Текущее время: Вт, сен 22 2026, 20:03
 Заголовок сообщения: installation error SDM deployment
СообщениеДобавлено: Вс, сен 24 2006, 14:33
Вт, июл 18 2006, 11:57
Privet vsem. Probljema instaljaciji ERP2005
OS. Win2003ent R2 64bit
DB: SQL 2005 SP1
arch: X86_64
jdk1.5.0_08
v chom mozhet bitj probljema?
java.exe.log:
ERROR: Not deployed. Deploy Service returned ERROR:
java.rmi.RemoteException: Cannot deploy application sap.com/tc~SL~CMS~cvers~proxy..
Reason: Webservices common deployment exception! The reason is: Error occured, trying to generate deployment files for ws client com.sap.cms.tcs.cvers.proxy.CMSRTS, application sap.com/tc~SL~CMS~cvers~proxy. . Additional info: none; nested exception is:
java.lang.Exception: com.sap.engine.interfaces.webservices.server.deploy.WSDeploymentException: Webservices common deployment exception! The reason is: Error occured, trying to generate deployment files for ws client com.sap.cms.tcs.cvers.proxy.CMSRTS, application sap.com/tc~SL~CMS~cvers~proxy. . Additional info: none
sdmlogxx.log:
Sep 24, 2006 11:52:48... Error: Aborted: development component 'tc/SL/CMS/cvers/proxy'/'sap.com'/'MAIN_APL70P06_C'/'699999':
Caught exception during application deployment from SAP J2EE Engine's deploy service:
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateSingleWSClientDeployFiles(WSClientsDeployGenerator.java:194)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateSingleWSClientDeployFiles(WSClientsDeployGenerator.java:167)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateWSClientsDeployFiles0(WSClientsDeployGenerator.java:155)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateWSClientsDeployFiles(WSClientsDeployGenerator.java:139)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateWSClientsDeployFiles0(WSClientsDeployGenerator.java:129)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateWSClientsDeployFiles(WSClientsDeployGenerator.java:91)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateDeployFiles(WSClientsDeployGenerator.java:46)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployManager.deploy(WSClientsDeployManager.java:56)
at com.sap.engine.services.webservices.server.deploy.WSDeployer.deploy(WSDeployer.java:158)
at com.sap.engine.services.deploy.server.application.DeploymentTransaction.makeComponents(DeploymentTransaction.java:606)
at com.sap.engine.services.deploy.server.application.DeployUtilTransaction.commonBegin(DeployUtilTransaction.java:318)
at com.sap.engine.services.deploy.server.application.DeploymentTransaction.begin(DeploymentTransaction.java:307)
at com.sap.engine.services.deploy.server.application.ApplicationTransaction.makeAllPhasesOnOneServer(ApplicationTransaction.java:292)
at com.sap.engine.services.deploy.server.application.ApplicationTransaction.makeAllPhases(ApplicationTransaction.java:326)
at com.sap.engine.services.deploy.server.DeployServiceImpl.makeGlobalTransaction(DeployServiceImpl.java:3123)
at com.sap.engine.services.deploy.server.DeployServiceImpl.deploy(DeployServiceImpl.java:540)
at com.sap.engine.services.deploy.server.DeployServiceImplp4_Skel.dispatch(DeployServiceImplp4_Skel.java:1555)
at com.sap.engine.services.rmi_p4.DispatchImpl._runInternal(DispatchImpl.java:304)
at com.sap.engine.services.rmi_p4.DispatchImpl._run(DispatchImpl.java:193)
at com.sap.engine.services.rmi_p4.server.P4SessionProcessor.request(P4SessionProcessor.java:122)
at com.sap.engine.core.service630.context.cluster.session.ApplicationSessionMessageListener.process(ApplicationSessionMessageListener.java:33)
at com.sap.engine.core.cluster.impl6.session.MessageRunner.run(MessageRunner.java:41)
at com.sap.engine.core.thread.impl3.ActionObject.run(ActionObject.java:37)
at java.security.AccessController.doPrivileged(Native Method)
at com.sap.engine.core.thread.impl3.SingleThread.execute(SingleThread.java:100)
at com.sap.engine.core.thread.impl3.SingleThread.run(SingleThread.java:170)
Caused by: com.sap.engine.interfaces.webservices.server.deploy.WSDeploymentException: Webservices common deployment exception! The reason is: Error occurred generating ws client proxy files. Package error. . Additional info: {1}
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientProxyGenerator.generateAndPackageProxyFiles(WSClientProxyGenerator.java:61)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientsDeployGenerator.generateSingleWSClientDeployFiles(WSClientsDeployGenerator.java:188)
... 25 more
Caused by: com.sap.engine.interfaces.webservices.server.deploy.WSDeploymentException: Webservices common deployment exception! The reason is: Error occurred trying to compile ws client proxy files. Compilation error. . Additional info: {1}
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientProxyGenerator.compileWSClientProxyFile(WSClientProxyGenerator.java:256)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientProxyGenerator.compileAndPackageWSClientProxyFiles(WSClientProxyGenerator.java:220)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientProxyGenerator.generateAndPackageProxyFiles(WSClientProxyGenerator.java:54)
... 26 more
Caused by: java.io.IOException: Compilation fails...
