Текущее время: Чт, сен 24 2026, 02:57
 Заголовок сообщения: Проблема с полями.
СообщениеДобавлено: Пн, фев 21 2011, 11:17
Чт, дек 16 2010, 14:04
Здравствуйте.
Программа использует кусочек кода batch-input.
LOOP AT x_tab.
      FREE bdctab.
      CLEAR LGORT2.
      CLEAR CHARG2.
      CLEAR zcharg.
      CLEAR zlgort.
      CLEAR zcharg.
*      SELECT SINGLE * FROM lips  INTO ls_lips WHERE vbeln = lf_vbeln  AND posnr = posnrmod.
      REPLACE FIRST OCCURRENCE OF ',' IN x_tab-z22 WITH '.'.
      REPLACE FIRST OCCURRENCE OF ',' IN x_tab-z29 WITH '.'.
      REPLACE FIRST OCCURRENCE OF ',' IN x_tab-z23 WITH '.'.
      SELECT SINGLE lgort FROM ZAZS  INTO zlgort WHERE AZS = x_tab-z2.
      SELECT SINGLE matnr FROM zprod INTO zmatnr WHERE ZAZSMATRN = x_tab-Z17.
*--------------------------------------------------------------------*это по партиям
      SELECT  SINGLE charg FROM  MCHB INTO zcharg
      WHERE    MATNR  = zmatnr
      AND    WERKS  = '1043'
      AND    LGORT  = zlgort
      AND clabs <> 0
      AND clabs =>  x_tab-z23.
*  CONCATENATE 'LIPS-LGORT (zz)' INTO LGORT2.
      zz = zz + '01'.
      CONCATENATE 'LIPS-LGORT('zz')'INTO LGORT2.
      CONCATENATE 'LIPS-CHARG('zz')'INTO CHARG2.
      CONCATENATE 'LIPS-VOLUM('zz')'INTO VOLUM2.
      CONCATENATE 'LIPS-VOLEH('zz')'INTO VOLEH2.
      CONCATENATE 'LIPS-MATNR('zz')'INTO MATNR2.
      PERFORM:    _dynpro      USING 'SAPMV50A'            '4004',
      _field       USING 'BDC_CURSOR'          'LIKP-VBELN',
      _field       USING 'BDC_OKCODE'          '/00',
      _field       USING 'LIKP-VBELN'          lf_vbeln.
      IF zcharg = ' '.
        codpocik = zz * posnrmod.
        CLEAR:
        zlgort, zcharg.
      ENDIF.
      PERFORM:    _dynpro      USING 'SAPMV50A'           '1000',
      _field       USING VOLUM2               x_tab-z22,
      _field       USING VOLEH2               'Л',
      _field       USING LGORT2               zlgort,
      _field       USING CHARG2               zcharg.
      _field       USING 'BDC_OKCODE'         '/00'.
      _field       USING 'BDC_OKCODE'               '=IDET_T',
      _field       USING 'BDC_CURSOR'            MATNR2.
      PERFORM:    _dynpro      USING 'SAPMV50A' '3000',
      _field       USING 'BDC_OKCODE'                '=T\12'.
      _field       USING 'LIPS-ZZDENSF'          x_tab-z29.
      _field       USING 'BDC_OKCODE'               '=SICH_T'.
      CLEAR opt.
      MOVE: 'A' TO opt-dismode, "'A'
      'L' TO opt-updmode.
      FREE call_mess.
      CALL TRANSACTION 'VL02N' USING bdctab
            OPTIONS FROM opt
            MESSAGES INTO call_mess.
*        MESSAGES INTO lt_itab.
      LOOP AT call_mess WHERE msgtyp = 'E' OR msgtyp = 'A' OR msgtyp = 'S' .
*WRITE call_mess.
      ENDLOOP.
    ENDLOOP.
Вот это поле
Означает что надо заполнить склад в поле с позицией zz.
Все нормально работало до тех пор пока не начал кидать большое колиество позиций. Когда начал смотреть в видимом режиме увидел странную вещь. когда количесто строк доходит до конца экрана. у меня что-то вроде 23-24 то начинается ругань "я это поле типо не знаю" :( . Пробовал записать заполнение ручками для большого кол-ва не смог разобраться они опять начинают с 1 по 24.
Это что получается сменяется экран и опять начинается заполнение заново?
Ладно предположим я смогу ручками прописать экран и смену при достижении кол-ва строк, но не будет ли у каждого пользователя разные экраны?
Подскажите пожалуйста. :cry:
 Заголовок сообщения: Re: Проблема с полями.
СообщениеДобавлено: Пн, фев 21 2011, 11:33
Чт, ноя 11 2004, 16:25
Все правильно. У Вас на экране видно предположим 23 позиции, после их заполнения нужно прокрутить экран, еще на 23 новых позиции.
Чтоб у каждого пользователя был "одинаковый экран", используйте опцию DEFSIZE.
СообщениеДобавлено: Пн, фев 21 2011, 11:59
А не подскажите способ прокрутки экрана?
Это случайно не это?
perform bdc_dynpro using 'SAPMSSY0' '0120'.
perform bdc_field using 'BDC_CURSOR'
'04/03'.
perform bdc_field using 'BDC_OKCODE'
'=P+'.
 Заголовок сообщения: Re: Проблема с полями.  Тема решена
СообщениеДобавлено: Пн, фев 21 2011, 12:02
Да, это код pagedown по-моему. Поищите по форуму, подобные тему много раз поднимались.
СообщениеДобавлено: Пн, фев 21 2011, 12:06
Спасибо!
