Текущее время: Чт, авг 20 2026, 05:24
Начать новую тему Ответить на тему  [ Сообщений: 70 ]  На страницу Пред.  1, 2, 3, 4, 5  След.
 Заголовок сообщения: Re: Ошибка входа в SAP: SQL error 942
СообщениеДобавлено: Пт, апр 09 2010, 12:00
Пт, ноя 06 2009, 08:29
После некоторых моих монипуляций центральная инстанция перестала стартовать :) вот лог dev_w0:
trc file: "dev_w0", trc level: 1, release: "701"
* ACTIVE TRACE LEVEL 1
* ACTIVE TRACE COMPONENTS all, MJ
B
B Fri Apr 09 15:29:44 2010
B create_con (con_name=R/3)
B Loading DB library 'C:\usr\sap\SSS\DVEBMGS00\exe\dboraslib.dll' ...
B Library 'C:\usr\sap\SSS\DVEBMGS00\exe\dboraslib.dll' loaded
B Version of 'C:\usr\sap\SSS\DVEBMGS00\exe\dboraslib.dll' is "700.08", patchlevel (0.42)
B New connection 0 created
M sysno 00
M sid SSS
M systemid 562 (PC with Windows NT)
M relno 7010
M patchlevel 0
M patchno 55
M intno 20020600
M make: multithreaded, Unicode, 64 bit, optimized
M pid 2504
M
M kernel runs with dp version 242000(ext=110000) (@(#) DPLIB-INT-VERSION-242000-UC)
M length of sys_adm_ext is 576 bytes
M ***LOG Q0Q=> tskh_init, WPStart (Workproc 0 2504) [dpxxdisp.c 1349]
I MtxInit: 30000 0 0
M DpSysAdmExtCreate: ABAP is active
M DpSysAdmExtCreate: VMC (JAVA VM in WP) is not active
M
M Fri Apr 09 15:29:45 2010
M DpShMCreate: sizeof(wp_adm) 29792 (1752)
M DpShMCreate: sizeof(tm_adm) 5912704 (29416)
M DpShMCreate: sizeof(wp_ca_adm) 24064 (80)
M DpShMCreate: sizeof(appc_ca_adm) 8000 (80)
M DpCommTableSize: max/headSize/ftSize/tableSize=500/16/552064/552080
M DpShMCreate: sizeof(comm_adm) 552080 (1088)
M DpSlockTableSize: max/headSize/ftSize/fiSize/tableSize=0/0/0/0/0
M DpShMCreate: sizeof(slock_adm) 0 (104)
M DpFileTableSize: max/headSize/ftSize/tableSize=0/0/0/0
M DpShMCreate: sizeof(file_adm) 0 (72)
M DpShMCreate: sizeof(vmc_adm) 0 (1864)
M DpShMCreate: sizeof(wall_adm) (41664/36752/64/192)
M DpShMCreate: sizeof(gw_adm) 48
M DpShMCreate: SHM_DP_ADM_KEY (addr: 000000000A800050, size: 6614144)
M DpShMCreate: allocated sys_adm at 000000000A800050
M DpShMCreate: allocated wp_adm at 000000000A802270
M DpShMCreate: allocated tm_adm_list at 000000000A8096D0
M DpShMCreate: allocated tm_adm at 000000000A809730
M DpShMCreate: allocated wp_ca_adm at 000000000ADACFB0
M DpShMCreate: allocated appc_ca_adm at 000000000ADB2DB0
M DpShMCreate: allocated comm_adm at 000000000ADB4CF0
M DpShMCreate: system runs without slock table
M DpShMCreate: system runs without file table
M DpShMCreate: allocated vmc_adm_list at 000000000AE3B980
M DpShMCreate: allocated gw_adm at 000000000AE3BA00
M DpShMCreate: system runs without vmc_adm
M DpShMCreate: allocated ca_info at 000000000AE3BA30
M DpShMCreate: allocated wall_adm at 000000000AE3BA40
M rdisp/queue_size_check_value : -> off
M ThTaskStatus: rdisp/reset_online_during_debug 0
X EmInit: MmSetImplementation( 2 ).
X MM global diagnostic options set: 0
X <ES> client 0 initializing ....
X Using implementation view
X <EsNT> Using memory model view.
M <EsNT> Memory Reset disabled as NT default
X ES initialized.
X mm.dump: set maximum dump mem to 96 MB
M ThInit: running on host sapvm
M calling db_connect ...
