Текущее время: Пн, сен 21 2026, 07:44
 Заголовок сообщения: 4PEDH176 Parameter list of append search help "<object name>" differs from appending one
СообщениеДобавлено: Пн, фев 03 2014, 12:06
Вт, ноя 09 2010, 19:59
всем доброго времени суток!
пропачил свою систему разработки с EHP7 SP02 на SP03
в конце процесса вышло предупреждение
File: LONGPOST.LOG
4PEDH176 Parameter list of append search help "ASH_CRAM" differs from appending one
  Long text:
    Cause
      The parameter list of an
       <DS:TX.DDDOK_SHLP_APPEND>append search help</> should always agree with
      the parameter list of its appending objects. This is not the case for
      append search help &V#&. Probably the parameter list of the appending
      object was changed in a previous system and this change was transported.
    System Response
      The append search help functions as in the past.
    What to do
      Go to the maintenance transaction of the ABAP Dictionary to maintain
      search help &V#&. You are recommended to adjust the parameter list to
      the interface of the appending object. Accept this proposal.
      Then check if you want to adjust the assignment of the parameters of
      the append search help to the those of the search helps it includes to
      the new parameter list. In this way you can for example use functional
      enhancements resulting from changing the parameter list of the
      appending objects when using the appended search helps.
    Tasks for system administration
4PEDH176 Parameter list of append search help "COI2O2_CRAM" differs from appending one
  Long text: see above
4PEDH176 Parameter list of append search help "SECURITY_F4_APPEND" differs from appending one
по упомянутым объектам нашел не совсем свежие ноты
IR03: Workcenter field value not copied from search help.
особого отличия не обнаружил между текущим содержимым и информации в нотах
объекты ASH_CRAM COI2O2_CRAM SECURITY_F4_APPEND имеют какую-то особую важность,
чтобы на них обратить пристальное внимание?
