Текущее время: Ср, сен 23 2026, 18:47
 Заголовок сообщения: Помогите с дампом!
СообщениеДобавлено: Пт, фев 18 2011, 13:59
Чт, дек 16 2010, 14:04
Написал программку которая делает массовый создание заказов и исходящих поставок для розницы. Делалось с использованием двух бапишек: BAPI_SALESORDER_CREATEFROMDAT2 и BAPI_OUTB_DELIVERY_CREATE_SLS, а также немножко bach-input. При обработке небольшого количества записей все было хорошо. Но когда запустил обработку на 5700 записей через какое то время вывылился дамп.
Краткий текст
     Time limit exceeded.
Что произошло?
     The program "SAPLFM23" has exceeded the maximum permitted runtime without
     interruption and has therefore been terminated.
Что Вы можете сделать?
     Note down which actions and inputs caused the error.
     To process the problem further, contact you SAP system
     administrator.
     Using Transaction ST22 for ABAP Dump Analysis, you can look
     at and manage termination messages, and you can also
     keep them for a long time.
Анализ ошибки
     After a specific time, the program is terminated to make the work area
     available to other users who may be waiting.
     This is to prevent a work area being blocked unnecessarily long by, for
     example:
     - Endless loops (DO, WHILE, ...),
     - Database accesses with a large result set
     - Database accesses without a suitable index (full table scan)
     The maximum runtime of a program is limited by the system profile
     parameter "rdisp/max_wprun_time". The current setting is 1800 seconds. If this
      time limit is
     exceeded, the system attempts to cancel any running SQL statement or
     signals the ABAP processor to stop the running program. Then the system
     waits another 60 seconds maximum. If the program is then still active,
     the work process is restarted.
Указания по устранению ошибки
    Programs with long runtime should generally be started as background
    jobs. If this is not possible, you can increase the system profile
    Depending on the cause of the error, you may have to take one of the
    following measures:
    - Endless loop: Correct program;
    - Dataset resulting from database access is too large:
      Instead of "SELECT * ... ENDSELECT", use "SELECT * INTO internal table
      (for example);
    - Database has unsuitable index: Check index generation.
    If the error occures in a non-modified SAP program, you may be able to
    find an interim solution in an SAP Note.
    If you have access to SAP Notes, carry out a search with the following
    keywords:
    "TIME_OUT" " "
    "SAPLFM23" or "LFM23U04"
    "FM23_GET_AVAILABILITY"
    If you cannot solve the problem yourself and want to send an error
    notification to SAP, include the following information:
    1. The description of the current problem (short dump)
       To save the description, choose "System->List->Save->Local File
    (Unconverted)".
    2. Corresponding system log
       Display the system log by calling transaction SM21.
       Restrict the time interval to 10 minutes before and five minutes
    after the short dump. Then choose "System->List->Save->Local File
    (Unconverted)".
    3. If the problem occurs in a problem of your own or a modified SAP
    program: The source code of the program
       In the editor, choose "Utilities->More
    Utilities->Upload/Download->Download".
    4. Details about the conditions under which the error occurred or which
    actions and input led to the error.
Системная среда
    SAP-Release 700
    Application server... "erpdev"
    Network address...... "172.30.2.34"
    Operating system..... "AIX"
    Release.............. "6.1"
    Hardware type........ "0009B4CAD400"
    Character length.... 16 Bits
    Pointer length....... 64 Bits
    Work process number.. 2
    Shortdump setting.... "full"
    Database server... "erpdev"
    Database type..... "DB6"
    Database name..... "TED"
    Database user ID.. "SAPTED"
    Char.set.... "C"
    SAP kernel....... 700
    created (date)... "Aug 12 2010 00:49:07"
    create on........ "AIX 2 5 005DD9CD4C00"
    Database version. "DB6_81 "
    Patch level. 267
    Patch text.. " "
    Database............. "DB6 08.02.*, DB6 09.*"
    SAP database version. 700
    Operating system..... "AIX 1 5, AIX 2 5, AIX 3 5, AIX 1 6, AIX 1 7"
Информация о месте прерывания
    Termination occurred in the ABAP program "SAPLFM23" - in
     "FM23_GET_AVAILABILITY".
