Текущее время: Ср, сен 23 2026, 09:09
Начать новую тему Ответить на тему  [ Сообщений: 34 ]  На страницу Пред.  1, 2, 3  След.
 Заголовок сообщения: Re: Удалили пользователей операционной системы
СообщениеДобавлено: Пт, авг 03 2012, 14:44
Чт, фев 16 2006, 15:46
Логи успевает записать.
dev_disp (конец)
NiBufReceive starting
MsINiRead: received 114 bytes
MSG received, len 110+4, flag 3, from MSG_SERVER          , typ 0, key -
Received 4 bytes from MSG_SERVER
Received opcode MS_NOOP from msg_server, reply MSOP_OK
MsOpReceive: ok
MsSendKeepalive : keepalive sent to message server
NiIRead: hdl 2 recv would block (errno=EAGAIN)
Fri Aug 03 15:25:06 2012
NiIPeek: peek for hdl 2 timed out (r; 1000ms)
NiIRead: read for hdl 2 timed out (1000ms)
DpHalt: no more messages from the message server
DpHalt: sync with message server o.k.
detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c   13124]
NiBufSend starting
NiIWrite: hdl 2 sent data (wrt=110,pac=1,MESG_IO)
MsINiWrite: sent 110 bytes
MsIDetach: send logout to msg_server
MsIDetach: call exit function
DpMsShutdownHook called
NiBufISelUpdate: new MODE -- (r-) for hdl 2 in set0
SiSelNSet: set events of sock 916 to: ---
NiBufISelRemove: remove hdl 2 from set0
SiSelNRemove: removed sock 916 (pos=2)
NiSelIRemove: removed hdl 2
MBUF state OFF
AdGetSelfIdentRecord: >        <
AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0
AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0
blks_in_queue/wp_ca_blk_no/wp_max_no = 1/300/17
LOCK WP ca_blk 1
make DISP owner of wp_ca_blk 1
DpSemRq: key: 2, units: 1, timeout: -1
DpSemRel: key: 2, units: 1
DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 15)
MBUF component DOWN
NiICloseHandle: shutdown and close hdl 2 / sock 916
NiBufIClose: clear extension for hdl 2
MsIDetach: detach MS-system
cleanup EM
EsCleanup ....
EmCleanup() -> 0
Es2Cleanup: Cleanup ES2
***LOG Q05=> DpHalt, DPStop ( 2956) [dpxxdisp.c   11298]
Good Bye .....
dev_ms
trc file: "dev_ms", trc level: 1, release: "701"
[Thr 2068] Fri Aug 03 15:23:50 2012
[Thr 2068] MsSSetTrcLog: trc logging active, max size = 20971520 bytes
systemid   562 (PC with Windows NT)
relno      7010
patchlevel 0
patchno    152
intno      20020600
make:      multithreaded, Unicode, 64 bit, optimized
pid        3516
[Thr 2068] ***LOG Q01=> MsSInit, MSStart (Msg Server 1 3516) [msxxserv.c   1853]
[Thr 2068] load acl file = \\BW\sapmnt\DW1\SYS\global\ms_acl_info.DAT
[Thr 2068] MsGetOwnIpAddr: my host addresses are :
[Thr 2068]   1 : [95.128.178.123] BW (HOSTNAME)
[Thr 2068]   2 : [127.0.0.1] validation.sls.microsoft.com (LOCALHOST)
[Thr 2068] MsHttpInit: full qualified hostname = BW
[Thr 2068] HTTP logging is switch off
[Thr 2068] set HTTP state to LISTEN
[Thr 2068] ms/icf_info_server : deleted
[Thr 2068] *** I listen to port sapmsDW1 (3601) ***
[Thr 2068] *** I listen to internal port 3901 (3901) ***
[Thr 2068] *** HTTP port 8101 state LISTEN ***
[Thr 2068] CUSTOMER KEY: >A0083868837<
[Thr 2068] build version=701.2009.12.02
[Thr 2068] Fri Aug 03 15:25:05 2012
[Thr 2068] *** ERROR => MsSClientHandle: no server provides service ENQ  (4), requested from BW_DW1_01 [msxxserv.c   4731]
[Thr 2068] Fri Aug 03 15:35:26 2012
[Thr 2068] *** ERROR => MsSCheckConnections: no response from client C0 (95.128.178.123) after 300 secs received [msxxserv.c   3217]
[Thr 2068] *** ERROR => MsSCheckConnections: disconnect now [95.128.178.123] [msxxserv.c   3221]
Ян Владимирович,
http://www.vladimirovich.net
СообщениеДобавлено: Пт, авг 03 2012, 14:53
а Вы уверены что на этом сервере есть база?
дело в том, что в логах ms, идет поиск сервера, предоставляющего сервисы - ENQ (очереди блокировок).
как правило сие чудо находится в виде параметра в профиле CIBD инстанции.
процесс может работать только на одном сервере.
СообщениеДобавлено: Пт, авг 03 2012, 14:54
Пн, фев 11 2008, 11:38
Как минимум стоит посмотреть профиль с которым стартует инстанция.
