Текущее время: Вт, сен 22 2026, 12:12
 Заголовок сообщения: table J_3RFREG_HNDL
СообщениеДобавлено: Чт, дек 05 2013, 18:13
Вт, ноя 09 2010, 19:59
всем доброго времени суток!
пытаюсь выполнить пререквизиты для ноты 1883352 - Invoice Journal: Electronic invoice improvements
подвис на этапе создания даблицы
6. Create table J_3RFREG_HNDL:
Short Description: Automatic CLR handling
In 'Delivery and Maintainance' tab select Delivery class as 'C', 'Data Browser/Table View Maint.' as 'Display/Maintenance Allowed with Restrictions'.
In Fields Tab enter the below Fields:
Field Key Initial Dataelement
MANDT X X MANDT
BUKRS X X BUKRS
SENT_CLR_MODE J_3RF_REGINV_HANDLE
RECV_CLR_MODE J_3RF_RECV_CLR_HNDL
Select field MANDT, create foreign key relatioship with table 'T000'. Choose type "Key fields/candidates" "1:CN".
Select field BUKRS create foreign key relatioship with table 'T001', "Key fields/candidates" "1:CN".
In Technical Settings of the table select 'APPL2' for Data class and '0' for Size Category, Enable check box for 'Buffering activated'. Mark 'Generic Area Buffered' and set 1 for 'Number of Key Fields'.
In 'Extras' select 'Enhancement Category...' in Which Select radio button 'Can be enhanced (Character-type or numeric)'.
Save in J3RF package and activate the Table.
при попытке протестировать таблицу выдается сообщение
   Check table J_3RFREG_HNDL (SELEZNEV/05.12.13/22:09)
   Field SENT_CLR_MODE: Component type or domain used not active or does not exist
   Field name MANDT can be provided in this system. Please do not use.
   Field name BUKRS can be provided in this system. Please do not use.
   Field name SENT_CLR_MODE can be provided in this system. Please do not use.
   Nametab for table J_3RFREG_HNDL cannot be generated
   Check on table J_3RFREG_HNDL resulted in errors
при этом первым пунктом
1. Create domain J_3RF_REGINV_HANDLE:
Short Description: Automatic Handling of Clarifiacation Requests
Data type: CHAR
Length: 2
Value range:
Fix. Val. Short Descr.
Do not set (default)
PR Set for Parent entry
AL Set for All Preceding Entries
Save in J3RF package and activate.
домен создан и активирован
почему не видит домен?
и связано ли это как-то с ситуацией, когда при релизе реквеста ругается на программу,
мол она не активна,
Object REPT J_3RF_REGINV is inactive
а se80 говорит, что программа активна...
что-то с другими BC-компонентами ?
релиз 60608
 Заголовок сообщения: Re: table J_3RFREG_HNDL
СообщениеДобавлено: Чт, дек 05 2013, 23:37
Чт, окт 06 2005, 16:44
1. В таблице указывается не домен, а элемент данных. Его тоже нужно создать.
2. Объект REPT - это текстовые элементы программы. Их тоже нужно активировать (меню Перейти к - Текстовые элементы - Символы текстовых переменных)
Удав.
СообщениеДобавлено: Пт, дек 06 2013, 05:13
Удав, спасибо!
а вот по первому пункту у меня сомнение, может в описании очепятка?
хотели написать про дата элемент, а почему то написали про домен?
потому как при поиске термина J_3RF_REGINV_HANDLE выдает только эту ноту... :(
писать в саппорт?
 Заголовок сообщения: Re: table J_3RFREG_HNDL  Тема решена
СообщениеДобавлено: Пт, дек 06 2013, 09:37
См. п.5 этой ноты
5. Create data element J_3RF_SENT_CLR_HNDL:
Short Description: Automatic Handling of Sent Clarif.Requests
Domain: J_3RF_REGINV_HANDLE
Field Label:
Short: 10 SntReqHndl
Medium: 20 SentRequest_Handling
Long: 40 Automatic Handling of Sent Clarif.Req.
Heading: 15 SentReqHndl
Очевидно, что в ноте ошибка: должно быть написано
MANDT X X MANDT
BUKRS X X BUKRS
SENT_CLR_MODE J_3RF_SENT_CLR_HNDL
Удав.
СообщениеДобавлено: Пт, дек 06 2013, 10:03
судя по следующему пункту в ноте
7. Create view V_J_3RFREG_HNDL:
View type: Maintenance View
Short Description: Automatic Handling of Clarification Requests
Select 'Tables/Join conditions' tab, in 'Tables' column enter the table name J_3RFREG_HNDL.
Go to 'View Fields' tab and enter the fields:
View field Table Field
MANDT J_3RFREG_HNDL MANDT
BUKRS J_3RFREG_HNDL BUKRS
SENT_CLR_MODE J_3RFREG_HNDL SENT_CLR_MODE
RECV_CLR_MODE J_3RFREG_HNDL RECV_CLR_MODE
Save and activate the View.
Удав, похоже действительно должно быть так
Удав, спасибо ещё раз
напишу в саппорт, пусть либо разъясняют свою твердую девичью позицию, либо правят описание в ноте
