Текущее время: Ср, авг 19 2026, 07:21
 Заголовок сообщения: удалил системные enhancement points
СообщениеДобавлено: Ср, апр 14 2010, 14:16
Пн, апр 17 2006, 11:03
добрый день.
ковырялся в BAPI BAPI_ROUTING_CREATE.
исходник выглядел так (начало):
FUNCTION bapi_routing_create.
*"*"Lokale Schnittstelle:
*"  IMPORTING
*"     VALUE(TESTRUN) TYPE  BAPIFLAG DEFAULT SPACE
*"     VALUE(PROFILE) LIKE  BAPI1012_CONTROL_DATA-PROFILE OPTIONAL
*"     VALUE(BOMUSAGE) LIKE  BAPI1012_CONTROL_DATA-BOM_USAGE OPTIONAL
*"     VALUE(APPLICATION) LIKE  BAPI1012_CONTROL_DATA-APPLICATION
*"       OPTIONAL
*"  EXPORTING
*"     VALUE(GROUP) TYPE  BAPI1012_TSK_C-TASK_LIST_GROUP
*"     VALUE(GROUPCOUNTER) TYPE  BAPI1012_TSK_C-GROUP_COUNTER
*"  TABLES
*"      TASK STRUCTURE  BAPI1012_TSK_C
*"      MATERIALTASKALLOCATION STRUCTURE  BAPI1012_MTK_C OPTIONAL
*"      SEQUENCE STRUCTURE  BAPI1012_SEQ_C OPTIONAL
*"      OPERATION STRUCTURE  BAPI1012_OPR_C OPTIONAL
*"      SUBOPERATION STRUCTURE  BAPI1012_SUB_OPR_C OPTIONAL
*"      REFERENCEOPERATION STRUCTURE  BAPI1012_REF_OPR_C OPTIONAL
*"      WORKCENTERREFERENCE STRUCTURE  BAPI1012_WC_REF_OPR_C OPTIONAL
*"      COMPONENTALLOCATION STRUCTURE  BAPI1012_COM_C OPTIONAL
*"      PRODUCTIONRESOURCE STRUCTURE  BAPI1012_PRT_C OPTIONAL
*"      INSPCHARACTERISTIC STRUCTURE  BAPI1012_CHA_C OPTIONAL
*"      TEXTALLOCATION STRUCTURE  BAPI1012_TXT_HDR_C OPTIONAL
*"      TEXT STRUCTURE  BAPI1012_TXT_C OPTIONAL
*"      RETURN STRUCTURE  BAPIRET2 OPTIONAL
ENHANCEMENT-POINT BAPI_ROUTING_CREATE_G8 SPOTS ES_SAPLCPCC_BUS1012 STATIC.
*$*$-Start: BAPI_ROUTING_CREATE_G8--------------------------------------------------------------$*$*
ENHANCEMENT 4  MGV_GENERATED_SAPLCPCC_BUS1012.    "active version
DATA: T_MGV_FNAMES1 LIKE MGVBAPIFNAMES OCCURS 0 WITH HEADER LINE.
DATA: T_MGV_FNAMES2 LIKE MGVBAPIFNAMES OCCURS 0 WITH HEADER LINE.
DATA: T_MGV_FNAMES3 LIKE MGVBAPIFNAMES OCCURS 0 WITH HEADER LINE.
ENDENHANCEMENT.
*$*$-End:   BAPI_ROUTING_CREATE_G8--------------------------------------------------------------$*$*
ENHANCEMENT-POINT BAPI_ROUTING_CREATE_G6 SPOTS ES_SAPLCPCC_BUS1012.
*$*$-Start: BAPI_ROUTING_CREATE_G6--------------------------------------------------------------$*$*
ENHANCEMENT 2  MGV_GENERATED_SAPLCPCC_BUS1012.    "active version
*{BAPI Begin} generation http://intranet.sap.com/materialversion
*Do not change coding between begin and end comments. ANI 20050119
T_MGV_FNAMES1-INT = 'MATERIAL'.
