Текущее время: Чт, сен 24 2026, 15:32
 Заголовок сообщения: Прерывание бэкапа
СообщениеДобавлено: Чт, июн 29 2006, 19:04
Ср, апр 20 2005, 09:29
суть проблемы:
бэкап прерывается с ошибкой:
BR058I BRBACKUP action ID: bdswszrj
BR059I BRBACKUP function ID: ant
BR110I Backup mode: ALL
BR077I Database file for backup: E:\oracle\SID\sapbackup\cntrlSID.dbf
BR061I 36 files found for backup, total size 44132.945 MB
BR143I Backup type: online
BR113I Files will be compressed by hardware
BR130I Backup device type: tape
BR102I Following backup device will be used: /dev/nmt0
BR103I Following backup volume will be used: SIDB01
BR289I BRARCHIVE will be started at the end of processing
BR134I Unattended mode with 'force' active - no operator confirmation allowed
BR208I Volume with name LPSB01 required in device /dev/nmt0
BR280I Time stamp 2006-06-22 21.01.34
BR226I Rewinding tape volume in device /dev/mt0 ...
BR351I Restoring E:\oracle\SID\sapbackup\.tape.hdr0
BR355I from /dev/nmt0 ...
BR278W Command output of 'E: && cd E:\oracle\SID\sapbackup && D:\usr\sap\SID\SYS\exe\run\brtools.exe -f detach cpio -iuvB -I /dev/nmt0 .tape.hdr0 """.tape.hdr0 """':
cpio: unable to initialize ASPI manager
cpio: using NT tape support
Volume 1: 0 blocks
Insert volume #2, hit return
BR278E Command output of 'E: && cd E:\oracle\LPS\sapbackup && D:\usr\sap\SID\SYS\exe\run\brtools.exe -f detach cpio -iuvB -I /dev/nmt0 .tape.hdr0 """.tape.hdr0 """':
cpio: Unable to open terminal "CONIN$": Access is denied.
0 blocks
BR279E Return code from 'E: && cd E:\oracle\SID\sapbackup && D:\usr\sap\SID\SYS\exe\run\brtools.exe -f detach cpio -iuvB -I /dev/nmt0 .tape.hdr0 """.tape.hdr0 """': 1
BR359E Restore of E:\oracle\SID\sapbackup\.tape.hdr0 from /dev/nmt0 failed due to previous errors
BR218E Checking label on volume in device /dev/nmt0 failed
BR236I Perhaps volume initialization with option '-i force' required
BR056I End of database backup: bdswszrj.ant 2006-06-22 21.01.34
BR054I BRBACKUP terminated with errors
поначалу грешил на привод, но стандартными средствами Винды закатал файлы на ленту. Пробовал разнести базу и логи на разные ленты-та ж ошибка. Может кто сталкивался?
Win2k, лента DDS-4(40 Gb) прописана rewind = "mt -f $ rewind" tape_size = 20000M
система без базисника должна лежать! © Skif
СообщениеДобавлено: Чт, июн 29 2006, 19:54
Пт, май 05 2006, 08:35
Доброго
Косо пробежал - вроде это:
В ораклином профайле стоит использовать ленту SIDB01
(BR103I Following backup volume will be used: SIDB01)
а вы используете LPSB01
собсно - в самом логе:
дайте ему то что он просит - инициализацию ленты
СообщениеДобавлено: Чт, июн 29 2006, 20:07
сори, LPS-и везде перебил на SID а ленту забыл :-(
все правильно СИД у меня - LPS
