Текущее время: Пт, сен 25 2026, 03:58
 Заголовок сообщения: Error during update of Table VBUP
СообщениеДобавлено: Пт, июн 05 2009, 11:45
Сб, мар 21 2009, 08:27
Hi,
I did some changes in MV45AFZZ, but when I try to save document using VA02 / after adding new material / I receive an error message as follows:
Update was terminated
System ID.... KR1
Client....... 300
User..... SKOLEV
Transaction.. VA02
Update key... A1A651DE3CFDF1C795720019BBCE4FAA
Generated.... 05.06.2009, 11:03:46
Completed.... 05.06.2009, 11:03:46
Error Info... V2 101: Error during update of Table VBUP
Please help !!!
 Заголовок сообщения: Re: Error during update of Table VBUP
СообщениеДобавлено: Пт, июн 05 2009, 11:54
Вт, сен 07 2004, 17:47
skolev написал(а):
Hi,
System ID.... KR1
Client....... 300
User..... SKOLEV
Transaction.. VA02
Check your "some changes in MV45AFZZ".
И ещё можно посмотреть в тр. ST22
СообщениеДобавлено: Пт, июн 05 2009, 19:25
Пт, апр 28 2006, 22:39
Well, obviously there is a problem with your changes. Pay attention to the field POSNR, usually these things happen when there are duplicate records (i.e. you're trying to create 2 records with the same POSNR). And check ST22, as already suggested. Set a break point right before the update and check what's being updated exactly.
