Текущее время: Ср, сен 23 2026, 14:36
 Заголовок сообщения: Установка Диалоговой инстанции
СообщениеДобавлено: Чт, янв 31 2008, 12:28
Вт, окт 10 2006, 12:23
Здравствуйте! Поставил диалоговую инстанцию...запускаю...пишет в процессе disp+work.exe RUNNING but Message Server unreachable...прописал в файле services порты 3640, 4740, 3240, 3340, 4840. Message Server запустился но потом показал ошибку Running but dialog queue standstill.
В логе пишет следующее:
trc file: "dev_disp", trc level: 1, release: "640"
Thu Jan 31 13:13:21 2008
kernel runs with dp version 130(ext=102) (@(#) DPLIB-INT-VERSION-130)
length of sys_adm_ext is 312 bytes
sysno 41
sid TTP
systemid 560 (PC with Windows NT)
relno 6400
patchlevel 0
patchno 121
intno 20020600
make: multithreaded, ASCII
pid 24456
***LOG Q00=> DpSapEnvInit, DPStart (41 24456) [dpxxdisp.c 1098]
shared lib "dw_xml.dll" version 121 successfully loaded
shared lib "dw_xtc.dll" version 121 successfully loaded
shared lib "dw_stl.dll" version 121 successfully loaded
shared lib "dw_gui.dll" version 121 successfully loaded
shared lib "dw_mdm.dll" version 121 successfully loaded
Thu Jan 31 13:13:33 2008
*** WARNING => DpNetCheck: NiHostToAddr(www.doesnotexist0013.qqq.nxst) took 12 seconds
Thu Jan 31 13:13:50 2008
*** WARNING => DpNetCheck: NiAddrToHost(1.0.0.0) took 17 seconds
***LOG GZZ=> 2 possible network problems detected - check tracefile and adjust the DNS settings [dpxxtool2.c 3893]
MtxInit: -2 0 0
DpSysAdmExtInit: ABAP is active
DpIPCInit2: start server >stt-04_TTP_41 <
DpShMCreate: sizeof(wp_adm) 8280 (828)
DpShMCreate: sizeof(tm_adm) 2379840 (11840)
DpShMCreate: sizeof(wp_ca_adm) 18000 (60)
DpShMCreate: sizeof(appc_ca_adm) 6000 (60)
DpShMCreate: sizeof(comm_adm) 192000 (384)
DpShMCreate: sizeof(vmc_adm) 0 (364)
DpShMCreate: sizeof(wall_adm) (22440/34344/56/100)
DpShMCreate: SHM_DP_ADM_KEY (addr: 05810040, size: 2667104)
DpShMCreate: allocated sys_adm at 05810040
DpShMCreate: allocated wp_adm at 058117D0
DpShMCreate: allocated tm_adm_list at 05813828
DpShMCreate: allocated tm_adm at 05813850
DpShMCreate: allocated wp_ca_adm at 05A58890
DpShMCreate: allocated appc_ca_adm at 05A5CEE0
DpShMCreate: allocated comm_adm_list at 05A5E650
DpShMCreate: allocated comm_adm at 05A5E668
DpShMCreate: allocated vmc_adm_list at 05A8D468
DpShMCreate: system runs without vmc_adm
DpShMCreate: allocated ca_info at 05A8D490
DpShMCreate: allocated wall_adm at 05A8D498
MBUF state OFF
EmInit: MmSetImplementation( 2 ).
<ES> client 0 initializing ....
<ES> InitFreeList
<ES> block size is 1024 kByte.
Using implementation flat
<EsNT> Memory Reset disabled as NT default
<ES> 1499 blocks reserved for free list.
ES initialized.
Thu Jan 31 13:13:51 2008
rdisp/http_min_wait_dia_wp : 1 -> 1
***LOG Q0K=> DpMsAttach, mscon ( stt-05) [dpxxdisp.c 9915]
DpStartStopMsg: send start message (myname is >stt-04_TTP_41 <)
DpStartStopMsg: start msg sent
CCMS: AlInitGlobals : alert/use_sema_lock = TRUE.
CCMS: Initalizing shared memory of size 40000000 for monitoring segment.
CCMS: start to initalize 3.X shared alert area (first segment).
Release check o.K.