CompilerOracle: exclude com/sapportals/portal/pb/layout/taglib/ContainerTag addIviewResources
CompilerOracle: exclude com/sap/engine/services/keystore/impl/security/CodeBasedSecurityConnector getApplicationDomain
CompilerOracle: exclude com/sap/engine/services/rmi_p4/P4StubSkeletonGenerator generateStub
CompilerOracle: exclude com/sapportals/portal/prt/util/StringUtils escapeToJS
CompilerOracle: exclude com/sapportals/portal/prt/core/broker/PortalServiceItem startServices
CompilerOracle: exclude com/sap/engine/services/webservices/server/deploy/WSConfigurationHandler downloadFile
CompilerOracle: exclude com/sapportals/portal/prt/jndisupport/util/AbstractHierarchicalContext lookup
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\CMSRTSImpl.java:3: cannot find symbol
symbol : class CMSRTS
public class CMSRTSImpl extends com.sap.engine.services.webservices.jaxrpc.wsdl2java.ServiceBaseServer implements com.sap.cms.tcs.cvers.proxy.CMSRTS {
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\CMSRTSImpl.java:10: cannot find symbol
symbol : class CMSRTSViDocument
public com.sap.cms.tcs.cvers.proxy.CMSRTSViDocument getLogicalPort(String portName) throws javax.xml.rpc.ServiceException {
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\CMSRTSImpl.java:13: cannot find symbol
public com.sap.cms.tcs.cvers.proxy.CMSRTSViDocument getLogicalPort() throws javax.xml.rpc.ServiceException {
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:14: cannot find symbol
public class Config1BindingStub extends com.sap.engine.services.webservices.jaxrpc.wsdl2java.BaseGeneratedStub implements com.sap.cms.tcs.cvers.proxy.CMSRTSViDocument {
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:44: package com.sap.cms.tcs.cvers.proxy.types does not exist
public com.sap.cms.tcs.cvers.proxy.types.SendStringResponse sendString(com.sap.cms.tcs.cvers.proxy.types.SendString parameters) throws java.rmi.RemoteException {
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\CMSRTSImpl.java:11: cannot find symbol
return (com.sap.cms.tcs.cvers.proxy.CMSRTSViDocument) getPort(new javax.xml.namespace.QName(null,portName),null);
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\CMSRTSImpl.java:14: cannot find symbol
return (com.sap.cms.tcs.cvers.proxy.CMSRTSViDocument) getLogicalPort(com.sap.cms.tcs.cvers.proxy.CMSRTSViDocument.class);
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:53: package com.sap.cms.tcs.cvers.proxy.types does not exist
this.inputParams[0].contentClass = com.sap.cms.tcs.cvers.proxy.types.SendString.class;
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:61: package com.sap.cms.tcs.cvers.proxy.types does not exist
this.outputParams[0].contentClass = com.sap.cms.tcs.cvers.proxy.types.SendStringResponse.class;
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:64: package com.sap.cms.tcs.cvers.proxy.types does not exist
com.sap.cms.tcs.cvers.proxy.types.SendStringResponse parametersTemp;
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:84: package com.sap.cms.tcs.cvers.proxy.types does not exist
parametersTemp = (com.sap.cms.tcs.cvers.proxy.types.SendStringResponse) this.outputParams[0].content;
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:96: package com.sap.cms.tcs.cvers.proxy.types does not exist
com.sap.cms.tcs.cvers.proxy.types.SendString _request_variable = new com.sap.cms.tcs.cvers.proxy.types.SendString();
C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java:98: package com.sap.cms.tcs.cvers.proxy.types does not exist
com.sap.cms.tcs.cvers.proxy.types.SendStringResponse _result_variable = sendString(_request_variable);
Note: C:\usr\sap\SBX\DVEBMGS01\j2ee\cluster\server0\temp\webservices\deploy\sap.com_tc_SL_CMS_cvers_proxy\wsClients\ws_cl_0\gen\com\sap\cms\tcs\cvers\proxy\Config1BindingStub.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
16 errors
at com.sap.engine.services.webservices.jaxrpc.util.PackageBuilder.compileExternal(PackageBuilder.java:359)
at com.sap.engine.services.webservices.jaxrpc.util.PackageBuilder.traversThrough(PackageBuilder.java:302)
at com.sap.engine.services.webservices.jaxrpc.util.PackageBuilder.traversThrough(PackageBuilder.java:278)
at com.sap.engine.services.webservices.jaxrpc.util.PackageBuilder.compile(PackageBuilder.java:426)
at com.sap.engine.services.webservices.server.deploy.wsclient.WSClientProxyGenerator.compileWSClientProxyFile(WSClientProxyGenerator.java:249)
... 28 more
Сейчас этот форум просматривают: Google [Bot], Yandex [Bot]