+ Запостите dev_w0
СообщениеДобавлено: Пт, авг 03 2012, 14:56
+ Запостите dev_w0
если это не апликуха ;)
СообщениеДобавлено: Пт, авг 03 2012, 15:26
шрам написал:
+ Запостите dev_w0
Ну на данный момент мы знаем не больше топикстартера ))))
СообщениеДобавлено: Пт, авг 03 2012, 16:16
История такова: был сервер BW, песочница. За ним не особо следили. Тут его бац и поломали из интернета. Стерли все учётки с уровня ОС.
На серваке база есть, Оракл, она запускается. Зайти as sysdba можно. К несчастью, я не знаю как проверить консистентность бд. Тейблспейсы по виду саповские, по именам.
Профиль посмотреть могу, но что там искать? Как понять, в чём проблема у процесса блокировок?
Ян Владимирович,
СообщениеДобавлено: Пт, авг 03 2012, 16:20
А, о!
C Fri Aug 03 16:39:04 2012
C  Now '/@SAP' is connected: con=0, nls_hdl=0, session_id=139.
C  *** ERROR => ORA-1403 when accessing table SAPUSER
[dbsloci.c    11781]
C  Disconnecting from connection 0 ...
C  Closing user session (con=0,svchp=000000000799CAD8,usrhp=00000000079AA530)
C  Disconnected (con=0) from ORACLE.
C  Info: 99=DBSL_ERR_DB, oerr=1403, try to connect with default password.
C  Connecting as SAPSR3/<pwd>@SAP on connection 0 (nls 0) ... (dbsl 701 131011, UNICODE[2])
C  Starting user session: OCISessionBegin(con=0, usr=SAPSR3/<pwd>, svchp=000000000799CAD8, srvhp=000000000799D618, usrhp=00000000079AA530)
C     OCISessionBegin(OCI_DEFAULT) failed with SQL error 1017:
C     ORA-01017: invalid username/password; logon denied
C  *** ERROR => CONNECT failed with sql error '1017'
[dbsloci.c    11299]
B  ***LOG BY2=> sql error 1017   performing CON [dbsh#2 @ 1208] [dbsh    1208 ]
B  ***LOG BY0=> ORA-01017: invalid username/password; logon denied [dbsh#2 @ 1208] [dbsh    1208 ]
B  ***LOG BY2=> sql error 1017   performing CON [dblink#4 @ 433] [dblink  0433 ]
B  ***LOG BY0=> ORA-01017: invalid username/password; logon denied [dblink#4 @ 433] [dblink  0433 ]
M  ***LOG R19=> ThInit, db_connect ( DB-Connect 000256) [thxxhead.c   1518]
M  in_ThErrHandle: 1
M  *** ERROR => ThInit: db_connect (step 1, th_errno 13, action 3, level 1) [thxxhead.c   10826]
Короче, оно, кажется, не может законнектится к бд. Походу, нужно менять пароли от SAPSR3, да?
Ян Владимирович,
СообщениеДобавлено: Пт, авг 03 2012, 16:28
попробуйте поиграть с утилитами brtools.exe для начала, там и пароль сменить сможете
затем добейтесь, чтобы корректно отрабатывала команда R3trans.exe -x
потом уже и сап стартует
СообщениеДобавлено: Пт, авг 03 2012, 17:00
Ого, пользователя sapsr3 нет. Похоже, удалили.
Создать не проблема, но вот какие ему дать права?
Ян Владимирович,
СообщениеДобавлено: Пт, авг 03 2012, 17:05
это ерунда:
Note 50088 - Creating OPS$ users on Windows NT/Oracle
к ноте прикреплен sql файл, его запустите с правильными входными данными, они в шапке файла описаны.
и будет пользователь
ну и отсюда тоже примените sql-ку:
Note 134592 - Importing the SAPDBA role (sapdba_role.sql)
СообщениеДобавлено: Пт, авг 03 2012, 17:09
В винду зайдите под SIDADM.
Для начала нужно зайти в oracle под пользователем system. Если пароль не знаете то попробуйте сбить пароль залогинившись под sysdba :
SQL > alter user system identified by your_password;
Далее нужно сбить пароль вашему SAPSR3 :
brconnect -c -u system/your_password -f chpass -o SAPSID(или SAPSR3 , зависит от схемы) -p NEW_PASSWORD
Далее как выше советуют проверьте R3trans -d.
А базу попробуйте проверить так :
brconnect -f check
Последний раз редактировалось SergoB Пт, авг 03 2012, 17:14, всего редактировалось 2 раз(а).
СообщениеДобавлено: Пт, авг 03 2012, 17:10
А какие пользователи есть? Может у вас SID в схеме , а не SR3.
СообщениеДобавлено: Пт, авг 03 2012, 17:44
Да, посмотрел какие есть схемы, это SAP<sid>
А он хочет войти по SAPSR3, ну и ему отказывают.
Гм, а это где-то настраивается?
Ян Владимирович,
СообщениеДобавлено: Вс, авг 05 2012, 08:08
Ну переменные пользователя посмотрите и настройте как надо , правда пользователя SAPserviceSID , вы сходу им и зайти то не сможете в винду ) Ну сначала войдите (поменяйте политики относительно него) потом гляньте set и поменяйте. У SIDadm тоже наверно не все гладко с переменными окружения потренируйтесь на нем )
СообщениеДобавлено: Пн, авг 06 2012, 08:27
Вт, ноя 09 2010, 19:59
select * from dba_users;
