Текущее время: Ср, сен 23 2026, 21:22
Начать новую тему Ответить на тему  [ Сообщений: 51 ]  На страницу 1, 2, 3, 4  След.
 Заголовок сообщения: ERP2005 installation error
СообщениеДобавлено: Чт, июл 20 2006, 10:53
Вт, июл 18 2006, 11:57
Vo vremja instaljaciji ERP2005 na faze import ABAP 4 iz 38 packages viljetajut :(
OS: WIN2003
DB: ORA 10.2
Vsjo chto mog naiti iz probljem:
import_monitor.log:
ERROR: 2006-07-20 09:54:49 com.sap.inst.migmon.LoadTask run
Loading of 'SAPAPPL0_2' import package is interrupted with R3load error.
Process 'C:\usr\sap\RET\SYS\exe\uc\NTI386\R3load.exe -i SAPAPPL0_2.cmd -dbcodepage 4103 -l SAPAPPL0_2.log -stop_on_error' exited with return code 2.
For mode details see 'SAPAPPL0_2.log' file.
Standard error output:
sapparam: sapargv( argc, argv) has not been called.
sapparam(1c): No Profile used.
sapparam: SAPSYSTEMNAME neither in Profile nor in Commandline
SAPAPPL0_2.log:
DbSl Trace: Failed to register client info: orc=604
DbSl Trace: ORA-1403 when accessing table SAPUSER
(DB) INFO: connected to DB
(DB) INFO: DbSlControl(DBSL_CMD_NLS_CHARACTERSET_GET): UTF8
(DB) ERROR: DDL statement failed
(DROP TABLE "KNA1")
DbSlExecute: rc = 103
(SQL error 942)
error message returned by DbSl:
ORA-00942: table or view does not exist
(IMP) INFO: a failed DROP attempt is not necessarily a problem
DbSl Trace: ORA-604 occurred when executing SQL statement (parse error offset=0)
DbSlExecute: rc = 99
(SQL error 604)
ORA-00604: error occurred at recursive SQL level 1
ORA-04031: unable to allocate 4108 bytes of shared memory ("shared pool","select name,password,datats#...","Typecheck","kgghtInit")
(DB) INFO: disconnected from DB
V chom mozhet bitj probljema?
СообщениеДобавлено: Чт, июл 20 2006, 11:06
Чт, июн 08 2006, 17:23
ORA-04031 unable to allocate string bytes of shared memory ("string","string","string","string")
Cause: More shared memory is needed than was allocated in the shared pool.
Action: If the shared pool is out of memory, either use the DBMS_SHARED_ POOL package to pin large packages, reduce your use of shared memory, or increase the amount of available shared memory by increasing the value of the initialization parameters SHARED_POOL_RESERVED_SIZE and SHARED_ POOL_SIZE. If the large pool is out of memory, increase the initialization parameter LARGE_POOL_SIZE.
ORA-00604 error occurred at recursive SQL level string
Cause: An error occurred while processing a recursive SQL statement (a statement applying to internal dictionary tables).
Action: If the situation described in the next error on the stack can be corrected, do so; otherwise contact Oracle Support Services.
СообщениеДобавлено: Чт, июл 20 2006, 11:07
Вт, мар 29 2005, 19:54
с памятью проблем нет?
Не откладывай работу на субботу, а секс на старость
система без базисника должна лежать! (с) Skif
СообщениеДобавлено: Чт, июл 20 2006, 11:11
2 Gb
Proboval prodolzhatj instaljaciju poslje perezagruzki. Bez izmenenij.
Instaljacija povtornaja. Pervij raz instaljiroval ispoljzuja java 1.5.0 Viljetalji 8 packages s takimi zhe oshibkami.
Postavil java 1.4.2 i povtoril instaljaciju zanovo. Teperj viljetajut toljko 4 packages.
СообщениеДобавлено: Чт, июл 20 2006, 11:17
Платформа установки какая? Скорее всего Windows? 32,64bit ? Свопа хватает?
СообщениеДобавлено: Чт, июл 20 2006, 11:19
avlag написал:
Ïëàòôîðìà óñòàíîâêè êàêàÿ? Ñêîðåå âñåãî Windows? 32,64bit ? Ñâîïà õâàòàåò?
Windows Server 2003 R2 32bit
Swap: Paging file custom size: Initial 2046 Maximum 8000
СообщениеДобавлено: Чт, июл 20 2006, 11:24
vamis написал(а):
avlag написал:
А максимум 8 Gb это как? Вроде ограничение для 32 bit 4 Gb на один диск?
Поставьте fixed 4 Gb, возможно в этом проблема. Хотя всего желательно иметь 8 Gb. Но если нет второго, хотя бы логического диска, то придется обойтись 4-мя Gb. Должно хватить, хотя и в натяг.
vamis написал(а):
avlag написал:
при установке посмотри сколько всего памти съело (можно в таска манагере) да и поставь инишиал своп на 8 гигов.
СообщениеДобавлено: Чт, июл 20 2006, 11:32
Blood Angel написал(а):
vamis написал(а):
avlag написал:
ïðè óñòàíîâêå ïîñìîòðè ñêîëüêî âñåãî ïàìòè ñúåëî (ìîæíî â òàñêà ìàíàãåðå) äà è ïîñòàâü èíèøèàë ñâîï íà 8 ãèãîâ.
pomenjal min 8000 max 8000
njepomoglo
v taskmanagere:
Physical memory
Total: 2094976
Available 1353608
PF usage 638 Mb
v alert_<SID>.log:
Errors in file c:\oracle\ret\saptrace\background\ret_m001_2204.trc:
ORA-04031: unable to allocate 4108 bytes of shared memory ("shared pool","select ts#,file#,block#,nvl(...","Typecheck","kgghtInit")
ORA-06512: at "SYS.PRVT_HDM", line 49
ORA-06512: at "SYS.PRVT_HDM", line 66
ORA-06512: at line 1
СообщениеДобавлено: Чт, июл 20 2006, 11:33
Gde pomenjatj?
СообщениеДобавлено: Чт, июл 20 2006, 11:37
Oracle версии 10.2 ? Патчик ставили?
СообщениеДобавлено: Чт, июл 20 2006, 11:38
vamis написал(а):
Gde pomenjatj?
Nashol init<SID>.ora
sejchas stoit
SHARED_POOL_SIZE=160903987
SHARED_POOL_RESERVED_SIZE = 16090398
СообщениеДобавлено: Чт, июл 20 2006, 11:39
avlag написал:
Oracle âåðñèè 10.2 ? Ïàò÷èê ñòàâèëè?
Njet. Skachal uzhe 10.2 ot SAPa.
Esho patch nuzhen?
СообщениеДобавлено: Чт, июл 20 2006, 11:43
vamis написал(а):
avlag написал:
Esho patch nuzhen?
В базовом комплекте сейчас поставляют патч до 10.2.0.2 и настойчиво говорят что он обязателен :)
СообщениеДобавлено: Чт, июл 20 2006, 13:00
Патч 10.2.0.2 ставить обязательно
а вот эти параметры должны быть не менее 400 метров (по гайду )
SHARED_POOL_SIZE=400000000
и соответственно
SHARED_POOL_RESERVED_SIZE = 40000000
