Текущее время: Ср, сен 23 2026, 19:40
 Заголовок сообщения: Ошибки при инсталяции ERP2005.Кто подскажет что с этим делать?
СообщениеДобавлено: Чт, ноя 29 2007, 21:57
Пн, фев 19 2007, 01:11
Шаг усьановки Install DBA tolls
Кто знает с чем сязваны данные ошибки?
Подскажите плиз.
WARNING 2007-11-30 21:28:37
Execution of the command "D:\j2sdk1.4.2_16-x64\bin\java.exe -classpath migmon.jar -showversion com.sap.inst.migmon.imp.ImportMonitor -dbType ORA -importDirs F:\SAPINST\export\51032272_1\EXP1;F:\SAPINST\export\51032272_1\EXP2;F:\SAPINST\export\51032272_1\EXP3;F:\SAPINST\export\51032272_1\EXP4;F:\SAPINST\export\51032272_1\EXP5;F:\SAPINST\export\51032272_1\EXP6;F:\SAPINST\export\51032272_2\EXP7;F:\SAPINST\export\51032272_2\EXP8;F:\SAPINST\export\51032272_2\EXP9;F:\SAPINST\export\51032272_2\EXP10;F:\SAPINST\export\51032272_2\EXP11 -installDir "D:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS" -orderBy "" -r3loadExe D:\usr\sap\NWS\SYS\exe\uc\NTAMD64\R3load.exe -tskFiles yes -extFiles yes -dbCodepage 4103 -jobNum 3 -monitorTimeout 30 -loadArgs " -stop_on_error" -trace all -sapinst" finished with return code 103. Output:
java version "1.4.2_16"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_16-b05)
Java HotSpot(TM) 64-Bit Server VM (build 1.4.2_16-b05, mixed mode)
Import Monitor jobs: running 1, waiting 20, completed 17, failed 0, total 38.
Import Monitor jobs: running 2, waiting 19, completed 17, failed 0, total 38.
Import Monitor jobs: running 3, waiting 18, completed 17, failed 0, total 38.
Loading of 'SAPAPPL2_2' import package: ERROR
Loading of 'SAPAPPL2_3' import package: ERROR
Import Monitor jobs: running 1, waiting 18, completed 17, failed 2, total 38.
Loading of 'SAPAPPL0_1' import package: ERROR
Import Monitor jobs: running 0, waiting 18, completed 17, failed 3, total 38.
Import Monitor jobs: running 1, waiting 17, completed 17, failed 3, total 38.
Import Monitor jobs: running 2, waiting 16, completed 17, failed 3, total 38.
Import Monitor jobs: running 3, waiting 15, completed 17, failed 3, total 38.
Loading of 'SAPAPPL0_2' import package: ERROR
Loading of 'SAPSSEXC_5' import package: ERRORImport Monitor jobs: running 1, waiting 15, completed 17, failed 5, total 38.
Loading of 'SCPRSVALS' import package: ERROR
Import Monitor jobs: running 0, waiting 15, completed 17, failed 6, total 38.
Import Monitor jobs: running 1, waiting 14, completed 17, failed 6, total 38.
Import Monitor jobs: running 2, waiting 13, completed 17, failed 6, total 38.
Import Monitor jobs: running 3, waiting 12, completed 17, failed 6, total 38.
Loading of 'FUPARAREF' import package: ERROR
Import Monitor jobs: running 2, waiting 12, completed 17, failed 7, total 38.
Loading of 'SAPSSRC' import package: ERROR
Loading of 'SAPSDIC' import package: ERROR
Import Monitor jobs: running 0, waiting 12, completed 17, failed 9, total 38.
Import Monitor jobs: running 1, waiting 11, completed 17, failed 9, total 38.
Import Monitor jobs: running 2, waiting 10, completed 17, failed 9, total 38.
Import Monitor jobs: running 3, waiting 9, completed 17, failed 9, total 38.
Loading of 'SCPRVALS' import package: ERROR
Loading of 'E071K' import package: ERROR
Import Monitor jobs: running 0, waiting 9, completed 17, failed 12, total 38.
Loading of 'SAPAPPL0_4' import package: ERROR
Import Monitor jobs: running 1, waiting 8, completed 17, failed 12, total 38.
Import Monitor jobs: running 2, waiting 7, completed 17, failed 12, total 38.
Import Monitor jobs: running 3, waiting 6, completed 17, failed 12, total 38.
Loading of 'SAPPOOL' import package: ERROR
Loading of 'SAPSPROT' import package: ERROR
Loading of 'SAPSLOAD' import package: ERROR
Import Monitor jobs: running 0, waiting 6, completed 17, failed 15, total 38.
Import Monitor jobs: running 1, waiting 5, completed 17, failed 15, total 38.
Import Monitor jobs: running 2, waiting 4, completed 17, failed 15, total 38.
Import Monitor jobs: running 3, waiting 3, completed 17, failed 15, total 38.
Loading of 'SAPDDIM' import package: ERROR
Loading of 'SAPDFACT' import package: ERROR
Import Monitor jobs: running 0, waiting 3, completed 17, failed 18, total 38.
Loading of 'SAPDODS' import package: ERROR
Import Monitor jobs: running 1, waiting 2, completed 17, failed 18, total 38.
Import Monitor jobs: running 2, waiting 1, completed 17, failed 18, total 38.
Loading of 'SAP0000' import package: ERROR
Import Monitor jobs: running 1, waiting 1, completed 17, failed 19, total 38.
Loading of 'SAPUSER1' import package: ERROR
Import Monitor jobs: running 0, waiting 1, completed 17, failed 20, total 38.
ERROR 2007-11-30 21:28:37
CJS-30022 Program 'Migration Monitor' exits with error code 103. For details see log file(s) import_monitor.java.log, import_monitor.log.
FCO-00011 The step runMigrationMonitor with step key |NW_Onehost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|ind|ind|ind|10|0|NW_ABAP_Import_Dialog|ind|ind|ind|ind|5|0|NW_ABAP_Import|ind|ind|ind|ind|0|0|runMigrationMonitor was executed with status ERROR .
INFO 2007-11-30 21:41:22
An error occured and the user decide to stop.\n Current step "|NW_Onehost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|ind|ind|ind|10|0|NW_ABAP_Import_Dialog|ind|ind|ind|ind|5|0|NW_ABAP_Import|ind|ind|ind|ind|0|0|runMigrationMonitor".
СообщениеДобавлено: Пт, ноя 30 2007, 08:58
Чт, сен 08 2005, 13:23
Посмотрите логи всех заданий, напротив которых стоит ERROR:
SAPAPPL2_2
SAPAPPL2_3
и т.д.
В них описаны сами ошибки. Файлы кажется называются SAPAPPL2_2.log и такой лог к каждому заданию.
Они должны находиться в установочной директории, т.е. откуда запускается sapinst, в вашем случае это "D:\Program Files\sapinst_instdir\ERP\SYSTEM\ORA\CENTRAL\AS". Возможно, что ошибка в одном задании вызовет ошибку в другом(их) задании(ях).
