Текущее время: Чт, сен 24 2026, 09:36
 Заголовок сообщения: валится disp+work на Unix
СообщениеДобавлено: Пн, авг 20 2007, 09:14
Пн, авг 20 2007, 09:03
Коллеги, помогите решить проблему... При запуске валится диспетчер, в логе dev_v0:
C Now I'm connected to ORACLE
C Database NLS settings: AMERICAN_AMERICA.WE8DEC
C Database instance BWD is running on paracels with ORACLE version 9.2.0.7.0 since 20070820
B Connection 0 opened
B Wp Hdl ConName ConId ConState TX PRM RCT TIM MAX OPT Date Time DBHost
B 000 000 R/3 000000000 ACTIVE NO YES NO 000 255 255 20070820 110723 paracels
M db_connect o.k.
I MtxInit: 0 0 0
M SHM_PRES_BUF (addr: ffffffff7480a000, size: 4400000)
M SHM_ROLL_AREA (addr: fffffffe63400000, size: 134217728)
I *** ERROR => shmget(11008,67108864,992) (22: Invalid argument) [shmux.c 1407]
M *** ERROR => ThShMCreate: ShmCreate SHM_PAGING_AREA failed [thxxhead.c 2394]
M *** ERROR => ThIPCInit: ThShMCreate [thxxhead.c 1891]
M ***LOG R19=> tskh_init, ThIPCInit ( TSKH-IPC-000001) [thxxhead.c 1359]
M in_ThErrHandle: 1
M *** ERROR => tskh_init: ThIPCInit (step 1, th_errno 17, action 3, level 1) [thxxhead.c 9413]
M
M Info for wp 0
M
M stat = 4
M reqtype = 1
M act_reqtype = -1
M rq_info = 0
M tid = -1
M mode = 255
M len = -1
M rq_id = 65535
M rq_source = 255
M last_tid = 0
M last_mode = 0
M int_checked_resource(RFC) = 0
M ext_checked_resource(RFC) = 0
M int_checked_resource(HTTP) = 0
M ext_checked_resource(HTTP) = 0
M report = > <
M action = 0
M tab_name = > <
M PfStatDisconnect: disconnect statistics
M Entering TH_CALLHOOKS
M ThCallHooks: call hook >ThrSaveSPAFields< for event BEFORE_DUMP
M *** ERROR => ThrSaveSPAFields: no valid thr_wpadm [thxxrun1.c 730]
M *** ERROR => ThCallHooks: event handler ThrSaveSPAFields for event BEFORE_DUMP failed [thxxtool3.c 252]
M Entering ThSetStatError
M Entering ThReadDetachMode
M call ThrShutDown (1)...
M ***LOG Q02=> wp_halt, WPStop (Workproc 0 9657) [dpuxtool.c 322]
cleanipc НЕ ПОМОГ...
СообщениеДобавлено: Пн, авг 20 2007, 09:49
Вт, авг 17 2004, 11:44
До появления проблемы параметры управления памятью не изменяли?
СообщениеДобавлено: Пн, авг 20 2007, 10:00
qdublin написал:
Нет, ничего не меняли, проблема возникла в процессе инсталляции, на двух последних джобах с RFC, вот тогда и увидели..
СообщениеДобавлено: Пн, авг 20 2007, 10:57
На этапе ввода параметров инсталляции, какие значения распределения памяти между инстанциями БД и центральной?
СообщениеДобавлено: Пн, авг 20 2007, 12:59
Всем спасибо, разобрались с проблемой!
 Заголовок сообщения: Re: валится disp+work на Unix
СообщениеДобавлено: Пт, сен 30 2011, 16:39
Пн, май 07 2007, 09:44
Подскажите, пожалуйста, а как решили проблему?
