Текущее время: Вт, сен 22 2026, 22:27
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Homogeneous copy Web AS 6.40 with restoring from offline backup
СообщениеДобавлено: Ср, июл 05 2006, 17:17
Вт, авг 17 2004, 14:04
Äîáðûé äåíü, êîëëåãè.
Êòî çàíèìàëñÿ óêàçàííûì â òåìå ïðîöåññîì ïîìîãèòå, âîòêíóëñÿ. :)
Åñòü ñèñòåìà SAP BW 3.50 (SAP NetWeaver'04, SAP Web AS 6.40) íà Windows/ORACLE. Ðåøèë ñäåëàòü êîïèðîâàíèå ñèñòåìû èç îôôëàéí áýêàïà, ñîîòâåòñòâåííî ñî ñìåíîé SID è hostname. Ñäåëàë offline backup. Ïîäãîòîâèë ñêðèïò CONTROL.SQL è ORACLE ïðîôàéë íà èñõîäíîé ñèñòåìå. Íà öåëåâîé ïðîèíñòàëëèðîâàë CI, çàòåì çàïóñòèë óñòàíîâêó DB èíñòàíñà, óñòàíîâêà îñòàíîâèëàñü íà ýòàïå - "Âîññòàíîâèòå ORACLE DB". Âîññòàíîâèë. Çàòåì íàæàë - ïðîäîëæèòü. Ñîçäàëèñü êîððåêòíî íîâûå control files. Ïîñëå ýòîãî óñòàíîâêà âñòàëà íà ýòàïå âûïîëíåíèÿ ñêðèïòà oradbusr.sql.
Âûâîä îøèáêè:
connect / as sysdba ;
@@"C:\Program Files\sapinst_instdir\NW04SR1\WEBAS_ABAP_ORA_NUC\DB/oradbusr.sql"
exit;
Output of SQL executing program:
SQL*Plus: Release 9.2.0.6.0 - Production on Wed Jul 5 15:50:33 2006
Copyright (c) 1982, 2002, Oracle Corporation. All rights reserved.
Connected.
Connected.
old 6: if length('&&1') = 5 then
new 6: if length('SAPBWD') = 5 then
old 7: if substr(upper('&&1'),1,5) = 'SAPR3' then
new 7: if substr(upper('SAPBWD'),1,5) = 'SAPR3' then
old 10: if upper('&&2') = 'NT' then
new 10: if upper('NT') = 'NT' then
old 17: :sDomain := upper('&&3');
new 17: :sDomain := upper('sapserv1');
old 18: :sSapSid := upper('&&4');
new 18: :sSapSid := upper('BWD');
old 20: :sSapSid := upper('&&3');
new 20: :sSapSid := upper('sapserv1');
old 36: :sSchema := upper('&&1');
new 36: :sSchema := upper('SAPBWD');
old 37: if upper('&&2') = 'NT' then
new 37: if upper('NT') = 'NT' then
old 44: :sDomain := upper('&&3');
new 44: :sDomain := upper('sapserv1');
old 45: :sSapSid := upper('&&4');
new 45: :sSapSid := upper('BWD');
old 47: :sSapSid := upper('&&3');
new 47: :sSapSid := upper('sapserv1');
using following Parameters:
. Oracle Version: 9.2.0.6.0
. Parametervalue os_authent_prefix: OPS$
. Schema Id: BWD
. Database User (Schema): SAPBWD
. SAP R/3 Administrator: OPS$SAPSERV1\BWDADM
. SAP R/3 Serviceuser: OPS$SAPSERV1\SAPSERVICEBWD
unable to assign default tablespace to user: SAPBWD
begin
ERROR at line 1:
ORA-00959: tablespace 'PSAPBWDUSR' does not exist
ORA-06512: at line 114
Íàøåë íîòêó - 659509, ïðîáîâàë êàê òàì óêàçàíî âûïîëíèòü âûøåóêàçàííûé ñêðèïò ðó÷êàìè - ðåçóëüòàò òîò æå.
