Текущее время: Ср, сен 23 2026, 08:41
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Backup на ленту
СообщениеДобавлено: Пт, май 19 2006, 10:10
Пн, май 15 2006, 07:01
Пытаюсь настроить резервное копирование через db13 (SAP R3/470, Oracle 9.2.0.4, RedHat AS 2.1, стриммер Dell DLT VS160)
настройки в initSID.sap
backup_mode = full
restore_mode = all
backup_type = offline
backup_dev_type = tape
backup_root_dir = /oracle/SID/sapbackup
stage_root_dir = /oracle/SID/sapbackup
compress = yes
compress_cmd = "gzip -c $ > $"
uncompress_cmd = "gunzip -c $ > $"
compress_dir = /oracle/SID/sapreorg
archive_function = save
archive_copy_dir = /oracle/SID/sapbackup
archive_stage_dir = /oracle/SID/sapbackup
tape_copy_cmd = dd
disk_copy_cmd = copy
stage_copy_cmd = rcp
cpio_flags = -ovB
cpio_in_flags = -iuvB
cpio_disk_flags = -pdu
dd_flags = "obs=64k bs=64k"
dd_in_flags = "ibs=64k bs=64k"
saveset_members = 1
copy_out_cmd = "dd ibs=8k obs=64k of=$"
copy_in_cmd = "dd ibs=64k obs=8k if=$"
rewind = "mt -f $ rewind"
rewind_offline = "mt -f $ offline"
tape_pos_cmd = "mt -f $ fsf $"
tape_size = 80000M
exec_parallel = 0
tape_address = /dev/nst0
tape_address_rew = /dev/st0
volume_archive = (SIDA01, SIDA02, SIDA03, SIDA04, SIDA05,
SIDA06, SIDA07, SIDA08, SIDA09, SIDA10,
SIDA11, SIDA12, SIDA13, SIDA14, SIDA15,
SIDA16, SIDA17, SIDA18, SIDA19, SIDA20,
SIDA21, SIDA22, SIDA23, SIDA24, SIDA25,
SIDA26, SIDA27, SIDA28, SIDA29, SIDA30)
volume_backup = (SIDB01, SIDB02, SIDB03, SIDB04, SIDB05,
SIDB06, SIDB07, SIDB08, SIDB09, SIDB10,
SIDB11, SIDB12, SIDB13, SIDB14, SIDB15,
SIDB16, SIDB17, SIDB18, SIDB19, SIDB20,
SIDB21, SIDB22, SIDB23, SIDB24, SIDB25,
SIDB26, SIDB27, SIDB28, SIDB29, SIDB30)
expir_period = 30
tape_use_count = 100
лог задания
Step 001 started (program RSDBAJOB, variant &0000000000035, user ID )
Execute logical command BRBACKUP On host
Parameters: -u / -c force -t online -m full -p initSID.sap -v /DEV/ST0 -a -c force -p initSID.sap -sd
BR0051I BRBACKUP 6.40 (11)
BR0055I Start of database backup: bdsqfjxc.fnt 2006-05-19 12.57.56
BR0477I Oracle pfile /oracle/SID/920_32/dbs/initSID.ora created from spfile /oracle/SID/920_32/dbs/spfileSID.ora
BR0105E 0 free backup volumes found, 1 required
BR0056I End of database backup: bdsqfjxc.fnt 2006-05-19 12.58.01
BR0280I BRBACKUP time stamp: 2006-05-19 12.58.01
BR0054I BRBACKUP terminated with errors
External program terminated with exit code 3
BRBACKUP returned error status E
инициализация ленты дает следующее
Job started
Step 001 started (program RSDBAJOB, variant &0000000000026, user ID )
Parameters: -u / -i force -c force -n 1 -v SCRATCH
BR0055I Start of database backup: bdspwhgc.tib 2006-05-17 16.31.38
BR0205I Backup volume initialization
BR0058I BRBACKUP action ID: bdspwhgc
BR0059I BRBACKUP function ID: tib
BR0102I Following backup device will be used: /dev/nst0
BR0131I All volumes get the name SCRATCH
BR0129I Force option set - no label checking during initialization
BR0134I Unattended mode with 'force' active - no operator confirmation allowed
BR0207I Volume in device: /dev/nst0 will be initialized with name: SCRATCH
BR0280I BRBACKUP time stamp: 2006-05-17 16.31.38
BR0226I Rewinding tape volume in device /dev/st0 ...
BR0202I Saving /oracle/SID/sapbackup/.tape.hdr0
BR0203I to /dev/nst0 ...
