABAP_CONV_OUT_CE=>CREATE
  exporting
    ENCODING = '1504'
  receiving
    CONV     = GCL_CONV_TO_X.
call method GCL_CONV_TO_X->WRITE
  exporting
    DATA = G_STRING1.
call method GCL_CONV_TO_X->GET_BUFFER
  receiving
    BUFFER = G_BUFFER1.
call function 'SCMS_XSTRING_TO_BINARY'
  exporting
    BUFFER               = G_BUFFER1
importing
   OUTPUT_LENGTH         = F_SIZE
  tables
    BINARY_TAB           = F_XLINE.
APPEND  F_XLINE to F_XTAB.
endloop.
или
2 вариант перекодировки
DATA:
gcl_conv_to_x TYPE REF TO cl_abap_conv_out_ce,
gcl_conv_to_c TYPE REF TO cl_abap_conv_in_ce.
DATA: in_codepage TYPE cpcodepage.
DATA:
g_buffer TYPE xstring,
l_string TYPE string,
l_string_out TYPE string.
*CALL FUNCTION 'SCP_GET_CODEPAGE_NUMBER'
*EXPORTING
*database_also = P_FINAL
*IMPORTING
*appl_codepage = in_codepage.
CALL METHOD cl_abap_conv_out_ce=>create
encoding = in_codepage
RECEIVING
conv = gcl_conv_to_x.
loop at P_FINAL.
l_string = P_FINAL-text1.
CALL METHOD gcl_conv_to_x->write
data = l_string.
CALL METHOD gcl_conv_to_x->get_buffer
RECEIVING
buffer = g_buffer.
CALL METHOD cl_abap_conv_in_ce=>create
encoding = '1504'
input = g_buffer
RECEIVING
conv = gcl_conv_to_c.
CALL METHOD gcl_conv_to_c->read
IMPORTING
data = l_string_out.
F_XLINE-buffer = l_string_out.
endloop.
заканчивается все :
call function 'RFC_REMOTE_FILE' destination c_dest
exporting
  file = p_readpath
  write = p_flag1
  tables
    filedata = P_FINAL
*    filedata = F_XTAB
  exceptions
      system_failure = 1 message dg_ermsg
      communication_failure = 2 message dg_ermsg.
if sy-subrc <> 0.
  format reset intensified off.
  write: / 'RFC ERROR:'(003), dg_ermsg.
else.
  if dg_flag = c_x.
    write : / 'Data is successfully Uploaded'(004).
  else. dg_flag1 = c_x.
    write : / 'Data is successfully Downloaded'(005).
  endif.
endif.
ни первый вариант, ни второй не помогают, даже если оба варианта закомментировать, то файл выходит один и тот же, пример:
01300;їа-Ым:OOO "±РеХвЫХ-1" ОаШФШзХбЪШЩ РФаХб: 420061, АЮббШп,;АВ, У. єРЧРЭм, гЫ. °Ъ. ігСЪШЭР, 1. ВХЫ. 537-76-00;ёЧУЮвЮТШвХЫм: OOO "±РеХвЫХ-1"
может кто сможет что-нибудь посоветовать.
P.S. RFC настраивала вот по этой ссылке http://www.scribd.com/doc/30284918/Comm ... -1#archive
 Заголовок сообщения: Re: выгрузка в фоновом режиме через RFC, кодировка ####
СообщениеДобавлено: Чт, ноя 24 2011, 17:44
Пт, сен 23 2005, 11:11
а без перекодировки что выводит?
как вариант, можно преобразовывать в utf-8
СообщениеДобавлено: Пт, ноя 25 2011, 09:01
я тут порылась на форуме немного, вот что нашла :
"My computer"->"Properties"->"Advanced"->"Environment Variables"
А там хоть для системы в целом, хоть для юзера - на выбор (по мне лучше для системы) создавай, если она отсутствует.....
"New"
"Variable name" - SAP_CODEPAGE
"Variable value" - 1504
помогло, но теперь есть другая проблема, максимальная длина строки в текстовом файле 256 символов, иначе вываливается дамп...
СообщениеДобавлено: Пт, ноя 25 2011, 09:13
ооо - это классика ;)
забыл даже как с этим боролись в 90-х ;)
на железке был отчётик (МО3 кажется) - так там этих символов!
СообщениеДобавлено: Пт, ноя 25 2011, 09:31
в логах вот такая бяка:
LOCATION SAP-Gateway on host ... / sapgw00
ERROR connection to partner '....local:4151' broken
TIME Fri Nov 25 10:21:11 2011
RELEASE 700
COMPONENT NI (network interface)
VERSION 38
RC -6
MODULE nixxi.cpp
LINE 4193
DETAIL NiIRead
SYSTEM CALL recv
COUNTER 10005
и вышибает rfc подключение : обнаружена ошибка. подключение будет закрыто.
как с этим бороться???
СообщениеДобавлено: Пт, ноя 25 2011, 09:33
Пн, май 12 2008, 09:07
Вернитесь к opendataset
Для экспорта используйте построчную таблицу с одним текстовым полем длиной 4000 символов - у меня это работало.
СообщениеДобавлено: Пт, ноя 25 2011, 09:40
а в фоне разве работает opendataset?
СообщениеДобавлено: Пт, ноя 25 2011, 09:42
Да! Но на апликейшин сервер, или на любую рассшареную на запись папку
(если апликейшин на MS Windows Server)
СообщениеДобавлено: Пт, ноя 25 2011, 10:13
апликейшин сервер у нас не на MS Windows. Неужели эти 255 символов не обойти???
еще нашла вот такое:
Statements that are longer than 255 characters are splitted into
two lines or more than two lines if necessary. Concatenate
splitted statements again by removing the return character.
а с апликейшин сервер по FTP передавать в нужное место?
СообщениеДобавлено: Пт, ноя 25 2011, 10:31
Тогда, в фоне opendataset будет создавать файл именно на апликейшин сервере.
Огромное обсуждение - viewtopic.php?f=13&t=73225
СообщениеДобавлено: Пт, ноя 25 2011, 10:32
спасибо!
СообщениеДобавлено: Пт, ноя 25 2011, 18:04
Чт, авг 19 2004, 17:37
ablinka написал(а):
...Задача: необходимо выгрузить данные в фоновом режиме в текстовый файл...
Это не задача, а вариант решения какой то задачи. Любопытно какой?
СообщениеДобавлено: Пн, ноя 28 2011, 11:19
сделала следующим образом:
табличку с результатом перекодирую:
data: F_XTAB LIKE TABLE OF SDOKCNTBIN.
data: F_XLINE LIKE  SDOKCNTBIN occurs 1 with header line.
loop at TBL_SOSTAV INTO WA_SOSTAV.
G_STRING = WA_SOSTAV.
  exporting
    ENCODING = '1504'
  receiving
  exporting
    DATA = G_STRING.
  receiving
    BUFFER = G_BUFFER.
  exporting
    BUFFER               = G_BUFFER
importing
  tables
endloop.
затем
  CALL FUNCTION 'HTTP_SCRAMBLE'
      SOURCE      = w_pwd
      sourcelen   = slen
      key         = c_key
    IMPORTING
      destination = w_pwd.
* Соединение
  CALL FUNCTION 'FTP_CONNECT'
      user            = w_user
      password        = w_pwd
      host            = host
      rfc_destination = c_dest
    IMPORTING
      handle          = w_hdl.
  IF sy-subrc NE 0.
    sy-subrc = 1.
    EXIT.
  ENDIF.
* Переход к каталогу
  CALL FUNCTION 'FTP_COMMAND'
      handle        = w_hdl
      command       = path
    TABLES
      data          = result
    EXCEPTIONS
      tcpip_error   = 1
      command_error = 2
      data_error    = 3
      OTHERS         = 4.
      handle        = w_hdl
      command       = 'binary'
    TABLES
      data          = result
    EXCEPTIONS
      tcpip_error   = 1
      command_error = 2
      data_error    = 3
      OTHERS         = 4.
* передача по фтп
  CALL FUNCTION 'FTP_R3_TO_SERVER'
      handle = w_hdl
      fname = fname
*      character_mode = 'X'
      blob_length = F_SIZE
    TABLES
*      text = TBL_SOSTAV.
*      text = F_XTAB.
       BLOB = F_XTAB.
не в фоне выгружается все хорошо, если в фоне выгружается только первая строка.
если без перекодировки то выгружается все в '####'.
думала все в одну строку F_XTAB записать, но как поставить символ разрыва строки?
СообщениеДобавлено: Пн, ноя 28 2011, 14:22
пробовала вставлять вот такой код
data: char_crlf value CL_ABAP_CHAR_UTILITIES=>CR_LF.
но в файле все в одну строку с разделителем "квадратик".
СообщениеДобавлено: Пн, ноя 28 2011, 16:34
P.S. система на которой стоит сервер приложений Юниксовая.
