Текущее время: Ср, сен 23 2026, 16:58
 Заголовок сообщения: Error при установке Database instance
СообщениеДобавлено: Чт, май 24 2007, 13:30
Ср, мар 28 2007, 18:00
Уважаемые, подскажите пожалуйста в чем может быть загвоздка.
Во время установки database instance на этапе database Load (post processing) вылазит Error.
Лог:
C:\usr\sap\BAS\SYS\exe\run/R3load.exe: START OF LOG: 20070524125354
C:\usr\sap\BAS\SYS\exe\run/R3load.exe: sccsid @(#) $Id: //bas/620/src/R3ld/R3load/R3ldmain.c#6 $ SAP
C:\usr\sap\BAS\SYS\exe\run/R3load.exe: version R6.20/V1.2
C:\usr\sap\BAS\SYS\exe\run/R3load.exe -dbcodepage 1100 -i C:\SAPinst_bd_instance/SAPVIEW.cmd -l C:\SAPinst_bd_instance/SAPVIEW.log -stop_on_error
DbSl Trace: Got ORACLE_HOME=C:\oracle\ora92 from environment
DbSl Trace: Client NLS settings: AMERICAN_AMERICA.WE8DEC
DbSl Trace: Logon as OPS$-user to get SAPBAS's password
DbSl Trace: Connecting as /@BAS on connection 0 ...
DbSl Trace: Attaching to DB Server BAS (con_hdl=0,svchp=014C5AEC,svrhp=014C7D24)
DbSl Trace: Starting user session (con_hdl=0,svchp=014C5AEC,srvhp=014C7D24,usrhp=014D04D4)
DbSl Trace: Now I'm connected to ORACLE
DbSl Trace: ORA-1403 when accessing table SAPUSER
DbSl Trace: Disconnecting from connection 0 ...
DbSl Trace: Closing user session (con_hdl=0,svchp=014C5AEC,usrhp=014D04D4)
DbSl Trace: Now I'm disconnected from ORACLE
DbSl Trace: Try to connect with default password
DbSl Trace: Connecting as SAPBAS/<pwd>@BAS on connection 0 ...
DbSl Trace: Database NLS settings: AMERICAN_AMERICA.WE8DEC
DbSl Trace: Database instance bas is running on SERVER with ORACLE version 9.2.0.4.0 since 20070524
(DB) INFO: connected to DB
(DB) INFO: /SAPTRX/A_CONDF4 created
(DB) INFO: /SAPTRX/VDASFEV created
(DB) INFO: /SAPTRX/VDASFPAR created
(DB) INFO: /SAPTRX/VD_AOMIL created
(DB) INFO: /SAPTRX/VD_AOPAC created
(DB) INFO: /SAPTRX/VD_AOPAE created
(DB) INFO: /SAPTRX/VD_AOPAI created
(DB) INFO: /SAPTRX/VD_AOPAR created
(DB) INFO: /SAPTRX/VD_AOTD1 created
(DB) INFO: /SAPTRX/VD_AOTD2 created
(DB) INFO: /SAPTRX/VD_AOTDD created
(DB) INFO: /SAPTRX/VD_AOTYP created
(DB) INFO: /SAPTRX/VD_ASPAR created
(DB) INFO: /SAPTRX/VD_CONDL created
(DB) ERROR: DDL statement failed
(CREATE VIEW "/SAPTRX/V_AODD02" ( "TRK_OBJ_TYPE" , "TABLEDEF" , "DDICDEF" , "DBTAB" , "DDLANGUAGE" , "DDTEXT" , "AS4LOCAL" ) AS SELECT T0001."TRK_OBJ_TYPE", T0001."TABLEDEF", T0001."DDICDEF", T0001."DBTAB", T0003."DDLANGUAGE", T0003."DDTEXT", T0002."AS4LOCAL" FROM "/SAPTRX/AOALLTAB" T0001, "DD02L" T0002, "DD02T" T0003 WHERE T0002."TABNAME" = T0001."DDICDEF" AND T0002."TABNAME" = T0003."TABNAME" AND T0002."AS4LOCAL" = 'A')
DbSlExecute: rc = 103
(SQL error 942)
error message returned by DbSl:
ORA-00942: table or view does not exist
DbSl Trace: Detaching from DB Server (con_hdl=0,svchp=014C5AEC,srvhp=014C7D24)
(DB) INFO: disconnected from DB
C:\usr\sap\BAS\SYS\exe\run/R3load.exe: job finished with 1 error(s)
C:\usr\sap\BAS\SYS\exe\run/R3load.exe: END OF LOG: 20070524125358
Уже 2ой день бьюсь, буду очень признателен за помощь.
СообщениеДобавлено: Чт, май 24 2007, 13:55
Чт, сен 08 2005, 13:23
Для начала: следующие таблицы есть в БД?