T_MGV_FNAMES1-EXT = 'MATERIAL_EXTERNAL'.
T_MGV_FNAMES1-VERS = 'MATERIAL_VERSION'.
T_MGV_FNAMES1-GUID = 'MATERIAL_GUID'.
APPEND T_MGV_FNAMES1.
CALL FUNCTION 'MATNR_BAPI_TABLES_CONVERSION'
  INT_TO_EXTERNAL = ' '
TABLES
  T_FNAMES = T_MGV_FNAMES1
  T_MATNR  = COMPONENTALLOCATION
T_MGV_FNAMES2-INT = 'MATERIAL'.
T_MGV_FNAMES2-EXT = 'MATERIAL_EXTERNAL'.
T_MGV_FNAMES2-VERS = 'MATERIAL_VERSION'.
T_MGV_FNAMES2-GUID = 'MATERIAL_GUID'.
APPEND T_MGV_FNAMES2.
TABLES
  T_FNAMES = T_MGV_FNAMES2
  T_MATNR  = MATERIALTASKALLOCATION
T_MGV_FNAMES3-INT = 'MATERIAL'.
T_MGV_FNAMES3-EXT = 'MATERIAL_EXTERNAL'.
T_MGV_FNAMES3-VERS = 'MATERIAL_VERSION'.
T_MGV_FNAMES3-GUID = 'MATERIAL_GUID'.
APPEND T_MGV_FNAMES3.
TABLES
  T_FNAMES = T_MGV_FNAMES3
  T_MATNR  = PRODUCTIONRESOURCE
*{BAPI End} generation
ENDENHANCEMENT.
как то случайно удалил стандартную реализацию расширений и стало так:
function bapi_routing_create.
*"  IMPORTING
*"       OPTIONAL
*"  EXPORTING
*"  TABLES
enhancement-point bapi_routing_create_g8 spots es_saplcpcc_bus1012 static.
enhancement-point bapi_routing_create_g6 spots es_saplcpcc_bus1012.
как вернуть обратно?)
спасибо
 Заголовок сообщения: Re: удалил системные enhancement points
СообщениеДобавлено: Ср, апр 14 2010, 14:24
Чт, ноя 11 2004, 16:25
Случайно это как? В запрос не просилось?
СообщениеДобавлено: Ср, апр 14 2010, 14:26
Сб, сен 13 2008, 08:50
SE20->Enhancement Spot = es_saplcpcc_bus1012.
Затем меню Утилиты->Версии - находим версию которая необходима и делаем ее активной.
Наверное, как то так :)
СообщениеДобавлено: Ср, апр 14 2010, 14:30
Чт, янв 20 2005, 08:34
В SE37 меню Утилиты-Версии-Управление версиями. Может осталась предыдущая.
СообщениеДобавлено: Ср, апр 14 2010, 14:44
сохранял локально, без запроса.
теперь никак?
в se20 сама реализация существует, и видно что расположена она в BAPI_ROUTING_CREATE, но в se37 не видно реализации.
почему так?
СообщениеДобавлено: Ср, апр 14 2010, 15:06
Вт, июн 09 2009, 15:25
Зайди в se80 -> локальные объекты. Правой клавишей на объект (расширение) -> другие функции -> изменить присвоение пакета.
После присвоения пакета попросит запрос.
И уж после этого вернёшь версию.
СообщениеДобавлено: Ср, апр 14 2010, 15:32
abrukhov написал:
Получится разве? Какую он версию вернет, ту которую ложил в запрос, то есть уже кривую? Если без запроса, то через версии вряд ли получится, если только перед "ковыряние" не создали локальную версию. Могу ошибаться....
СообщениеДобавлено: Ср, апр 14 2010, 15:49
не получилось
в локальные я сохранил Z-реализацию, а при удалении стандартной реализации система ничего не спрашивала.
в se80/локальные объекты видно только Z-реализацию. в итоге восстановить версию не получается.
