Текущее время: Ср, сен 23 2026, 03:36
 Заголовок сообщения: компонент ST-PI
СообщениеДобавлено: Пн, дек 05 2005, 09:46
Вт, сен 21 2004, 10:05
Всем привет.
Подскажите кто знает, что содержит (для чего предназначен) компонент ST-PI.
Где, чего про него написано (желательно ссылку).
СообщениеДобавлено: Пн, дек 05 2005, 09:59
Вт, авг 17 2004, 08:17
Solution Tools Plug-In (ST-PI)
Easy and Continuous improvement for your business solution
The add-on Solution Tools Plug-In (ST-PI) provides Basis and Trace Tools, which are required for service delivery and system monitoring.
The Solution Tools Plug-In contains the latest version of:
* Function modules for data collection
* Transaction SDCCN (Service Data Control Center)¹
* Transaction SQLR (SQL Trace Interpreter)¹
¹ SDCCN and SQLR are included in ST-PI for releases 4.0B - 4.6D. For release SAP Web AS 6.10 and higher the transactions are included in the SAP Basis. Changes are shipped by basis support packages.
Spotlight
* As of November 11, 2005 Support Package 03 for ST-PI 2005_1 is available.
It provides all corrections for ST-PI 2005_1 SP02 and some new functions.
* Install ST-PI 2005_1 with Support Package 03 (ST-PI 2005_1 SP03) on all SAP systems in your system landscape including the SAP Solution Manager.
* ST-PI 2005_1 requires a low Basis Support Package Level, therefore an installation should be possible on most systems. See SAP Note 769623 for further information.
General Download Information
The download file for the Solution Tools Plug-In Add-On and the Support Package can be downloaded by release in the current folder.
Implementation
Follow the installation instructions in SAP Note 769623. The Solution Tools Plug-In is imported using the SAP Add-On Installation Tool (transaction SAINT). The Support Package is imported using the Support Package Manager (transaction SPAM).
The Solution Tools Plug-In must be installed on all SAP systems in your system landscape including the SAP Solution Managerr
Please note that in the case of SAP R/3 3.0D, 3.0F, 3.1G, 3.1H, and 3.1I, the solution tools are still available as a transport and not as an add-on.
Relevant SAP Notes
The following SAP Notes describe the implementation steps of the Solution Tools Plug-In and the general requirements for SAP Standard Support.
SAP Note 539977 Release Strategy for Solution Tools Plug-In
SAP Note 769623 Installation/Delta-Upgrade ST-PI 2005_1
SAP Note 769519 Upgrade mit ST-PI 2005_1 (Solution Tools Plug-In)
SAP Note 560475 Frequent questions on the Solution Tool Plug-In
SAP Note 116095 Solution Tools Plug-In
SAP Note 091488 SAP Support Services: Central preparation note
Support
Refer to the SAP Notes above and to section Known problems and solutions - ST-PI, which cover the most common questions.
If you require further help, create a customer message on component SV-SMG-SDD and include ST-PI in the beginning of the short text. Use component BC-UPG-ADDON for installation issues.
ST-PI 003C_40B SP02 - 003C_620 SP02, ST-PI 003C_640 SP011
Report /SDF/RSORAVSE (export tool for SAP Support employee) must not be executed before applying the correction.
Apply SAP Note 766425.
