Текущее время: Сб, авг 08 2026, 03:33
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Отваливается апликейшен  Тема решена
СообщениеДобавлено: Вт, июн 20 2006, 14:31
У меня проблема, после запуска системы, через пару секунд останавливается disp+work
вот траса
trc file: "dev_disp", trc level: 1, release: "640"
***LOG Q00=> DpSapEnvInit, DPStart (00 3724) [dpxxdisp.c 1100]
shared lib "dw_xml.dll" version 43 successfully loaded
shared lib "dw_xtc.dll" version 43 successfully loaded
shared lib "dw_stl.dll" version 43 successfully loaded
shared lib "dw_gui.dll" version 43 successfully loaded
Tue Jun 20 16:12:42 2006
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 5 seconds
***LOG GZZ=> 1 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 3886]
MtxInit: -2 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: JAVA is not active
DpShMCreate: sizeof(wp_adm) 6624 (828)
DpShMCreate: sizeof(tm_adm) 2219848 (11044)
DpShMCreate: sizeof(wp_ca_adm) 18000 (60)
DpShMCreate: sizeof(appc_ca_adm) 6000 (60)
DpShMCreate: sizeof(comm_adm) 192000 (384)
DpShMCreate: sizeof(vmc_adm) 0 (320)
DpShMCreate: sizeof(wall_adm) (22440/34344/56/100)
DpShMCreate: SHM_DP_ADM_KEY (addr: 03970040, size: 2505416)
DpShMCreate: allocated sys_adm at 03970040
DpShMCreate: allocated wp_adm at 039717A8
DpShMCreate: allocated tm_adm_list at 03973188
DpShMCreate: allocated tm_adm at 039731B0
DpShMCreate: allocated wp_ca_adm at 03B910F8
DpShMCreate: allocated appc_ca_adm at 03B95748
DpShMCreate: allocated comm_adm_list at 03B96EB8
DpShMCreate: allocated comm_adm at 03B96ED0
DpShMCreate: allocated vmc_adm_list at 03BC5CD0
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated ca_info at 03BC5CF8
DpShMCreate: allocated wall_adm at 03BC5D00
MBUF state OFF
EmInit: MmSetImplementation( 2 ).
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 1024 kByte.
Using implementation flat
<EsNT> Memory Reset disabled as NT default
<ES> 511 blocks reserved for free list.
ES initialized.
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG Q0K=> DpMsAttach, mscon ( sap) [dpxxdisp.c 9736]
CCMS: Initalizing shared memory of size 40000000 for monitoring segment.
CCMS: start to initalize 3.X shared alert area (first segment).
DpMsgAdmin: Set release to 6400, patchlevel 0
MBUF state PREPARED
MBUF component UP
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1025]
DpMsgAdmin: Set patchno for this platform to 43
Release check o.K.
Tue Jun 20 16:13:22 2006
*** ERROR => W0 (pid 4092) died [dpxxdisp.c 12187]
*** ERROR => W1 (pid 144) died [dpxxdisp.c 12187]
my types changed after wp death/restart 0xbf --> 0xbe
*** ERROR => W2 (pid 196) died [dpxxdisp.c 12187]
my types changed after wp death/restart 0xbe --> 0xbc
*** ERROR => W3 (pid 208) died [dpxxdisp.c 12187]
my types changed after wp death/restart 0xbc --> 0xb8
*** ERROR => W4 (pid 216) died [dpxxdisp.c 12187]
*** ERROR => W5 (pid 188) died [dpxxdisp.c 12187]
my types changed after wp death/restart 0xb8 --> 0xb0
*** ERROR => W6 (pid 220) died [dpxxdisp.c 12187]
my types changed after wp death/restart 0xb0 --> 0xa0
*** ERROR => W7 (pid 244) died [dpxxdisp.c 12187]
my types changed after wp death/restart 0xa0 --> 0x80
*** DP_FATAL_ERROR => DpWPCheck: no more work processes
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
killing W0-4092 (SIGUSR2)
*** ERROR => DpWpKill(4092, SIGUSR2) failed [dpxxtool.c 2468]
killing W1-144 (SIGUSR2)
*** ERROR => DpWpKill(144, SIGUSR2) failed [dpxxtool.c 2468]
killing W2-196 (SIGUSR2)
*** ERROR => DpWpKill(196, SIGUSR2) failed [dpxxtool.c 2468]
killing W3-208 (SIGUSR2)
*** ERROR => DpWpKill(208, SIGUSR2) failed [dpxxtool.c 2468]
killing W4-216 (SIGUSR2)
*** ERROR => DpWpKill(216, SIGUSR2) failed [dpxxtool.c 2468]
killing W5-188 (SIGUSR2)
*** ERROR => DpWpKill(188, SIGUSR2) failed [dpxxtool.c 2468]
killing W6-220 (SIGUSR2)
*** ERROR => DpWpKill(220, SIGUSR2) failed [dpxxtool.c 2468]
killing W7-244 (SIGUSR2)
*** ERROR => DpWpKill(244, SIGUSR2) failed [dpxxtool.c 2468]
NiWait: sleep (10000 msecs) ...
