Текущее время: Вт, сен 15 2026, 08:56
Вопросы по LSMW - сюда
Вопросы по SAP GRC - сюда
Вопросы по SAP HANA - сюда
 Заголовок сообщения: Помогите с бекапом
СообщениеДобавлено: Чт, апр 26 2007, 14:59
Чт, апр 26 2007, 14:22
Привет. Требуется помощь для настройки бэкапа.
Используется Data Protector.
При бэкапе формируется лог:
[Normal] From: BSM@sbp01 "New1" Time: 26.04.2007 17:02:45
OB2BAR application on "sbp01" successfully started.
BR0051I BRBACKUP 6.40 (42)
BR0055I Start of database backup: bdvcxqev.pnf 2007-04-26 17.02.45
BR0484I BRBACKUP log file: C:\Oracle\SBP\sapbackup\bdvcxqev.pnf
BR0477I Oracle pfile C:\Oracle\SBP\920\database\initSBP.ora created from spfile C:\Oracle\SBP\920\database\spfileSBP.ora
BR0280I BRBACKUP time stamp: 2007-04-26 17.02.46
BR0319I Control file copy created: C:\Oracle\SBP\sapbackup\cntrlSBP.dbf 6791168
BR0057I Backup of database: SBP
BR0058I BRBACKUP action ID: bdvcxqev
BR0059I BRBACKUP function ID: pnf
BR0110I Backup mode: PARTIAL
BR0060I Tablespace for backup: SYSTEM
BR0077I Database file for backup: C:\Oracle\SBP\sapbackup\cntrlSBP.dbf
BR0061I 2 files found for backup, total size 556.484 MB
BR0143I Backup type: online
BR0130I Backup device type: util_file
BR0109I Files will be saved by backup utility
BR0126I Unattended mode active - no operator confirmation required
BR0315I 'Alter tablespace SYSTEM begin backup' successful
BR0229I Calling backup utility with function 'backup'...
BR0279E Return code from 'C:\usr\sap\SBP\SYS\exe\run\backint.exe -u SBP -f backup -i C:\Oracle\SBP\sapbackup\.bdvcxqev.lst -t file -c': 128
BR0232E 0 of 2 files saved by backup utility
BR0231E Backup utility call failed
BR0280I BRBACKUP time stamp: 2007-04-26 17.02.49
BR0317I 'Alter tablespace SYSTEM end backup' successful
BR0056I End of database backup: bdvcxqev.pnf 2007-04-26 17.02.46
BR0054I BRBACKUP terminated with errors
[Major] From: OB2BAR_OMNISAP@sbp01 "OMNISAP" Time: 26.04.2007 17:02:50
BRBACKUP C:\usr\sap\SBP\SYS\exe\run\brbackup.exe -t online -d util_file -c -m SYSTEM -u system/******* returned 5
[Normal] From: BSM@sbp01 "New1" Time: 26.04.2007 17:03:26
OB2BAR application on "sbp01" disconnected.
[Critical] From: BSM@sbp01 "New1" Time: 26.04.2007 17:03:26
None of the Disk Agents completed successfully.
Session has failed.
Для проверки работы запускал из директории Data Protector:
testbar2 –type:SAP –appname:SBP –bar:new1 –perform:backup
получил следующий лог:
[Normal] From: OB2BAR_TESTBAR@sbp01 "SBP" Time: 26.04.2007 16:00:23
Sending a multiline message directly to Session Manager.
Second line
[Normal] From: BMA@sbp01 "HP:Ultrium 2-SCSI_1_sbp01" Time: 26.04.2007 16:00:28
STARTING Media Agent "HP:Ultrium 2-SCSI_1_sbp01"
[Normal] From: BMA@sbp01 "HP:Ultrium 2-SCSI_1_sbp01" Time: 26.04.2007 16:00:31
By: UMA@sbp01@Changer0:0:4:1
Loading medium from slot 1 to device Tape0:0:4:0C
[Critical] From: OB2BAR_TESTBAR@sbp01 "SBP" Time: 26.04.2007 16:01:12
Unknown internal error.
[Major] From: BSM@sbp01 "New1" Time: 26.04.2007 16:01:48
[61:3003] Lost connection to OB2BAR Backup DA named "SBP"
on host sbp01.
Ipc subsystem reports: "IPC Read Error
System error: [10054] Сброс подключения другим компьютером
[Normal] From: BMA@sbp01 "HP:Ultrium 2-SCSI_1_sbp01" Time: 26.04.2007 16:02:25
Tape0:0:4:0C
Medium header verification completed, 0 errors found
[Normal] From: BMA@sbp01 "HP:Ultrium 2-SCSI_1_sbp01" Time: 26.04.2007 16:02:46
Unloading medium to slot 1 from device Tape0:0:4:0C
[Normal] From: BMA@sbp01 "HP:Ultrium 2-SCSI_1_sbp01" Time: 26.04.2007 16:03:08
COMPLETED Media Agent "HP:Ultrium 2-SCSI_1_sbp01"
[Critical] From: BSM@sbp01 "New1" Time: 26.04.2007 16:03:08
Session has failed.
[Normal] From: BSM@sbp01 "New1" Time: 26.04.2007 16:03:08
Подскажите в чем проблема?
СообщениеДобавлено: Чт, апр 26 2007, 16:22
Чт, фев 15 2007, 11:04
Для того чтобы настроить бэкап:
_STRONGLY_RECOMMENDED_:
1. Избавиться от HP DataProtector.
Подсказать обычно может в чем проблема саппорт из HP. Но редко когда сразу.
СообщениеДобавлено: Пт, апр 27 2007, 13:55
Пн, ноя 21 2005, 15:25
эт точно. реткое г... :)
если сделано всё по гайду DP Agent for SAP - то сразу работает.
попробуйте вместо -u system/******* написать просто -u /
.туч