C Prepending C:\usr\sap\SSS\DVEBMGS00\exe to Path.
C Oracle Client Version: '10.2.0.4.0'
C application info callback registered
C Client NLS setting (OCINlsGetInfo): connection handle 0 -> 'AMERICAN_AMERICA.UTF8'
C Logon as OPS$-user to get SAPSR3's password
C Connecting as /@DB2 on connection 0 (nls_hdl 0) ... (dbsl 701 220409)
C Nls CharacterSet NationalCharSet EnvHp ErrHp ErrHpBatch
C 0 UTF8 000000000447DEB0 0000000004444B60 0000000004486178
C Attaching to DB Server DB2 (con_hdl=0,svchp=0000000004486038,srvhp=00000000044872C8)
C
C Fri Apr 09 15:29:47 2010
C OCIServerAttach(OCI_DEFAULT) failed with SQL error 12541:
C ORA-12541: TNS:no listener
C *** ERROR => CONNECT failed with sql error '12541'
[dbsloci.c 11239]
C Try to connect with default password
C Connecting as SAPSR3/<pwd>@DB2 on connection 0 (nls_hdl 0) ... (dbsl 701 220409)
C Detaching from DB Server (con_hdl=0,svchp=0000000004486038,srvhp=00000000044872C8)
C
C Fri Apr 09 15:29:48 2010
[dbsloci.c 11239]
B ***LOG BY2=> sql error 12541 performing CON [dbsh#2 @ 1208] [dbsh 1208 ]
B ***LOG BY0=> ORA-12541: TNS:no listener [dbsh#2 @ 1208] [dbsh 1208 ]
B ***LOG BY2=> sql error 12541 performing CON [dblink#4 @ 433] [dblink 0433 ]
B ***LOG BY0=> ORA-12541: TNS:no listener [dblink#4 @ 433] [dblink 0433 ]
M ***LOG R19=> ThInit, db_connect ( DB-Connect 000256) [thxxhead.c 1462]
M in_ThErrHandle: 1
M *** ERROR => ThInit: db_connect (step 1, th_errno 13, action 3, level 1) [thxxhead.c 10589]
M
M Info for wp 0
M
M pid = 2504
M severity = 0
M status = 0
M stat = WP_RUN
M waiting_for = NO_WAITING
M reqtype = DP_RQ_DIAWP
M act_reqtype = NO_REQTYPE
M rq_info = 0
M tid = -1
M mode = 255
M len = -1
M rq_id = 65535
M rq_source =
M last_tid = 0
M last_mode = 0
M semaphore = 0
M act_cs_count = 0
M csTrack = 0
M csTrackRwExcl = 0
M csTrackRwShrd = 0
M mode_cleaned_counter = 0
M control_flag = 0
M int_checked_resource(RFC) = 0
M ext_checked_resource(RFC) = 0
M int_checked_resource(HTTP) = 0
M ext_checked_resource(HTTP) = 0
M report = > <
M action = 0
M tab_name = > <
M attachedVm = no VM
M
M *****************************************************************************
M *
M * LOCATION SAP-Server sapvm_SSS_00 on host sapvm (wp 0)
M * ERROR ThInit: db_connect
M *
M * TIME Fri Apr 09 15:29:48 2010
M * RELEASE 701
M * COMPONENT Taskhandler
M * VERSION 1
M * RC 13
M * MODULE thxxhead.c
M * LINE 10854
M * COUNTER 1
M *
M
M PfStatDisconnect: disconnect statistics
M Entering TH_CALLHOOKS
M ThCallHooks: call hook >BtcCallLgCl< for event BEFORE_DUMP
M ThCallHooks: call hook >ThrSaveSPAFields< for event BEFORE_DUMP
M *** ERROR => ThrSaveSPAFields: no valid thr_wpadm [thxxrun1.c 723]
M *** ERROR => ThCallHooks: event handler ThrSaveSPAFields for event BEFORE_DUMP failed [thxxtool3.c 261]
M Entering ThSetStatError
M ThIErrHandle: do not call ThrCoreInfo (no_core_info=0, in_dynp_env=0)
M Entering ThReadDetachMode
M call ThrShutDown (1)...
M ***LOG Q02=> wp_halt, WPStop (Workproc 0 2504) [dpnttool.c 334]
СообщениеДобавлено: Пт, апр 09 2010, 12:02
надо проверить доступность базы с сервера калькулятора :)
СообщениеДобавлено: Пт, апр 09 2010, 12:09
Ср, июн 11 2008, 09:41
Листенер проверьте, стартанул?