NiISelect: timeout 10000 ms
NiISelect: maximum fd=1661
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Tue Jun 20 16:13:32 2006
NiISelect: TIMEOUT occured (10000 ms)
dump system status
Workprocess Table (long) Tue Jun 20 11:13:32 2006
No Ty. Pid Status Cause Start Err Sem CPU Time Program Cl User Action Table
0 DIA 4092 Ended no 1 0 0
1 DIA 144 Ended no 1 0 0
2 UPD 196 Ended no 1 0 0
3 ENQ 208 Ended no 1 0 0
4 BTC 216 Ended no 1 0 0
5 BTC 188 Ended no 1 0 0
6 SPO 220 Ended no 1 0 0
7 UP2 244 Ended no 1 0 0
Dispatcher Queue Statistics Tue Jun 20 11:13:32 2006
| Typ | now | high | max | writes | reads |
| NOWP | 0 | 3 | 2000 | 10 | 10 |
| DIA | 5 | 5 | 2000 | 5 | 0 |
| UPD | 0 | 0 | 2000 | 0 | 0 |
| ENQ | 0 | 0 | 2000 | 0 | 0 |
| BTC | 0 | 0 | 2000 | 0 | 0 |
| SPO | 0 | 0 | 2000 | 0 | 0 |
| UP2 | 0 | 0 | 2000 | 0 | 0 |
max_rq_id 13
wake_evt_udp_now 0
wake events total 9, udp 8 ( 88%), shm 1 ( 11%)
since last update total 9, udp 8 ( 88%), shm 1 ( 11%)
Dump of tm_adm structure: Tue Jun 20 11:13:32 2006
Term uid man user term lastop mod wp ta a/i (modes)
Workprocess Comm. Area Blocks Tue Jun 20 11:13:32 2006
Slots: 300, Used: 1, Max: 0
| id | owner | pid | eyecatcher |
| 0 | DISPATCHER | -1 | *WPCAAD000* |
NiWait: sleep (5000 msecs) ...
NiISelect: timeout 5000 ms
Tue Jun 20 16:13:37 2006
NiISelect: TIMEOUT occured (5000 ms)
Shutdown server ...
DpJ2eeDisableRestart
DpModState: buffer in state MBUF_PREPARED
NiBufSend starting
NiIWrite: write 110, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 110 bytes
MsIModState: change state to SHUTDOWN
DpModState: change server state from STARTING to SHUTDOWN
Switch off Shared memory profiling
ShmProtect( 57, 3 )
ShmProtect(SHM_PROFILE, SHM_PROT_RW
ShmProtect( 57, 1 )
ShmProtect(SHM_PROFILE, SHM_PROT_RD
DpWakeUpWps: wake up all wp's
Stop work processes...
Stop gateway
killing process (4076) (SOFT_KILL)
Stop icman
killing process (4084) (SOFT_KILL)
Terminate gui connections
[DpProcDied] Process lives (PID:4076 HANDLE:1632)
waiting for termination of gateway
NiWait: sleep (1000 msecs) ...
NiISelect: timeout 1000 ms
Tue Jun 20 16:13:38 2006
NiISelect: TIMEOUT occured (1000 ms)
[DpProcDied] Process died (PID:4076 HANDLE:1632)
[DpProcDied] Process died (PID:4084 HANDLE:1624)
DpHalt: cancel all lcom connections
MPI CancelAll 2 -> 0
MPI DeleteAll 2 -> 0
NiIMyHostName: hostname = 'sap'
AdGetSelfIdentRecord: > <
AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0
AdCvtRecToExt: opcode 4 (AD_STARTSTOP), ser 0, ex 0, errno 0
DpConvertRequest: net size = 163 bytes
NiBufSend starting
NiIWrite: write 562, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 562 bytes
send msg (len 110+452) to name -, type 4, key -
detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c 9962]
NiBufSend starting
MsIDetach: send logout to msg_server
MsIDetach: call exit function
DpMsShutdownHook called
NiSelClear: removed hdl 3 from selectset
MBUF state OFF
AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0
blks_in_queue/wp_ca_blk_no/wp_max_no = 1/300/8
LOCK WP ca_blk 1
make DISP owner of wp_ca_blk 1
DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 19)
MBUF component DOWN
NiBufClose: clear extensions for hdl 3
NiBufSetStat: bufstat of hdl 3 changed from OK to OFF
NiICloseHandle: shutdown and close hdl 3 / socket 1640
MsIDetach: detach MS-system
EsCleanup ....
***LOG Q05=> DpHalt, DPStop ( 3724) [dpxxdisp.c 8495]
Good Bye .....
 Заголовок сообщения: Re: Отваливается апликейшен
СообщениеДобавлено: Вт, июн 20 2006, 14:39
вопрос решен - тема закрыта - листенер не был запущен