Íà äàííûé ìîìåíò áàçà âîññòàíîâëåíà - ðàáîòîñïîñîáíà, òî åñòü ÷åðåç sqlplus ïðèêîííåêòèòüñÿ ìîæíî.
Ïîìîãèòå ðàçîáðàòüñÿ. :?
СообщениеДобавлено: Чт, июл 06 2006, 05:38
Ср, ноя 23 2005, 06:38
Barbarian, какие идентификаторы системы у старой и новой систем?
Как называются старая и новая схемы БД?
В новой системе при установке надо указывать идентификатор старой схемы!
 Заголовок сообщения: Re: Homogeneous copy Web AS 6.40 with restoring from offline backup
СообщениеДобавлено: Чт, июл 06 2006, 06:25
Barbarian написал:
begin
ERROR at line 1:
ORA-06512: at line 114[/i]
В БД нет табличного пространства PSAPBWDUSR.
Как вариант - попробовать создать его руками и повторно запустить oradbusr.sql
СообщениеДобавлено: Чт, июл 06 2006, 09:15
Âèêòîð Á. написал(а):
Barbarian, êàêèå èäåíòèôèêàòîðû ñèñòåìû ó ñòàðîé è íîâîé ñèñòåì?
Êàê íàçûâàþòñÿ ñòàðàÿ è íîâàÿ ñõåìû ÁÄ?
 íîâîé ñèñòåìå ïðè óñòàíîâêå íàäî óêàçûâàòü èäåíòèôèêàòîð ñòàðîé ñõåìû!
Ó íîâîé ñèñòåìû - BWD, ó ñòàðîé - BWR. Ñòàðàÿ ñõåìà ñîîòâåòñòâåííî - SAPBWR.
Âîò ýòî íîâîñòü? Òî åñòü ïðè óñòàíîâêè òîëüêî ñõåìó íàäî óêàçûâàòü ñòàðóþ, à SID è DBSID íîâûå?
СообщениеДобавлено: Чт, июл 06 2006, 09:26
sorc написал(а):
Barbarian написал:
begin
ERROR at line 1:
 ÁÄ íåò òàáëè÷íîãî ïðîñòðàíñòâà PSAPBWDUSR.
Êàê âàðèàíò - ïîïðîáîâàòü ñîçäàòü åãî ðóêàìè è ïîâòîðíî çàïóñòèòü oradbusr.sql
ß òàê ïîíèìàþ ñêðèïò ñàì âñå äîëæåí ñäåëàòü, à òî ñîçäàøü PSAPBWDUSR, ïîòîì îí â íåì íå íàéäåò íóæíîé òàáëè÷êè, ïîòîì åùå êàêîé íèòü òàáëñïåéñ íå íàéäåò è ò.ä. ß òàê ïîíèìàþ sapinst ñàì äîëæåí âñå ïðîäåëàòü.
СообщениеДобавлено: Чт, июл 06 2006, 10:02
В руководстве System Copy SAP Systems Based on WebAS ABAP 6.40 SR1 в разделе Oracle-Specific Procedure указано:
Disadvantages
• You cannot change the database schema and the tablespace names.
Предполагаю, что это к Вашей ситуации тоже относится.
СообщениеДобавлено: Чт, июл 06 2006, 10:03
 ðóêîâîäñòâå System Copy SAP Systems Based on WebAS ABAP 6.40 SR1 â ðàçäåëå Oracle-Specific Procedure óêàçàíî:
Disadvantages
Ïðåäïîëàãàþ, ÷òî ýòî ê Âàøåé ñèòóàöèè òîæå îòíîñèòñÿ.
Ñïàñèáî, ñåé÷àñ åùå ðàç ïîñìîòðåë... òî÷íî... Ëîãèêó íå ïîäêëþ÷èë. :wink:
