Текущее время: Пт, сен 25 2026, 11:08
 Заголовок сообщения: MB_MIGO_BADI
СообщениеДобавлено: Сб, мар 21 2009, 09:55
Сб, мар 21 2009, 08:27
Hi Gurus,
I try to use method line/item change, but I cannot find a solution.
Acctually I cannot change the value of cs_goitem and to display it.
Below is my code!
Pls help !
Please have a look on my code !
method IF_EX_MB_MIGO_BADI~LINE_MODIFY.
break skolev.
data: p_groes type mara-groes.
data: p_maktx type makt-maktx.
data: p_all type goitem-maktx.
data: p_len type p.
select single groes into p_groes
from mara
where matnr = cs_goitem-matnr.
select single maktx into p_maktx
from makt
and spras = sy-langu.
concatenate p_maktx p_groes into p_all SEPARATED BY space.
p_len = strlen( p_all ).
cs_goitem-maktx = p_all.
** CALL METHOD cs_GOITEM->HOLD_DATA_SAVE( ).
break skolev.
endmethod.
Regards,
Stefan
Ponomarev Artem: Stefan, use Code tag in future, please. It's pretty easier for reading.
 Заголовок сообщения: Re: MB_MIGO_BADI
СообщениеДобавлено: Сб, мар 21 2009, 10:41
Ср, ноя 03 2004, 14:51
Try use MB_MIGO_ITEM_BADI
СообщениеДобавлено: Сб, мар 21 2009, 13:17
Пт, июн 16 2006, 00:43
If you want to change a position, you can use LINE_MODIFY method as you already done. I don't see any problems. CS_GOITEM is changing parameter.
Hint 1: changed data in CS_GOITEM field is only transfered if the field is visible and ready for input.
Hint 2: try to use method PAI_DETAIL and parameter E_FORCE_CHANGE for LINE_MODIFY calls.