SAP Basis, SAP Security Audit/Pentest, РФ, Москва
СообщениеДобавлено: Пт, апр 09 2010, 12:10
Сейчас все перегрузил опять на 15 раз :) инстанция запустилась в логах dev_w0 только вот эти ошибки и SAP Logon не конектится:
*** ERROR => New Process with the same PID (3528, Aktion: 1
[semnt.c 1920]
A ABAP ShmAdm attached (addr=000007FFDED6A000 leng=20955136 end=000007FFE0166000)
A >> Shm MMADM area (addr=000007FFDF212F00 leng=247168 end=000007FFDF24F480)
A >> Shm MMDAT area (addr=000007FFDF250000 leng=15818752 end=000007FFE0166000)
A RFC Destination> destination sapvm_SSS_00 host sapvm system SSS systnr 0 (sapvm_SSS_00)
A RFC Options> H=sapvm,S=00,d=2,
A RFC FRFC> fallback activ but this is not a central instance.
[semnt.c 1920]
СообщениеДобавлено: Пт, апр 09 2010, 12:13
Пн, фев 11 2008, 11:38
Brtools пробовали как я написал? Есть ошибки какие нибудь в Windows Event LOg ?
СообщениеДобавлено: Пт, апр 09 2010, 12:25
BRtools пока запустить не получается у меня на разных машинах стоит БД и инстранция и не хотит поэтому работать сейчас попробую поковырять в эту сторону чтобы запустить. В логах винды ошибок нет
СообщениеДобавлено: Пт, апр 09 2010, 12:27
запостите сейчашный dew_w0 И dev_disp
СообщениеДобавлено: Пт, апр 09 2010, 12:34
Запустил BRTools вот что выдал
BR0801I BRCONNECT 7.00 (42)
BR0280I BRCONNECT time stamp: 2010-04-09 16.24.11
BR0301E SQL error -1031 at location BrInitOraCreate-2, SQL statement:
'CONNECT sapsr3/*********** AT PROF_CONN IN SYSOPER MODE'
ORA-01031: insufficient privileges
BR0303E Determination of Oracle version failed
B
B Fri Apr 09 15:58:24 2010
M sysno 00
M sid SSS
M relno 7010
M patchlevel 0
M patchno 55
M intno 20020600
M pid 3416
M
M ***LOG Q0Q=> tskh_init, WPStart (Workproc 0 3416) [dpxxdisp.c 1349]
M DpShMCreate: SHM_DP_ADM_KEY (addr: 0000000009D20050, size: 6614144)
M DpShMCreate: allocated sys_adm at 0000000009D20050
M DpShMCreate: allocated wp_adm at 0000000009D22270
M DpShMCreate: allocated tm_adm_list at 0000000009D296D0
M DpShMCreate: allocated tm_adm at 0000000009D29730
M DpShMCreate: allocated wp_ca_adm at 000000000A2CCFB0
M DpShMCreate: allocated appc_ca_adm at 000000000A2D2DB0
M DpShMCreate: allocated comm_adm at 000000000A2D4CF0
M DpShMCreate: allocated vmc_adm_list at 000000000A35B980
M DpShMCreate: allocated gw_adm at 000000000A35BA00
M DpShMCreate: allocated ca_info at 000000000A35BA30
M DpShMCreate: allocated wall_adm at 000000000A35BA40
X ES initialized.
C
C Fri Apr 09 15:58:25 2010
C 0 UTF8 00000000038CDEB0 0000000003894B60 00000000038D6178
C Attaching to DB Server DB2 (con_hdl=0,svchp=00000000038D6038,srvhp=00000000038D72C8)
C Starting user session: OCISessionBegin(con_hdl=0, usr='/',svchp=00000000038D6038, srvhp=00000000038D72C8, usrhp=00000000038E41E0)
C
C Fri Apr 09 15:58:26 2010
C CbApplInfoGet() failed (ignored 1).
C
C Fri Apr 09 15:58:27 2010
C Now '/@DB2' is connected: con_hdl=0, nls_hdl=0, session_id=130.
C Got SAPSR3's password from OPS$-user
C Disconnecting from connection 0 ...
C Closing user session (con_hdl=0,svchp=00000000038D6038,usrhp=00000000038E41E0)
C Now I'm disconnected from ORACLE
C Starting user session: OCISessionBegin(con_hdl=0, usr=SAPSR3/<pwd>, svchp=00000000038D6038, srvhp=00000000038D72C8, usrhp=00000000038E41E0)
C Now 'SAPSR3/<pwd>@DB2' is connected: con_hdl=0, nls_hdl=0, session_id=149.