/SAPTRX/AOALLTAB
DD02L
DD02T
СообщениеДобавлено: Чт, май 24 2007, 14:07
Их нужно создавать вручную или они создаются автоматически при установке SAP?
СообщениеДобавлено: Чт, май 24 2007, 14:19
Как я понимаю, инсталлятор пытается создать VIEW, которая ссылается на несуществующие таблицы. Эти таблицы я указал. Теоретически данные таблицы должны были создаться заранее в рамках другого шага инсталляции. Для начала надо проверить, есть ли эти таблицы в БД. Если есть, то проблема может быть в другом.
СообщениеДобавлено: Пт, май 25 2007, 10:38
Vadimus, вы были правы. Таких таблиц в базе нету. Параметров их я не знаю => сам создать не смогу.
Теряюсь в догадках в какую сторону думать дальше...
Буду благодарен за пинок в правильном направлении.
СообщениеДобавлено: Пт, май 25 2007, 10:52
Ср, май 16 2007, 14:30
У Вас не прошёл один из предыдущих шагов (когда шла загрузка
базы данных). Стартовало штук 20-30 заданий, каждое прогружало
какие-то таблицы(R3load). Одно или несколько заданий уВас не прошло, или закончилось с ошибкой. Смотри все логи на все задаиня(только последние строчки) в инсталляцинном каталоге.
СообщениеДобавлено: Пт, май 25 2007, 11:16
Ага! Нашел еще один лог:
Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=EXTPROC0)))
TNS-12541: TNS:no listener
TNS-12560: TNS:protocol adapter error
TNS-00511: No listener
32-bit Windows Error: 2: No such file or directory
Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=server)(PORT=1521)))
32-bit Windows Error: 61: Unknown error
Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=DB1.WORLD)))
Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=IPC)(KEY=DB1)))
Connecting to (DESCRIPTION=(ADDRESS=(COMMUNITY=SAP.WORLD)(PROTOCOL=TCP)(HOST=server)(PORT=1527)))
Что примечательно, SQL+ отказывается конектить по той же причине:
Error:
ORA-12560: TNS:protocol adapter error
хотя сервис ...Listener включен...
думаю дальше..
СообщениеДобавлено: Пт, май 25 2007, 11:48
1) Посмотрите конфигурацию Listener'a по пути: ORACLE_HOME\network\admin\listener.ora там описано какие порты он слушает... и сравните с приведенным логом.
2) ORACLE_HOME\network\log\listener.log - там лог работы Listener'а
И проверить, запущен ли сервис БД.
По проблеме: как правильно сказал spb123 инсталлятор запускает поочередно шаги, причем если одни шаг прошел неудачно, то он всё равно запускает следующие... т.е. в конце нужно проверить все логи шагов и исправить по возможности все ошибки...
СообщениеДобавлено: Пт, май 25 2007, 14:48
проверил все логи, ошибка только в последнем job e.
Отсутствуют таблицы, ... блин
central instance был установлен удачно.
Понять бы на каком этапе должны были создаваться эти таблицы.
СообщениеДобавлено: Пт, май 25 2007, 15:47
Инсталлятор говорит, в скольких шагах были ошибки.
Проверь sapinst.log, там должны быть примерно следующие записи:
INFO 2007-01-20 21:58:00
Working directory changed to C:\Program Files\sapinst_instdir\BW31\SYSTEM\ABAP\ORA\NUC\DB.
ERROR 2007-01-20 21:58:30
MSC-01015 Process finished with error(s), check log file C:\Program Files\sapinst_instdir\BW31\SYSTEM\ABAP\ORA\NUC\DB/SAPAPPL1.log
MSC-01015 Process finished with error(s), check log file C:\Program Files\sapinst_instdir\BW31\SYSTEM\ABAP\ORA\NUC\DB/SAPAPPL0.log
INFO 2007-01-20 21:58:30
Вот логи, где ERROR и надо смотреть, т.е. в моем случае SAPAPPL1.log и SAPAPPL0.log
СообщениеДобавлено: Сб, май 26 2007, 17:59
Сб, мар 17 2007, 16:48
Настоятельно рекомендую перезапустить процесс установки в режиме New. Причем не в удалённой сессии, а в реале. Затем, при финальном экране перед Start , выбрать количество процессов =80 штук. После нескольких часов должно всё завершиться удачно. А вообще то, для квалификации подобных вещей требуется несколько параметров. ОС, РСУБД, SAP INSTANCE... Поподробнее.
Старый глюк, лучше новых двух.
СообщениеДобавлено: Пн, май 28 2007, 11:31
При ошибке ORA-12560: TNS:protocol adapter error , попробуйте прописать переменную окружения: LOCAL=SID (устанавливаемой системы)