BR0278E Command output of 'LANG=C cd /oracle/SID/sapbackup && echo .tape.hdr0 /usr/sap/SID/SYS/exe/run/brtools -f detach LANG=
cpio: .tape.hdr0: truncating inode number
.tape.hdr0
1 block
BR0280I BRBACKUP time stamp: 2006-05-17 16.31.42
BR0279E Return code from 'LANG=C cd /oracle/SID/sapbackup && echo .tape.hdr0 /usr/sap/SID/SYS/exe/run/brtools -f detach LANG=C
BR0222E Copying /oracle/SID/sapbackup/.tape.hdr0 to/from /dev/nst0 failed due to previous errors
BR0219E Initialization of volume SCRATCH in device /dev/nst0 failed
BR0206I End of backup volume initialization
что я делаю не так и почему используется cpio, хотя в параметрах ставил и cpio и dd:
tape_copy_cmd = dd
СообщениеДобавлено: Ср, май 24 2006, 19:32
Пт, май 05 2006, 08:35
попробуй заремить перечень лент и поставить скрач
и только после этого делать инициализацию ленты - должно помочь
а лучше потрать немного времени - пропиши нормальные лейбы по количеству лент, инициализируй их все и ток тогда запускай бэкап
да и время хранения меньше сделай...
СообщениеДобавлено: Чт, май 25 2006, 07:02
я их инициализирую SCRATCH-ем
добился, чтобы он пытался писать на ленту, но потом, когда пытаюсь прочитать - там пусто
BR0280I BRBACKUP time stamp: 2006-05-22 15.40.07
BR0057I Backup of database: SID
BR0058I BRBACKUP action ID: bdsqurso
BR0059I BRBACKUP function ID: pnt
BR0110I Backup mode: PARTIAL
BR0060I Tablespace for backup: SYSTEM
BR0077I Database file for backup: /oracle/SID/sapbackup/cntrlSID.dbf
BR0061I 2 files found for backup, total size 636.562 MB
BR0091I 0 files were already saved in: bdsqurrn.pnt
BR0143I Backup type: online
BR0111I Files will be compressed
BR0130I Backup device type: tape
BR0103I Following backup volume will be used: SIDB0104
BR0208I Volume with name SIDB0104 required in device /dev/nst0
BR0351I Restoring /oracle/SID/sapbackup/.tape.hdr0
BR0355I from /dev/nst0 ...
BR0241I Checking label on volume in device /dev/nst0
BR0242I Scratch volume in device /dev/nst0 will be renamed to SIDB0104
BR0280I BRBACKUP time stamp: 2006-05-22 15.40.12
BR0209I Volume in device /dev/nst0 has name TCDB0104
BR0202I Saving init_ora
BR0202I Saving /oracle/SID/920_32/dbs/initSID.sap
BR0280I BRBACKUP time stamp: 2006-05-22 15.40.21
BR0198I Profiles saved successfully
BR0315I 'Alter tablespace SYSTEM begin backup' successful
BR0201I Compressing /oracle/SID/sapdata1/system_1/system.data1
BR0203I to /oracle/SID/sapreorg/system.data1.Z ...
BR0202I Saving /oracle/SID/sapreorg/system.data1.Z
#FILE..... /oracle/SID/sapdata1/system_1/system.data1
#SAVED.... system.data1.Z SIDB0104/4 5.0428:1 131001172
BR0280I BRBACKUP time stamp: 2006-05-22 15.47.19
BR0063I 1 of 2 files processed - 630.008 MB of 636.562 MB done
BR0204I Percentage done: 98.97%, estimated end time: 15:47
BR0001I *************************************************_
BR0317I 'Alter tablespace SYSTEM end backup' successful
BR0201I Compressing /oracle/SID/sapbackup/cntrlSID.dbf
BR0203I to /oracle/SID/sapreorg/cntrlSID.dbf.Z ...
BR0202I Saving /oracle/SID/sapreorg/cntrlSID.dbf.Z
#FILE..... /oracle/SID/sapbackup/cntrlSID.dbf
#SAVED.... cntrlSID.dbf.Z SIDB0104/5 84.1847:1 81643
BR0280I BRBACKUP time stamp: 2006-05-22 15.47.22
BR0063I 2 of 2 files processed - 636.562 MB of 636.562 MB done
BR0204I Percentage done: 100.00%, estimated end time: 15:47
BR0001I **************************************************
BR0280I BRBACKUP time stamp: 2006-05-22 15.47.24
BR0340I Switching to next online redo log file for database instance SID ...
