Текущее время: Чт, сен 24 2026, 07:03
Начать новую тему Ответить на тему  [ Сообщений: 19 ]  На страницу Пред.  1, 2
 Заголовок сообщения: Re: Пожалуйста помогите!
СообщениеДобавлено: Ср, май 19 2010, 14:15
Andrew Bocha написал(а):
Надо пробовать R3Load с ключом -merge_bck
как это сделать, можно подробнее.
Чувствую себя самым некомпетентным человеком в мире(
Я же ссылку дал на sdn?
СообщениеДобавлено: Ср, май 19 2010, 14:20
Чт, июн 15 2006, 08:41
смущает строчка:
DbSl Trace: ORA-1403 when accessing table SAPUSER
нота: 400241 - Problems with ops$ or sapr3 connect to Oracle
By default, R3trans uses SAPR3 as the database user. However, you can use the environment variable to specify another database user. This makes particular sense with R/3 6.x, if SAPR3 is replaced by SAP<sid>. In R/3 4.x or lower, if dbs_ora_schema is set to a value other than SAPR3, the connection fails since this user does not exist in the database or in the table SAPUSER. As a result, errors such as ORA-01403 or ORA-01017 occur. Up to and including 4.6D, dbs_ora_schema must not be set in any user environment.
Log entries: Logon as OPS$ user to get <sapowner>'s password
Connecting as /@<sid> on connection 0 ...
Now I'm connected to ORACLE
*** ERROR => ORA-1403 when accessing table SAPUSER
The main cause of ORA-01403 is that the table SAPUSER does not contain any entries. Therefore, proceed as follows:
Use the following BRCONNECT call (BRCONNECT 6.10 or higher) to set the password consistently in SAPUSER and in the Oracle DDIC:
brconnect -u system/<password> -f chpass -o <sapowner> -p <password>
Alternatively, you can insert it in SAPUSER manually.
INSERT INTO "OPS$<sid>ADM".SAPUSER VALUES ('<sapowner>', '<password>');
Another possible cause is that SAPUSER contains incorrect entries. The system always uses the user name to select from SAPUSER. Therefore, you must ensure that the user name is always uppercase (SAPR3 or SAP<sid>) and that it corresponds exactly to the value of the environment variable dbs_ora_schema if SAP<sid> is used.
If the system continues to issue ORA-01403, see the "General checks"section once again.
СообщениеДобавлено: Ср, май 19 2010, 14:43
да блин, эта ошибка появляется очень часто как заключительная, даже если у вас не будет поднят листенер, в логе r3trans появится эта ошибка, но пререквизитом к ней будет именно ошибка листенера....
очень редко эта ошибка бывает сама по себе.
я мож конечно скажу нечто кощунственное, но глядя в последнее время на форум, помогать не хочется совершенно.
вопросы из серии - а что такое мышка?
вот откуда спрашивается у человека IDES, который не распространяется SAP-ом за просто так?
если уж скачали, качайте InstGuide
у меня еще куча вопросов возникла после слов - поставил оракл, потом начал ставить инстанцию инсталлятором (не цитата).
а если уж совсем быть дотошным, то с вероятностью 99,9% ответы на именно эти вопросы можно найти:
1. поиск по этому форуму
2. гугл
СообщениеДобавлено: Пн, май 24 2010, 16:39
Пт, сен 21 2007, 12:13
А ХР случаем не Хомячок ? :D Если да то на него не встанет, а на Pro должна
З.Ы. просто нигде не указана какая именно ХР