результат таков:
в se20 видим SPOT ES_SAPLCPCC_BUS1012, в него включена реализация MGV_GENERATED_SAPLCPCC_BUS1012 в активном статусе. Проваливаемся в нее. На последней закладке видим 3 элемента реализации, например \PR:SAPLCPCC_BUS1012\EX:BAPI_ROUTING_CREATE_G8\EI. По кнопке ABAP видим код этого элемента:
Logical Position:    \PR:SAPLCPCC_BUS1012\EX:BAPI_ROUTING_CR
видно что позиция из тела этого функц. модуля.
но фактически в SE37 нет этого кода(
ничего не понимаю
СообщениеДобавлено: Ср, апр 14 2010, 15:58
Пт, сен 23 2005, 11:11
code plug-in-ы хранятс в табл. enhcross, enhincinx,
т.е. проверить версии include-ов в котором лежат enhancement-ы.
м/б это поможет найти (закомментируйте version = 'A'), но сомнительно
* source code plug-in browser (c) trop
report
yenh
no standard page heading
line-size 140.
tables
  : progdir.
data
  : enh         type enhcross
  , enh_t       like table of enh
  , inc         type enhincinx
  , inc_t       like table of inc
  , _
  , id(2)
  , src(255)
  , src_t       like table of src
  , c(255)
select-options
  : ?otype      for enh-otype    no intervals  default 'EI'
  , ?enhna      for enh-enhname
  , ?objty      for enh-obj_type
  , ?objna      for enh-obj_name
parameters
  : !showsrc    as checkbox default ''.
initialization.
start-of-selection.
end-of-selection.
  select *
    from enhcross
    into table enh_t
    where otype     in ?otype
      and enhname   in ?enhna
      and obj_type  in ?objty
      and obj_name  in ?objna
      and version   eq 'A'.
  if lines( enh_t ) = 0.
    message 'Данные не найдены.' type 'S'.
    return.
  endif.
  select *
    from enhincinx
    into table inc_t
    for all entries in enh_t
    where enhname     eq enh_t-enhname
      and version     eq enh_t-version
      and id          eq enh_t-id
      and is_enh      eq ''.
  data: begin of  where
        , type    type char2
        , colon   type c
        , name    type char40
      , end of    where
      , where_t   like table of where
  loop at inc_t   into inc.
    read table enh_t  into enh  with key enhname = inc-enhname  id = inc-id.
    assert sy-subrc eq 0.
    id = inc-id.
    shift id left deleting leading ` 0`.
    concatenate enh-enhmode `/` id  into c.
    write: /(12) c color = 4, (40) inc-enhname color = 4.
      id      = inc-id.
    clear: where, where_t.
    split inc-full_name+1 at '\' into table where_t.
    read table where_t  into where  index 1.
      delete where_t index 1.
      delete where_t where type eq 'EI'.
    case where-type.
      when 'PR'.  write: /(12) 'Program:'.
      when 'FU'.  write: /(12) 'Function:'.
      when 'TY'.  write: /(12) 'Class:'.
    endcase.
    write: (40) where-name.
    loop at where_t into where.
      case where-type.
        when 'FO'.  write: /(12) 'Form:'.
        when 'SE'.  write: /(12) 'Section:'.
        when 'ME'.  write: /(12) 'Method:'.
        when 'IN'.  write: /(12) 'Interface:'.
        when others.
          write: /(12) where-type.
      endcase.
    endloop.
    clear: progdir.
    select single * from progdir where name eq inc-enhinclude and state eq 'A'.
    write: /(12) 'Changed:', progdir-cdat, progdir-cnam.
*    write: / inc-full_name.
    concatenate 'Source/' id ':' into sy-winsl.
    write: /(12) sy-winsl, inc-enhinclude color = 7. " hotspot.
