Текущее время: Ср, сен 23 2026, 17:45
 Заголовок сообщения: Не загружается графический редактор экранов
СообщениеДобавлено: Пт, окт 29 2004, 17:01
Уважаемые господа базисники, возможно кто то сталкивался с такой проблемой - не загружается графический редактор при удаленном!!! доступе в систему. Причем проблема только с одной вышеупомянутой системой, с другими все в полном порядке.
Вот подробный текст ошибки:
Graphical Layout Editor not available. Continue with alphanumeric editor.
Message no. 37527
Diagnosis
You tried to start the layout editor and the "Grapical Screen Painter" option is set in your Workbench settings. However, the graphical layout editor is not available. Possible reasons include:
- You have insufficient memory resources on your frontend to start the graphical layout editor process.
- The system was unable to find the Graphical Screen Painter program.
- The system was unable to execute the Graphical Screen Painter program.
СообщениеДобавлено: Вс, окт 31 2004, 11:20
Посмотрите ноту 101971
Возможно дело вот в чем:
1) If a Firewall is installed between frontend computer and the application server, you need to decide whether the port for the RFC link of the graphical layout editor shall be released in the firewall. This is port 33nn, where nn is the 2-digit system number of the SAP application server. As of Release 3.1G, the graphical layout editor needs an RFC link for communication with the application server in addition to the already existing linkof the SAP GUIs. Such a second link is not allowed by the firewall in general because it would contradict the security concept (password protection, logging of the connection).
If no firewall exists, you should check whether the frontend computer can be added to the route permission table or whether the password option can be removed from out of the available entry.
For details refer to chapter 4.4 of the attached Note 30289.
СообщениеДобавлено: Пн, ноя 01 2004, 14:11
Спсибо огромное Я ИДИЁТ, УБЕЙТЕ МИНЯ КТО-НИБУДЬ!
Все работает :D
СообщениеДобавлено: Вт, фев 27 2007, 18:46
Вт, ноя 07 2006, 10:17
А кто сталкивался с такой проблемой при запуске графического редактора, запускается обычный строковый редактор и внизу сообщение (зеленое):
EU_SCRP_WN32 : timeout during allocate / CPIC-CALL: 'ThSAPCMRCV'
№ сообщения 37033
и все. Че с этим делать то?
СообщениеДобавлено: Вт, фев 27 2007, 21:30
Вт, авг 17 2004, 11:44
Глянуть для начала ноту 204910.
СообщениеДобавлено: Ср, фев 28 2007, 10:48
я не админ, подскажите где настраивается то что здесь написано:
Up to Release 3.0F: you can either delete the environment variable SAPGRAPH or copy all the files of the Graphical Layout Editor into the directory which is specified by SAPGRAPH.
СообщениеДобавлено: Ср, фев 28 2007, 12:14
Вы еще на 3.0 работаете?
СообщениеДобавлено: Ср, фев 28 2007, 12:26
нет, думал Up to 3.0 переводится как версия выше 3.0
СообщениеДобавлено: Чт, мар 01 2007, 14:56
Чт, фев 09 2006, 12:02
Графический редактор ставиться отдельно от GUI
См. в инсталяционном меню "Development tools"
СообщениеДобавлено: Пн, мар 12 2007, 11:09
Почитал ноту, через sm59 проверил RFC-соединение EU_SCRP_WN32. Вся проблема в том что соединение не хочет устанавливаться, то ли блокируется чем-то (хотя все файрволы поотключал), то ли еще что, админ сказал что подобную проблему у него не получилось побороть, помог только снос винды и установка с нуля. Сделал тоже самое, чтобы не терять время.
Собственно тема еще открыта, пишите кто сталкивался и как решали данную проблему.
 Заголовок сообщения: Re: Не загружается графический редактор экранов
СообщениеДобавлено: Ср, авг 01 2012, 10:28
Пт, сен 12 2008, 15:41
пост старый, но я оставлю свое сообщение, так как только что наткнулся на подобную проблему.
EU_SCRP_WN32 : timeout during allocate / CPIC-CALL: 'ThSAPCMRCV' № сообщения 37033
После анализа логов сапроутера выяснилось, что в saproutetab не был разрешен порт 3301.