C Database NLS settings: AMERICAN_AMERICA.UTF8
C DB instance DB2 is running on ORAVM with ORACLE version 10.2.0.4.0 since APR 09, 2010, 15:53:22
B Connection 0 opened (DBSL handle 0)
B Wp Hdl ConName ConId ConState TX HC PRM RCT FRC TIM MAX OPT Date Time DBHost
B 000 000 R/3 000000000 ACTIVE NO NO YES NO NO 000 255 255 20100409 155824 ORAVM
C build_stmt: reallocating stmt buffer: 256 -> 2000 characters
M db_connect o.k.
M ICT: exclude compression: *.zip,*.cs,*.rar,*.arj,*.z,*.gz,*.tar,*.lzh,*.cab,*.hqx,*.ace,*.jar,*.ear,*.war,*.css,*.pdf,*.js,*.gzip,*.uue,*.bz2,*.iso,*.sda,*.sar,*.gif,*.png,*.swc,*.swf
I
I Fri Apr 09 15:58:33 2010
I MtxInit: 0 0 0
M SHM_PRES_BUF (addr: 000000000E2A0050, size: 4400000)
M SHM_ROLL_AREA (addr: 000007FED8830050, size: 268435456)
M SHM_PAGING_AREA (addr: 0000000010090050, size: 134217728)
M SHM_ROLL_ADM (addr: 000000000E6E0050, size: 2678942)
M SHM_PAGING_ADM (addr: 0000000003540050, size: 525344)
M ThCreateNoBuffer allocated 544152 bytes for 1000 entries at 0000000003630050
M ThCreateNoBuffer index size: 3000 elems
M ThCreateVBAdm allocated 12176 bytes (50 server) at 00000000033C0050
X ES initialized.
B dbntab: NTAB buffers attached
B dbntab: Buffer FTAB(hash header) (addr: 00000000180A00E0, size: 584)
B dbntab: Buffer FTAB(anchor array) (addr: 00000000180A0330, size: 320072)
B dbntab: Buffer FTAB(item array) (addr: 00000000180EE580, size: 1280000)
B dbntab: Buffer FTAB(data area) (addr: 0000000018226D80, size: 30720000)
B dbntab: Buffer IREC(hash header) (addr: 000000000E9700E0, size: 584)
B dbntab: Buffer IREC(anchor array) (addr: 000000000E970330, size: 320072)
B dbntab: Buffer IREC(item array) (addr: 000000000E9BE580, size: 320000)
B dbntab: Buffer IREC(data area) (addr: 000000000EA0C780, size: 6144000)
B dbntab: Buffer STAB(hash header) (addr: 000000000EFF00E0, size: 584)
B dbntab: Buffer STAB(anchor array) (addr: 000000000EFF0330, size: 320072)
B dbntab: Buffer STAB(item array) (addr: 000000000F03E580, size: 320000)
B dbntab: Buffer STAB(data area) (addr: 000000000F08C780, size: 3072000)
B dbntab: Buffer TTAB(hash header) (addr: 000000000F3800E0, size: 2360)
B dbntab: Buffer TTAB(anchor array) (addr: 000000000F380A20, size: 320072)
B dbntab: Buffer TTAB(item array) (addr: 000000000F3CEC70, size: 800000)
B dbntab: Buffer TTAB(data area) (addr: 000000000F492170, size: 5840000)
B db_con_shm_ini: WP_ID = 0, WP_CNT = 17, CON_ID = -1
B dbstat: TABSTAT buffer attached (addr: 0000000019F8D0B0)
B dbtbxbuf: Buffer TABL (addr: 000000001CA10160, size: 30000000, end: 000000001E6AC4E0)
B dbtbxbuf: Buffer TABLP (addr: 000000001E6B0160, size: 10240000, end: 000000001F074160)
B dbexpbuf: Buffer EIBUF (addr: 000000000FA30170, size: 4194304, end: 000000000FE30170)
B dbexpbuf: Buffer ESM (addr: 000000001F080170, size: 4194304, end: 000000001F480170)
B dbexpbuf: Buffer CUA (addr: 000000001F490170, size: 3072000, end: 000000001F77E170)
B dbexpbuf: Buffer OTR (addr: 000000001F780170, size: 4194304, end: 000000001FB80170)
B dbcalbuf: Buffer CALE (addr: 000000000AFF0050, size: 500000, end: 000000000B06A170)
M CCMS: AlInitGlobals : alert/use_sema_lock = TRUE.
S
S Fri Apr 09 15:58:34 2010
S *** init spool environment
S TSPEVJOB updates inside critical section: event_update_nocsec = 0
S initialize debug system
T Stack direction is downwards.
T debug control: prepare exclude for printer trace
T new memory block 000000001FCDB4F0
S spool kernel/ddic check: Ok
S using table TSP02FX for frontend printing
S 1 spool work process(es) found
S frontend print via spool service enabled
S printer list size is 150
S printer type list size is 50
S queue size (profile) = 300
S hostspool list size = 3000
S option list size is 30
S intervals: query=50, rescan=1800, global=300 info=120
S init processing groups
S InitGroups parm=rdisp/wp_no_spo_Snm_max
S No SPOs are reserved for SNMP
S processing queue enabled
S creating spool memory service RSPO-RCLOCKS at 00000000290F00D0
S doing lock recovery
S setting server cache root
S found spool memory service RSPO-SERVERCACHE at 00000000290F0610
S using messages for server info
B dbtran INFO (init_connection '<DEFAULT>' [ORACLE:700.08]):
B max_blocking_factor = 5, max_in_blocking_factor = 5,
B min_blocking_factor = 5, min_in_blocking_factor = 5,
B prefer_union_all = 0, prefer_join = 0,
B prefer_fix_blocking = 0, prefer_in_itab_opt = 1,
B convert AVG = 0, alias table FUPD = 0,
B escape_as_literal = 1, opt GE LE to BETWEEN = 0,
B select * =0x0f, character encoding = STD / <none>:-,
B use_hints = abap->1, dbif->0x1, upto->2147483647, rule_in->0,
B rule_fae->0, concat_fae->0, concat_fae_or->0
S size of spec char cache entry: 297032 bytes (timeout 100 sec)
S size of open spool request entry: 2512 bytes
S immediate print option for implicitely closed spool requests is disabled
A
A Fri Apr 09 15:58:35 2010
A ***GENER* Trace switched on ***
A
A ---PXA-------------------------------------------
A PXA INITIALIZATION
A PXA: Locked PXA-Semaphore.
A System page size: 4kb, total admin_size: 20832kb, dir_size: 20764kb.
A PXA allocated (address 000007FEE8860050, size 300000K)
A System name
A ORACLE...........................SSS........20091123041157.....................................
A is used for RFC security.
A Sharedbuffer token: 41534050...33 (len: 111)====== 931fbe6dacfdc631c456cf39...
A abap/pxa = shared protect gen_remote
A PXA INITIALIZATION FINISHED
A
I *** ERROR => New Process with the same PID (3528, Aktion: 1
[semnt.c 1920]
A
A RFC rfc/signon_error_log = -1
A RFC rfc/dump_connection_info = 0
A RFC rfc/dump_client_info = 0
A RFC rfc/cp_convert/ignore_error = 1
A RFC rfc/cp_convert/conversion_char = 23
A RFC rfc/wan_compress/threshold = 251
A RFC rfc/recorder_pcs not set, use defaule value: 2
A RFC rfc/delta_trc_level not set, use default value: 0
A RFC rfc/no_uuid_check not set, use default value: 0
A RFC rfc/bc_ignore_thcmaccp_retcode not set, use default value: 0
A RFC Method> initialize RemObjDriver for ABAP Objects
A Hotpackage version: 6
M ThrCreateShObjects allocated 35354 bytes at 00000000033F0050
M ThVBStartUp: restart pending update requests
M
M Fri Apr 09 15:58:36 2010
M ThVBAutoStart: update-auto-delete
N SsfSapSecin: putenv(SECUDIR=C:\usr\sap\SSS\DVEBMGS00\sec): ok
N
N =================================================
N === SSF INITIALIZATION:
N ===...SSF Security Toolkit name SAPSECULIB .
N ===...SSF library is C:\usr\sap\SSS\DVEBMGS00\exe\sapsecu.dll .
N ===...SSF default hash algorithm is SHA1 .
N ===...SSF default symmetric encryption algorithm is DES-CBC .
N ===...SECUDIR="C:\usr\sap\SSS\DVEBMGS00\sec"
N ===...loading of Security Toolkit successfully completed.
N === SAPSECULIB Version 5.4.28M-6
N
N Fri Apr 09 15:58:38 2010
N MskiInitLogonTicketCacheHandle: Logon Ticket cache pointer retrieved from shared memory.
N MskiInitLogonTicketCacheHandle: Workprocess runs with Logon Ticket cache.
M JrfcVmcRegisterNativesDriver o.k.
W =================================================
W === ipl_Init() called
W ITS Plugin: Path dw_gui
W ITS Plugin: Description ITS Plugin - ITS rendering DLL
W ITS Plugin: sizeof(SAP_UC) 2
W ITS Plugin: Release: 701, [7010.0.55.20020600]
W ITS Plugin: Int.version, [33]
W ITS Plugin: Feature set: [20]
W ===... Calling itsp_Init in external dll ===>
W === ipl_Init() returns 0, ITSPE_OK: OK
N VSI: WP init in ABAP VM completed with rc=0
E Profile-Parameter: enque/deque_wait_answer = FALSE
E Replication is disabled
E EnqCcInitialize: local lock table initialization o.k.
E EnqId_SuppressIpc: local EnqId initialization o.k.
E EnqCcInitialize: local enqueue client init o.k.
M
M Fri Apr 09 15:58:43 2010
M SosICreateNewAnchorArray: sos_search_anchor_semantics = 1
C
C Fri Apr 09 15:59:27 2010
C OCIStmtExecute() failed with -1=OCI_ERROR
C SQL error 942:
B ***LOG BY4=> sql error 942 performing SEL on table REPOLOAD [dbrepo#2 @ 2657] [dbrepo 2657 ]
B ***LOG BY0=> ORA-00942: table or view does not exist [dbrepo#2 @ 2657] [dbrepo 2657 ]
A TH VERBOSE LEVEL FULL
A ** RABAX: level LEV_RX_PXA_RELEASE_MTX entered.
A ** RABAX: level LEV_RX_PXA_RELEASE_MTX completed.
A ** RABAX: level LEV_RX_COVERAGE_ANALYSER entered.
A ** RABAX: level LEV_RX_COVERAGE_ANALYSER completed.
A ** RABAX: level LEV_RX_SAVE_SHMLOCKS entered.
A ** RABAX: level LEV_RX_SAVE_SHMLOCKS completed.
A ** RABAX: level LEV_RX_RESET_SHMLOCKS entered.
A ** RABAX: level LEV_RX_RESET_SHMLOCKS completed.
A ** RABAX: level LEV_RX_ROLLBACK entered.
A ** RABAX: level LEV_RX_ROLLBACK completed.
A ** RABAX: level LEV_RX_DB_ALIVE entered.
A ** RABAX: level LEV_RX_DB_ALIVE completed.
A ** RABAX: level LEV_RX_HOOKS entered.
A ** RABAX: level LEV_RX_HOOKS completed.
A ** RABAX: level LEV_RX_STANDARD entered.
A ** RABAX: level LEV_RX_STANDARD completed.
A ** RABAX: level LEV_RX_STOR_VALUES entered.
A ** RABAX: level LEV_RX_STOR_VALUES completed.
A ** RABAX: level LEV_RX_C_STACK entered.
A
A Fri Apr 09 15:59:28 2010
A ** RABAX: level LEV_RX_C_STACK completed.
A ** RABAX: level LEV_RX_MEMO_CHECK entered.
A ** RABAX: level LEV_RX_MEMO_CHECK completed.
A ** RABAX: level LEV_RX_AFTER_MEMO_CHECK entered.
A ** RABAX: level LEV_RX_AFTER_MEMO_CHECK completed.
A ** RABAX: level LEV_RX_INTERFACES entered.
A ** RABAX: level LEV_RX_INTERFACES completed.
A ** RABAX: level LEV_RX_GET_MESS entered.
A ** RABAX: level LEV_RX_GET_MESS completed.
A ** RABAX: level LEV_RX_INIT_SNAP entered.
A ** RABAX: level LEV_RX_INIT_SNAP completed.
A ** RABAX: level LEV_RX_WRITE_SYSLOG entered.
A ** RABAX: level LEV_RX_WRITE_SYSLOG completed.
A ** RABAX: level LEV_RX_WRITE_SNAP_BEG entered.
A ** RABAX: level LEV_RX_WRITE_SNAP_BEG completed.
A ** RABAX: level LEV_RX_WRITE_SNAP entered.
A ** RABAX: level LEV_SN_END completed.
A ** RABAX: level LEV_RX_WRITE_SNAP_END entered.
A ** RABAX: level LEV_RX_WRITE_SNAP_END completed.
A ** RABAX: level LEV_RX_SET_ALERT entered.
A ** RABAX: level LEV_RX_SET_ALERT completed.
A ** RABAX: level LEV_RX_COMMIT entered.
A ** RABAX: level LEV_RX_COMMIT completed.
A ** RABAX: level LEV_RX_SNAP_SYSLOG entered.
A ** RABAX: level LEV_RX_SNAP_SYSLOG completed.
A ** RABAX: level LEV_RX_RESET_PROGS entered.
A ** RABAX: level LEV_RX_RESET_PROGS completed.
A ** RABAX: level LEV_RX_STDERR entered.
A
A ABAP Program ????????????????????????????????????????.
A Source Line 0.
A Error Code DBIF_REPO_SQL_ERROR.
A Module $Id: //bas/701_REL/src/krn/runt/abload5.c#2 $ SAP.
A Function db_info Line 252.
A ** RABAX: level LEV_RX_STDERR completed.
A ** RABAX: level LEV_RX_RFC_ERROR entered.
A ** RABAX: level LEV_RX_RFC_ERROR completed.
A ** RABAX: level LEV_RX_RFC_CLOSE entered.
A ** RABAX: level LEV_RX_RFC_CLOSE completed.
A ** RABAX: level LEV_RX_IMC_ERROR entered.
A ** RABAX: level LEV_RX_IMC_ERROR completed.
A ** RABAX: level LEV_RX_DATASET_CLOSE entered.
A ** RABAX: level LEV_RX_DATASET_CLOSE completed.
A ** RABAX: level LEV_RX_ERROR_SAVE entered.
A ** RABAX: level LEV_RX_ERROR_SAVE completed.
A ** RABAX: level LEV_RX_ERROR_TPDA entered.
A ** RABAX: level LEV_RX_ERROR_TPDA completed.
A ** RABAX: level LEV_RX_PXA_RELEASE_RUDI entered.
A ** RABAX: level LEV_RX_PXA_RELEASE_RUDI completed.
A ** RABAX: level LEV_RX_LIVE_CACHE_CLEANUP entered.
A ** RABAX: level LEV_RX_LIVE_CACHE_CLEANUP completed.
A ** RABAX: level LEV_RX_END entered.
A ** RABAX: level LEV_RX_END completed.
A ** RABAX: end no http/smtp
A ** RABAX: end RX_GOTO_RABAX
A SQL error 942 occurred when accessing program SAPMSYST part LOAD..
A
C SQL error 942:
A
A Fri Apr 09 15:59:29 2010
A
A Source Line 0.
A ** RABAX: end RX_GOTO_SAPDEXT
A SQL error 942 occurred when accessing program SAPMS380 part LOAD..
A
C SQL error 942:
B ***LOG BZA=> table T100 does not exist on database [dbtrtab#2 @ 3893] [dbtrtab 3893 ]
C SQL error 942:
C SQL error 942:
C SQL error 942:
C SQL error 942:
C SQL error 942:
M ***LOG R47=> ThResFree, delete (001024) [thxxmode.c 1384]
C
C Fri Apr 09 16:00:28 2010
C SQL error 942:
A Fri Apr 09 16:00:28 2010
A
A Source Line 0.
M *** WARNING => PfStatWrite: missing STAT_END for opcode STAT_REPLOAD [pfxxstat.c 4131]
DEV_DISP
trc file: "dev_disp", trc level: 1, release: "701"
sysno 00
sid SSS
relno 7010
patchlevel 0
patchno 55
intno 20020600
pid 2460
Fri Apr 09 15:57:54 2010
*** SWITCH TRC-HIDE on ***
***LOG Q00=> DpSapEnvInit, DPStart (00 2460) [dpxxdisp.c 1287]
shared lib "dw_xml.dll" version 55 successfully loaded
shared lib "dw_xtc.dll" version 55 successfully loaded
shared lib "dw_stl.dll" version 55 successfully loaded
shared lib "dw_gui.dll" version 55 successfully loaded
shared lib "dw_mdm.dll" version 55 successfully loaded
rdisp/softcancel_sequence : -> 0,5,-1
use internal message server connection to port 3900
Fri Apr 09 15:58:06 2010
*** WARNING => DpNetCheck: NiHostToAddr(www.doesnotexist0230.qqq.nxst) took 12 seconds
Fri Apr 09 15:58:23 2010
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 17 seconds
***LOG GZZ=> 2 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 5532]
MtxInit: 30000 0 0
DpSysAdmExtInit: ABAP is active
DpSysAdmExtInit: VMC (JAVA VM in WP) is not active
DpIPCInit2: start server >sapvm_SSS_00 <
DpShMCreate: SHM_DP_ADM_KEY (addr: 0000000007E00050, size: 6614144)
DpShMCreate: allocated sys_adm at 0000000007E00050
DpShMCreate: allocated wp_adm at 0000000007E02270
DpShMCreate: allocated tm_adm_list at 0000000007E096D0
DpShMCreate: allocated tm_adm at 0000000007E09730
DpShMCreate: allocated wp_ca_adm at 00000000083ACFB0
DpShMCreate: allocated appc_ca_adm at 00000000083B2DB0
DpShMCreate: allocated comm_adm at 00000000083B4CF0
DpShMCreate: allocated vmc_adm_list at 000000000843B980
DpShMCreate: allocated gw_adm at 000000000843BA00
DpShMCreate: allocated ca_info at 000000000843BA30
DpShMCreate: allocated wall_adm at 000000000843BA40
MBUF state OFF
DpCommInitTable: init table for 500 entries
<ES> InitFreeList
<ES> block size is 4096 kByte.
<ES> Info: em/initial_size_MB( 12286MB) not multiple of em/blocksize_KB( 4096KB)
<ES> Info: em/initial_size_MB rounded up to 12288MB
<ES> 3071 blocks reserved for free list.
ES initialized.
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG CPS=> DpLoopInit, ICU ( 3.0 3.0 4.0.1) [dpxxdisp.c 1682]
***LOG Q0K=> DpMsAttach, mscon ( sapvm) [dpxxdisp.c 12560]
DpStartStopMsg: send start message (myname is >sapvm_SSS_00 <)
DpStartStopMsg: start msg sent
CCMS: Initalizing shared memory of size 60000000 for monitoring segment.
CCMS: Checking Downtime Configuration of Monitoring Segment.
CCMS: start to initalize 3.X shared alert area (first segment).
DpMsgAdmin: Set release to 7010, patchlevel 0
MBUF state PREPARED
MBUF component UP
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1048]
DpMsgAdmin: Set patchno for this platform to 55
Release check o.K.
Fri Apr 09 15:58:37 2010
MBUF state ACTIVE
DpModState: change server state from STARTING to ACTIVE
СообщениеДобавлено: Пт, апр 09 2010, 12:41
Про это я и говорил, слетели привилегии.
СообщениеДобавлено: Пт, апр 09 2010, 12:42
Note 400241 - Problems with ops$ or sapr3 connect to Oracle
Note 50088 - Creating OPS$ users on Windows NT/Oracle
согласен, стоит проверить всю цепочку авторизации
кстати, ядро для windows последнее - 69е
СообщениеДобавлено: Пт, апр 09 2010, 12:47
Это всё ерунда, в том же инст гуиде написано про то что нужно заново выполнить sapdba_role.sql заново ....
Ваша проблема намного серьёзнее, надеюсь что это тестовая система?
Вы лог не до конца читаете -->
C SQL error 942:
Вы GUi-ём точно к нужной инстанции коннектитесь а не к шадоу? Если да то конкретно напишите что и как вы удалили ....
СообщениеДобавлено: Пт, апр 09 2010, 12:48
idle> conn sapsr3/<password>@<sid>
Connected.
sapsr3@SID> select user from dual;
USER
SAPSR3
СообщениеДобавлено: Пт, апр 09 2010, 12:57
SAPSR3 T100 TABLE PSAPSR3701 134217728
Если коннект в ту инстанцию, то непонятно, что грохнулось, ибо этот тбс как раз жив.
SELECT    OWNER,
    SEGMENT_NAME,
    SEGMENT_TYPE,
    TABLESPACE_NAME,
    BYTES
FROM     dba_segments
WHERE    OWNER =('SAPSR3')
AND segment_name LIKE 'T100'
СообщениеДобавлено: Пт, апр 09 2010, 12:59
ZeUsM написал:
Connected.
USER
SAPSR3
аналогичный вывод
СообщениеДобавлено: Пт, апр 09 2010, 13:01
SELECT * FROM dba_objects
WHERE object_name LIKE 'T100'
AND owner = 'SAPSR3'
AND object_type IN ('TABLE', 'VIEW')
Там же убедитесь что на уровне БД у вас все впорядке, и тогда смотрите GUI, может действительно не в ту систему коннект идет?