MBUF state PREPARED
MBUF component UP
DpMBufHwIdSet: set Hardware-ID
***LOG Q1C=> DpMBufHwIdSet [dpxxmbuf.c 1025]
Thu Jan 31 13:14:31 2008
*** ERROR => W0 (pid 26212) died [dpxxdisp.c 12391]
*** ERROR => W1 (pid 32972) died [dpxxdisp.c 12391]
*** ERROR => W2 (pid 39476) died [dpxxdisp.c 12391]
*** ERROR => W3 (pid 30076) died [dpxxdisp.c 12391]
*** ERROR => W4 (pid 17996) died [dpxxdisp.c 12391]
*** ERROR => W5 (pid 6680) died [dpxxdisp.c 12391]
*** ERROR => W6 (pid 16916) died [dpxxdisp.c 12391]
*** ERROR => W7 (pid 39352) died [dpxxdisp.c 12391]
*** ERROR => W8 (pid 40784) died [dpxxdisp.c 12391]
*** ERROR => W9 (pid 19544) died [dpxxdisp.c 12391]
my types changed after wp death/restart 0x81 --> 0x80
*** DP_FATAL_ERROR => DpWPCheck: no more work processes
*** DISPATCHER EMERGENCY SHUTDOWN ***
increase tracelevel of WPs
killing W0-26212 (SIGUSR2)
*** ERROR => DpWpKill(26212, SIGUSR2) failed [dpxxtool.c 2502]
killing W1-32972 (SIGUSR2)
*** ERROR => DpWpKill(32972, SIGUSR2) failed [dpxxtool.c 2502]
killing W2-39476 (SIGUSR2)
*** ERROR => DpWpKill(39476, SIGUSR2) failed [dpxxtool.c 2502]
killing W3-30076 (SIGUSR2)
*** ERROR => DpWpKill(30076, SIGUSR2) failed [dpxxtool.c 2502]
killing W4-17996 (SIGUSR2)
*** ERROR => DpWpKill(17996, SIGUSR2) failed [dpxxtool.c 2502]
killing W5-6680 (SIGUSR2)
*** ERROR => DpWpKill(6680, SIGUSR2) failed [dpxxtool.c 2502]
killing W6-16916 (SIGUSR2)
*** ERROR => DpWpKill(16916, SIGUSR2) failed [dpxxtool.c 2502]
killing W7-39352 (SIGUSR2)
*** ERROR => DpWpKill(39352, SIGUSR2) failed [dpxxtool.c 2502]
killing W8-40784 (SIGUSR2)
*** ERROR => DpWpKill(40784, SIGUSR2) failed [dpxxtool.c 2502]
killing W9-19544 (SIGUSR2)
*** ERROR => DpWpKill(19544, SIGUSR2) failed [dpxxtool.c 2502]
NiWait: sleep (10000 msecs) ...
NiISelect: timeout 10000 ms
NiISelect: maximum fd=1613
NiISelect: read-mask is NULL
NiISelect: write-mask is NULL
Thu Jan 31 13:14:41 2008
NiISelect: TIMEOUT occured (10000 ms)
dump system status
Workprocess Table (long) Thu Jan 31 09:14:41 2008
No Ty. Pid Status Cause Start Err Sem CPU Time Program Cl User Action Table
0 DIA 26212 Ended no 1 0 0
1 DIA 32972 Ended no 1 0 0
2 DIA 39476 Ended no 1 0 0
3 DIA 30076 Ended no 1 0 0
4 DIA 17996 Ended no 1 0 0
5 DIA 6680 Ended no 1 0 0
6 DIA 16916 Ended no 1 0 0
7 DIA 39352 Ended no 1 0 0
8 DIA 40784 Ended no 1 0 0
9 DIA 19544 Ended no 1 0 0
Dispatcher Queue Statistics Thu Jan 31 09:14:41 2008
| Typ | now | high | max | writes | reads |
| NOWP | 0 | 3 | 2000 | 10 | 10 |
| DIA | 5 | 5 | 2000 | 5 | 0 |
| UPD | 0 | 0 | 2000 | 0 | 0 |
| ENQ | 0 | 0 | 2000 | 0 | 0 |
| BTC | 0 | 0 | 2000 | 0 | 0 |
| SPO | 0 | 0 | 2000 | 0 | 0 |
| UP2 | 0 | 0 | 2000 | 0 | 0 |
max_rq_id 12
wake_evt_udp_now 0
wake events total 9, udp 8 ( 88%), shm 1 ( 11%)
since last update total 9, udp 8 ( 88%), shm 1 ( 11%)
Dump of tm_adm structure: Thu Jan 31 09:14:41 2008
Term uid man user term lastop mod wp ta a/i (modes)
Workprocess Comm. Area Blocks Thu Jan 31 09:14:41 2008
Slots: 300, Used: 1, Max: 0
| id | owner | pid | eyecatcher |
| 0 | DISPATCHER | -1 | *WPCAAD000* |
NiWait: sleep (5000 msecs) ...
