Текущее время: Сб, июн 13 2026, 17:22
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: LOCL printing проблема: Обрезание имени принтера!
СообщениеДобавлено: Ср, сен 08 2010, 11:45
Пн, апр 16 2007, 03:05
Привет всем.
Похожая проблемма уже встречается в интернете, но подходящего решения я так и не нашeл:
Вот log SAPLPD:
(09:54:06) Number of processors: 2
(09:54:06) Icon DLL loaded.
(09:54:06)
(09:54:06) Network Communication via SAP-NiLib
(09:54:06) Hostname: XxxxxxxX
(09:54:06) IP Address: 172.XX.XX.XX
(09:54:06) TRACE:  SncInit(): Initializing Secure Network Communication (SNC)
(09:54:06) TRACE:        PC with Windows NT (mt,ascii,SAP_UC/size_t/void* = 8/32/32)
(09:54:06) TRACE:  SncInit(): Reading configuration from 'SAPLPD.INI'.
(09:54:06) TRACE:  SncInit(): Reading configuration from 'WIN.INI'.
(09:54:06)
(09:54:06) SAPLPD Version 6.21 for Windows/NT (OPT) is listening
(09:54:06) OS-Info: version = 5.1, build = 0/2600, text = Service Pack 3
(09:54:06) Copyright © 1992-2001 SAP AG
(09:54:06)
(09:54:16)
(09:54:16) Receive job for printer \\ipp://iprint-kre.xxxxxx.com\DPC-265C-MIS (Berkeley LPD protocol / RFC1179)
(09:54:16) Job 0006NhNR.NEA for user XXXXXXX queued.
(09:54:16) Start printing job 0006NhNR.NEA on printer \\IPP://IPRINT-KRE.XXXXXX.COM\DPC-265C-MIS
(09:54:17) Print-job 0006NhNR.NEA, 1 pages finished.
(09:54:17) Elapsed time 0.438 sec (0.000 sec. used by windows)
(09:54:36)
(09:54:36) Receive job for printer \\ipp://iprint-kre.xxxxxx.com\HP-4100-MI (Berkeley LPD protocol / RFC1179)
(09:54:36) Job 0006Nptx.NEA for user XXXXXXX queued.
(09:54:36) Start printing job 0006Nptx.NEA on printer \\IPP://IPRINT-KRE.XXXXXX.COM\HP-4100-MI
(09:54:43) Error: Cannot create Printer Context, text = The operation completed successfully.
(09:54:43) Error: The printer \\IPP://IPRINT-KRE.XXXXXX.COM\HP-4100-MI is unknown to Windows Print Manager.
(09:54:43) The following printers are currently defined:
(09:54:43) Error: BG: saplpd_open_dc failed, msg = 808 SAPLPD:Windows Problem, siehe SAPLPD Protokoll
На один принтер (перввй job на DPC-265C-MIS) печатает без проблем.
Но вот на второй (HP-4100-MIS) выдает ошибку. И отрезает в имени принтере последнюю букву S, чтоб имя было 40 символов (\\ipp://iprint-kre.xxxxxx.com\HP-4100-MI[s]S[/s]).
! Хотя имя первого принтера \\ipp://iprint-kre.xxxxxx.com\DPC-265C-MIS не обрезается и состоит из 42 символов.
Поэтому решение этой проблемы переименованием принтера на более короткое имя нахожу не верным.
Кто с этим уже встречался или имеет какие-то соображения - прошу совета!
СПАСИБО!
*PS: Конфиденциальную инфу заменил на Х с учётом кол-ва символов.
 Заголовок сообщения: Re: LOCL printing проблема: Обрезание имени принтера!
СообщениеДобавлено: Ср, сен 08 2010, 17:01
Пт, сен 07 2007, 15:58
Попробуйте метод печати G.
СообщениеДобавлено: Пт, сен 10 2010, 10:40
Pepta написал:
Нету G, что это?
Есть только C, E, F, I, L, M, P, S, U, X
Сейчас стоит F (print to front-end-pc).
СообщениеДобавлено: Вс, сен 12 2010, 11:16
Вт, авг 03 2010, 06:32
Alkov написал:
Pepta написал:
Нету G, что это?
G - это усовершенствованный F. Работает без вызова saplpd на клиенте. Появился в версиях 7.х, если мне память не изменяет.
В нем действительно проблем с именами принтеров практически нет.
Если у вас более ранняя версия системы, то другого совета, как уменьшить длину имени принтера придумать сложно.
Есть еще, кстати, ограничение на определенные символы в имени принтера. Но так навскидку не помню, кажется ваши названия в них не попадают, хотя уточнить бы не мешало
Мне и отсюда хорошо видно
СообщениеДобавлено: Пн, сен 13 2010, 11:31
Вт, июл 24 2007, 14:52
судя по логам, у вас WebAS 6.20
в нем метод G появился начиная с некоторого патча на SAP_BASIS
СообщениеДобавлено: Вт, сен 14 2010, 15:58
Вт, ноя 23 2004, 10:40
Почитайте нотку 821519
