Текущее время: Пт, сен 25 2026, 15:11
 Заголовок сообщения: Проблема с ActiveX
СообщениеДобавлено: Ср, июл 16 2008, 16:39
Ср, июл 16 2008, 15:10
Есть элемент activex.
Глядя на "Using Classic ActiveX Controls in the ABAP Control Framework
Thomas Jung", написан класс.
METHOD constructor.
  DATA prog_id(80).
  IF parent IS INITIAL.
    RAISE error_cntl_create.
  ENDIF.
  CLASS cl_gui_cfw DEFINITION LOAD.
* assign prog_id to get the frontend specific control
  IF NOT activex IS INITIAL.
    prog_id = 'VIIDK.CameraCtrl.1'.
  ELSEIF NOT javabean IS INITIAL.
    RAISE gui_type_not_supported.
  ENDIF.
  IF prog_id IS INITIAL.
  ENDIF.
* Set the window styles of the control when style parameter was not
* set with constructor call.
* For more information on the styles see WIN32 SDK
  IF style IS INITIAL.
* otherwise the control would be invisible and the mistake would be
* hard to find
    style = cl_gui_control=>ws_visible
            + cl_gui_control=>ws_child
            + cl_gui_control=>ws_clipsiblings.
  ENDIF.
* Create the control
  CALL METHOD super->constructor
      clsid = prog_id
      shellstyle = style
      parent = parent
      lifetime = lifetime
      name = name
   EXCEPTIONS
      OTHERS    = 1.
  IF sy-subrc <> 0.
  ENDIF.
* register instance at framework
  CALL METHOD cl_gui_cfw=>subscribe
       shellid = h_control-shellid
       ref = me
    EXCEPTIONS
      OTHERS    = 1.
  IF sy-subrc <> 0.
  ENDIF.
* create and initialize dataprovider =>  m_dp_handle
  CALL FUNCTION 'DP_CREATE'
       CHANGING
            h_dp             = m_dp_handle
       EXCEPTIONS
            dp_create_error  = 1
            dp_install_error = 2
            dp_error         = 3
            OTHERS           = 4.
  IF sy-subrc <> 0.
    RAISE error_dp_create.
  ENDIF.
ENDMETHOD.
method SET_IP .
  call method set_property
         exporting
              property          = 'ip' "#EC NOTEXT
              value             = val    "#EC NOTEXT
         exceptions
              cntl_system_error = 1
              cntl_error        = 2
              others            = 3.
    if sy-subrc <> 0.
              raise error_cntl_call_method.
    endif.
* echo current property of control in attribute (public, read-only) of
* class. Thus calls to get method and eventually necessary flushes can
* be avoided and performance is improved.
    m_ip = val.
endmethod.
method PLAY.
m_par_val = 'play'.
call method call_method
    exporting
      method  = 'Play'
    exceptions
      others  = 1.
  if sy-subrc ne 0.
    raise ERROR_CNTL_CALL_METHOD.
  endif.
endmethod.
Есть программка, которая не работает:
data: container_1 type ref to cl_gui_custom_container,
      cam type ref to ZCL_GUI_CAM.
end-of-selection.
  create object container_1
             exporting
              container_name = 'CONTAINER_1'
  create object cam
    exporting
      parent = container_1
    exceptions
      error_cntl_create      = 1
      error_cntl_init        = 2
      error_cntl_link        = 3
      error_dp_create        = 4
      gui_type_not_supported = 5
      others                 = 6
call screen 5000.
module STATUS_5000 output.
  set pf-status 'S1'.
endmodule.
module USER_COMMAND_5000 input.
  case sy-ucomm.
    when 'BACK'.
      leave to screen 0.
    when 'EXIT'.
      leave program.
    when 'INIT'.
      perform init.
  endcase.
endmodule.
FORM init.
      call method cam->set_ip
        exporting
           val  = '127.0.0.1'
      call method cam->set_port
        exporting
           val  = '900'
      call method cam->set_camid
        exporting
           val  = 1
      call method cam->Play .
      call method cl_gui_cfw=>flush.
endform.
После запуска init при вызове cl_gui_cfw=>flush все текущие режимы и саплогон закрываются и остается процесс saplogon.exe, занимающий 50% цп. Подобное происходит при попытке вызвать любой метод (кроме set_property)) элемента.
Если установить свойства в неверные значения - ошибки нет - ведет себя так, как при неудадачной попытке соединения.
Как быть?
Последний раз редактировалось Igr Чт, июл 17 2008, 16:13, всего редактировалось 1 раз.
СообщениеДобавлено: Чт, июл 17 2008, 12:21
без вариантов?
или все настолько тривиально?