    The main program was "ZAZS ".
    In the source code you have the termination point in line 50
    of the (Include) program "LFM23U04".
Фрагмент исходного текста программы
Строк ИсхднТкст
   20 * Check if BCS Budgeting is active
   21   STATICS: sl_ref_bcs_active TYPE REF TO if_ex_fmavc_bcs_active.
   22
   23   IF sl_ref_bcs_active IS INITIAL.
   24     CALL METHOD cl_exithandler=>get_instance
   25       CHANGING
   26         instance = sl_ref_bcs_active.
   27   ENDIF.
   28
   29   IF NOT ( sl_ref_bcs_active IS INITIAL ).
   30
   31     IF I_BCS_GJAHR IS INITIAL.
   32       l_bcs_gjahr = i_gjahr.
   33     ELSE.
   34       l_bcs_gjahr = I_BCS_GJAHR.
   35     ENDIF.
   36
   37     CALL METHOD sl_ref_bcs_active->CHECK_BCS_ACTIVE
   38       EXPORTING
   39         I_FM_AREA        = I_FIKRS
   40         I_FISCYEAR       = l_bcs_gjahr
   41       IMPORTING
   42         E_FLG_BCS_ACTIVE = l_bcs_active.
   43   ENDIF.
   44
   45   SELECT SINGLE *  FROM fm01tol INTO l_f_fm01tol
   46                               WHERE fikrs EQ i_fikrs
   47                                AND  gjahr EQ i_gjahr
   48                                AND  versn EQ '000'.
   49
>>>>>   e_non_ava_check    = l_f_fm01tol-non_ava_check.
   51   e_rev_ava_check    = l_f_fm01tol-rev_ava_check.                   "nb
   52   e_always_ava_check = l_f_fm01tol-always_ava_check.                "bk
   53
   54   IF NOT sy-subrc IS INITIAL.
   55     CLEAR e_non_ava_check.
   56     CLEAR e_rev_ava_check.                                          "nb
   57     CLEAR e_always_ava_check.                                       "bk
   58 * with 4.70: if BCS Budgeting is active, the default value for
   59 * AVC is deactive, there has to be a FM01TOL entry with AVC
   60 * deactive 'OFF' to activate AVC
   61     if not l_bcs_active is initial.
   62       move 'X' to e_non_ava_check.
   63     endif.
   64   ENDIF.
   65
   66 ENDFUNCTION.
Как я понял программа вывалилась в дамп во время создания заказа на розницу. Вывалилась из за долго не ответа системы. Не знаю что делать подскажите пожалуйста. Или хотябы направление в какую сторону капать?
 Заголовок сообщения: Re: Помогите с дампом!
СообщениеДобавлено: Пт, фев 18 2011, 14:13
Вт, июл 07 2009, 13:24
а сколько программа у Вас работает(возможно есть вариант соптимизировать код), как вариант запустите ее как джоб, в фоновом режиме.
СообщениеДобавлено: Пт, фев 18 2011, 14:17
Вывалилась примерно через 20 минут. А можно по точнее про режим и джоб. Я новичок в этих вопросах.
СообщениеДобавлено: Пт, фев 18 2011, 14:53
Теперь точно знаю. вывыливается при бапишке.
    CALL FUNCTION 'BAPI_SALESORDER_CREATEFROMDAT2'
            order_header_in = l_order_header_in
            order_header_inx = l_order_header_inx
*  testrun = 'X'
          IMPORTING
            salesdocument = l_vbeln
          TABLES
            RETURN = li_return
            order_items_in = li_order_items_in
            order_items_inx = li_order_items_inx
            order_conditions_in = li_order_conditions_in
            order_conditions_inx = li_order_conditions_inx
            order_schedules_in = li_order_schedules_in
            order_schedules_inx = li_order_schedules_inx
            order_partners = li_order_partners.
*        APPEND l_vbeln TO provod_dokum.
          CLEAR l_errflag.
Похоже я превышаю количество обрабатываемых позиция у меня их в этом заказе 4865.
