Текущее время: Чт, сен 24 2026, 14:08
 Заголовок сообщения: Как можно переименовать столбцы ALVGrid
СообщениеДобавлено: Вт, май 11 2010, 08:42
Вт, фев 23 2010, 07:26
здравствуйте друзья. У Меня такой вопрос. Есть Внутрненный таблица
DATA: BEGIN OF z_tax OCCURS 0,
  bukrs LIKE ztax200910008a-rbukrs,
  maktx LIKE makt-maktx,
  bldat LIKE ztax200910008a-bldat,
  MSL LIKE ztax200910008a-msl,
  field4(10),
  field6(20),
  TSL LIKE ztax200910008a-TSL,
  field8(20),
  field9(20),
  field10(20),
  end of z_tax.
. как видите там есть поля field4(10),... я так его выгрузил в АЛВ
FORM fill_fieldcat.
  DATA: ls_fc TYPE slis_fieldcat_alv.
  DATA: zrep TYPE sy-repid.
  zrep = sy-repid. REFRESH dit_fc. CLEAR dit_fc.
  CALL FUNCTION 'REUSE_ALV_FIELDCATALOG_MERGE'
      i_program_name         = zrep
      i_internal_tabname     = 'Z_TAX'
      i_inclname             = zrep
    CHANGING
      ct_fieldcat            = dit_fc
    EXCEPTIONS
      inconsistent_interface = 1
      program_error          = 2
      OTHERS                 = 3.
  IF sy-subrc <> 0.
    EXIT.
  ENDIF.
  ls_fc-outputlen = 10.
  MODIFY dit_fc FROM ls_fc TRANSPORTING outputlen WHERE
   fieldname = 'TI_TXT'.
  ls_fc-outputlen = 1.
   fieldname = 'LIFNR'.
   fieldname = 'NAME'.
   fieldname = 'XBLNR'.
   fieldname = 'BUDAT'.
   fieldname = 'BLDAT'.
   fieldname = 'ZUONR'.
   fieldname = 'GUEBG'.
  ls_fc-outputlen = 30.
   fieldname = 'RA_TXT'.
   fieldname = 'SA_TXT'.
ENDFORM.                    "fill_fieldcat
*&      Form  DISPLAY_LIST
FORM display_list.
  DATA:  d_save.
  DATA ls_sort TYPE slis_sortinfo_alv.
  DATA it_sort TYPE slis_t_sortinfo_alv.
  zrep = sy-repid.
*  ls_slis_t_event-name = 'TOP_OF_PAGE'.
*  ls_slis_t_event-form = 'TOP_OF_PAGE'.
*  APPEND ls_slis_t_event TO d_slis_t_event.
*  d_save = 'A'.
*  ls_sort-spos = '1'.
*  ls_sort-fieldname = 'TAXCODE'.
*  ls_sort-subtot = 'X'.
*  ls_sort-up = 'X'.
*  ls_sort-down = space .
*  APPEND ls_sort TO it_sort .
  CALL FUNCTION 'REUSE_ALV_GRID_DISPLAY'
           i_callback_program       = zrep
           i_callback_user_command  = d_user_command_form
           is_layout                = ds_layout
           it_fieldcat              = dit_fc
*           IT_EXCLUDING             =
           i_default                = 'X'
           i_save                   = d_save
           is_variant               = ds_variant
           it_sort                  = it_sort
           it_events                = d_slis_t_event
*           IT_EVENT_EXIT            =
*           is_print                 = ds_print
       TABLES
           t_outtab                 = z_tax
       EXCEPTIONS
           program_error            = 1
           OTHERS                   = 2.
ENDFORM.
как можно эту field4(10) полю переименовать?
 Заголовок сообщения: Re: Как можно переименовать столбцы ALVGrid
СообщениеДобавлено: Вт, май 11 2010, 08:45
результате названия поля field4 пустой но выгружаеть.
СообщениеДобавлено: Вт, май 11 2010, 08:59
Чт, ноя 11 2004, 16:25
Название меняется также как Вы выставляете длину вывода поля, например, также можно через словарь. Смотрите примеры из пакета SLIS, пользуйтесь поиском по форуму или гуглом, почитайте мануал по алв.
СообщениеДобавлено: Вт, май 11 2010, 09:09
Вт, сен 07 2004, 17:47
Баке написал:
здравствуйте друзья. У Меня такой вопрос. Есть Внутрненный таблица ...
Если делать по уму и не заниматься ерундой, то структуру следует делать через словарь, названия и пр. параметры полей определять через элементы данных и домены.
СообщениеДобавлено: Пт, май 14 2010, 22:42
Пт, апр 28 2006, 22:39
+1 Значительно облегчит жизнь и вам, и следующим поколениям.
Тем не менее вы бы хоть в дебагере посмотрели, что у вас в программе происходит. Например, вы делаете такую вещь:
Но в определении таблицы Z_TAX (на основании которой заполняется dit_fc) нет поля TI_TXT. B чем смысл этого кода?
