Текущее время: Вт, сен 15 2026, 17:10
 Заголовок сообщения: Cross-system SQL trace
СообщениеДобавлено: Пт, май 03 2013, 23:58
Пт, окт 26 2012, 17:39
I am looking for a method to trace all SQL statements, running in the SAP system and updating the database (INSERT, UPDATE, DELETE). Like SQL trace in ST05, but not user-dependent. The purpose is to catch all updates from all users and store these updates in a database within the same SAP instance. I think it would be similar to Oracle ReDo logs techniques, but on SAP transactional level of details.
Are there any SAP standard tools for doing that?
 Заголовок сообщения: Re: Cross-system SQL trace
СообщениеДобавлено: Сб, май 04 2013, 13:32
ST01?
СообщениеДобавлено: Сб, май 04 2013, 23:35
LKU написал:
ST01?
Indeed ST01 allows non-user-specific scan, but I need something less performance consuming, as the screening should be executed permanently on the living production system. In addition I would like to be able to store each SQL statement as a separate piece of information.
I would appreciate any further thoughts!
Спасибо!
СообщениеДобавлено: Чт, май 09 2013, 00:45
Ну как, ребята, есть идеи? Не может-быть чтобы это было неразрешимо!