BR0321I Switch to next online redo log file for database instance SID successful
BR0202I Saving space_log
BR0202I Saving /oracle/SID/sapbackup/bdsqurso.pnt
BR0202I Saving /oracle/SID/sapbackup/backSID.log
BR0280I BRBACKUP time stamp: 2006-05-22 15.47.29
BR0280I BRBACKUP time stamp: 2006-05-22 15.47.51
BR0115I Compression rate for all files 5.0921:1
BR0056I End of database backup: bdsqurso.pnt 2006-05-22 15.48.23
BR0280I BRBACKUP time stamp: 2006-05-22 15.48.23
BR0052I BRBACKUP completed successfully
в общем вроде пишет и в конце касету выплевывает.
после этого я пытаюсь считать
mt -f /dev/st0 rewind
cpio -ivB < /dev/nst0
считывает .tape.hdr0
в нем VOLUME = SIDB0104
потом опять делаю считывание с ленты
он долго крутит касету, потом выплевывает и выдает:
Found end of tape. To continue, type device/file name when ready.
хотя я копирую только SYSTEM, который точно помещается на одну ленту и при копировании вторую ленту он не просит[/code]
СообщениеДобавлено: Чт, май 25 2006, 08:19
мдя...
все равно не пойму почему ты ленишься сделать правильную инициализацию лент ДО начала бэкапа...
ведь строка:
грит лишь о том что ты на скратч ленту пытаешься бэкапить, а в профайле стоит TCDB0104 (кста - зачем тебе лишние 2 символа в имени?? TCDB0104)
судя по логу - бэкап система прошел...
эт первое
второе
какой размер ленты стоит в профайле initTCD.sap ?
третье
проверить наличие файла можно через рестор - если есть куда конечно
СообщениеДобавлено: Чт, май 25 2006, 08:29
вот, вот
можно с этого момента поподробнее
как проверить наличие файла и убедиться, что бакап завершен нормально?
СообщениеДобавлено: Чт, май 25 2006, 09:59
вот, вот
через сапдба
куда... да хоть и на продуктив если не страшно :-)
СообщениеДобавлено: Чт, май 25 2006, 10:11
вот, вот
через сапдба
а где его взять и как запускать?
под линукс на макет-плейсе не нашли
СообщениеДобавлено: Чт, май 25 2006, 10:56
Пт, авг 27 2004, 09:10
Ноту почитай 12741 и хелп , касаемый brtools.
http://help.sap.com/saphelp_47x200/help ... ameset.htm
:rtfm: :wink:
Успехов.
по прозвищу Тосманский Дьявол
СообщениеДобавлено: Чт, май 25 2006, 10:57
стоп...
как это нету сапдба (sapdba) ???
СообщениеДобавлено: Чт, май 25 2006, 11:03
стоп...
а как его вызвать?
поиск нашел только sapdba_role.sql
Сб, авг 21 2004, 14:24
brtools наверняка у них.
СообщениеДобавлено: Чт, май 25 2006, 11:20
стоп...
а как его вызвать?
Я ж тебе все написал тремя сообщениями выше куда копать :!:
:twisted:
СообщениеДобавлено: Чт, май 25 2006, 13:50
Пн, май 22 2006, 10:37
sapdba ищи
/sapmnt/<SID системы>/exe
или
/usr/sap/<SID системы>/SYS/exe/run
там же и все brtools
кстати при вызове их не оказалось, потому что под orа-ой нужно вызвать
СообщениеДобавлено: Чт, май 25 2006, 14:03
sapall написал(а):
sapdba ищи
или
ls sap*
sapccm4x
sapccmsr
sapcm3x
sapcpe
sapcpeft
sapcpp45.so
sapdba_role.sql
sapdbmrfc
sapevt
sapexec
sapftp
saphttp
sapiconv
sapkprotp
saplicense
sapmscsa
saposcol
sapparar
sappfpar
saproot.sh
saprouter
sapsecin
sapstart
sapupgrade
sapwebdisp
sapxpg
СообщениеДобавлено: Чт, май 25 2006, 16:03
Данная ветка напрямую пересекается с аналогичной на одном из буржуйских форумов, цита с ittoolbox:
" How to restore Offline redolog files(Archive)back to the sap system.I did not observe restore option in DB13 and I think this can be done thru SAPDBA.Can anyone help me out."
Как гриться ноу комментс...
:wink: :lol: :lol:
Таки пройдите по ссылке ,которая вам была дана в предъидущих постах.