*{  pdtroev show source
    if !showsrc eq 'X'.
      read report inc-enhinclude into src_t.
      loop at src_t into src  where table_line cp 'ENHANCEMENT *.'.
        condense src.
        split src at ` ` into _ src.
        split src at ` ` into src _.
        if src eq id.
          add 1 to sy-tabix.
          loop at src_t into src  from sy-tabix.
            if src cp 'ENDENHANCEMENT*.'.
              exit.
            endif.
            write: / src.
          endloop.
          exit.
        endif.
      endloop.
    endif.
    skip.
  endloop.
at line-selection.
  if sy-lisel cs 'Source/'.
    condense sy-lisel.
    split sy-lisel at ` ` into sy-winsl inc-enhinclude.
      split sy-winsl at '/' into _ id.
      split id at ':' into id _.
      condense id no-gaps.
      condense src.
      if src eq id.
        add 1 to sy-tabix.
            exit.
          endif.
          write: / src.
        endloop.
        exit.
      endif.
    endloop.
  else.
    sy-winx1 = sy-lilli.
    read line sy-lilli line value into c.
*    write: / '[', c, ']'.
    if c cn ' 0'.
      while c+1(1) ne '/'.
        subtract 1 from sy-lilli.
      endwhile.
      if c+1(1) eq '/'.
        condense c.
        split c at ` ` into c src.
        split c at `/` into _ id.
        c = src.
        read table enh_t  into enh  with key enhname = c  id = id.
        if sy-subrc eq 0.
          data: begin of        call
                , iv_pgmid      type e071-pgmid
                , iv_object     type e071-object
                , iv_obj_name   type e071-obj_name
              , end of          call.
          if sy-winx1 eq sy-lilli.
            call-iv_pgmid     = 'R3TR'.
            call-iv_object    = 'ENHO'.
            call-iv_obj_name  = enh-enhname.
          else.
            call-iv_object    = 'PROG'.
            call-iv_obj_name  = enh-include.
          endif.
          call function 'TR_OBJECT_JUMP_TO_TOOL'
               exporting
                    iv_pgmid    = call-iv_pgmid
                    iv_object   = call-iv_object
                    iv_obj_name = call-iv_obj_name
                    iv_action   = 'SHOW'
               exceptions
                    others      = 1.
*          read report enh-include into src_t.
*          loop at src_t into src.
*            write: / src.
*          endloop.
        endif.
      endif.
    endif.
  endif.
* break pdtroev
СообщениеДобавлено: Ср, апр 14 2010, 16:55
к сожалению,
содержимое таблиц одинаково в системе с испорченным модулем и в системе с оригинальным...
СообщениеДобавлено: Ср, апр 14 2010, 17:00
когда куда-то вставляется enhancement, создаётся include программа
которая состоит из блоков вида
ENHANCEMENT 1.
bla-blah
ENDENHANCEMENT.
ENHANCEMENT 2.
bla-blah
ENDENHANCEMENT.
её название сохраняется в табл. enhincinx, вот их код и надо сравнивать в se38..
но если всё сверили и всё совпадает, то возможно нет причин беспокоиться
СообщениеДобавлено: Ср, апр 14 2010, 17:13
текст этих инклюдов тоже совпадает. проверил через READ REPORT.
это также видно и в se20.
исходные тексты модуля в разных системах тоже совпадают - если смотреть через READ REPORT, в коде только строки типа
а вот в самом редакторе SE37 в системе с испорченным видно только строки вида
в отличие от кода в правильной системе, там:
как будто сам редактор не подтягивает текст из инклюдов?
СообщениеДобавлено: Ср, апр 14 2010, 18:49
Чт, мар 11 2010, 18:35
Бывает такое. Попробуйте обновить GUI. Последний патч на 710 вроде 17
Хотя обычно SAP предлагает показывать или нет EnhP
СообщениеДобавлено: Чт, апр 15 2010, 11:54
может быть и такое, иногда пропадают новые параметры в функциях, хотя на деле работают.
попробуйте провалиться в название enhancement-а в утилите,
может там что-то можно сделать
СообщениеДобавлено: Пт, апр 16 2010, 09:45
поставил самый свежий sapgui - без изменений(