NiISelect: timeout 5000 ms
Thu Jan 31 13:14:46 2008
NiISelect: TIMEOUT occured (5000 ms)
DpHalt: shutdown server >stt-04_TTP_41 < (normal)
DpJ2eeDisableRestart
DpModState: buffer in state MBUF_PREPARED
NiBufSend starting
NiIWrite: write 110, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 110 bytes
MsIModState: change state to SHUTDOWN
DpModState: change server state from STARTING to SHUTDOWN
Switch off Shared memory profiling
ShmProtect( 57, 3 )
ShmProtect(SHM_PROFILE, SHM_PROT_RW
ShmProtect( 57, 1 )
ShmProtect(SHM_PROFILE, SHM_PROT_RD
DpWakeUpWps: wake up all wp's
Stop work processes...
Stop gateway
killing process (31384) (SOFT_KILL)
Stop icman
killing process (22244) (SOFT_KILL)
Terminate gui connections
[DpProcDied] Process lives (PID:31384 HANDLE:1592)
waiting for termination of gateway
NiWait: sleep (1000 msecs) ...
NiISelect: timeout 1000 ms
Thu Jan 31 13:14:47 2008
NiISelect: TIMEOUT occured (1000 ms)
[DpProcDied] Process died (PID:31384 HANDLE:1592)
[DpProcDied] Process lives (PID:22244 HANDLE:1596)
waiting for termination of icman
Thu Jan 31 13:14:48 2008
Thu Jan 31 13:14:49 2008
Thu Jan 31 13:14:50 2008
Thu Jan 31 13:14:51 2008
Thu Jan 31 13:14:52 2008
Thu Jan 31 13:14:53 2008
Thu Jan 31 13:14:54 2008
Thu Jan 31 13:14:55 2008
Thu Jan 31 13:14:56 2008
Thu Jan 31 13:14:57 2008
[DpProcDied] Process died (PID:22244 HANDLE:1596)
DpHalt: cancel all lcom connections
MPI CancelAll 2 -> 0
MPI DeleteAll 2 -> 0
DpStartStopMsg: send stop message (myname is >stt-04_TTP_41 <)
NiIMyHostName: hostname = 'stt-04'
AdGetSelfIdentRecord: > <
AdCvtRecToExt: opcode 60 (AD_SELFIDENT), ser 0, ex 0, errno 0
AdCvtRecToExt: opcode 4 (AD_STARTSTOP), ser 0, ex 0, errno 0
DpConvertRequest: net size = 163 bytes
NiBufSend starting
NiIWrite: write 562, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 562 bytes
send msg (len 110+452) to name -, type 4, key -
DpStartStopMsg: stop msg sent
NiIRead: read 229, 1 packs, MESG_IO, hdl 3, data complete
NiBufIn: NIBUF len=229
NiBufIn: Packet complete for hdl 3
NiBufReceive starting
MsINiRead: received 229 bytes
MSG received, len 110+119, flag 1, from MSG_SERVER, typ 0, key -
DpHalt: received 119 bytes from message server
NiPRead: WSAEWOULDBLOCK 1.time 4
NiIPeek: peek for hdl 3 / socket 1600 timed out (r; 0)
DpHalt: no more messages from the message server
DpHalt: send keepalive to synchronize with the message server
NiBufSend starting
NiIWrite: write 114, 1 packs, MESG_IO, hdl 3, data complete
MsINiWrite: sent 114 bytes
send msg (len 110+4) to name MSG_SERVER, type 0, key -
MsSndName: MS_NOOP ok
Send 4 bytes to MSG_SERVER
NiIRead: read 114, 1 packs, MESG_IO, hdl 3, data complete
NiBufIn: NIBUF len=114
MsINiRead: received 114 bytes
MSG received, len 110+4, flag 3, from MSG_SERVER, typ 0, key -
Received 4 bytes from MSG_SERVER
Received opcode MS_NOOP from msg_server, reply MSOP_OK
MsOpReceive: ok
MsSendKeepalive : keepalive sent to message server
Thu Jan 31 13:14:58 2008
NiIPeek: peek for hdl 3 / socket 1600 timed out (r; 1000)
DpHalt: sync with message server o.k.
detach from message server
***LOG Q0M=> DpMsDetach, ms_detach () [dpxxdisp.c 10141]
NiBufSend starting
MsIDetach: send logout to msg_server
MsIDetach: call exit function
DpMsShutdownHook called
NiSelClear: removed hdl 3 from selectset
MBUF state OFF
AdCvtRecToExt: opcode 40 (AD_MSBUF), ser 0, ex 0, errno 0
blks_in_queue/wp_ca_blk_no/wp_max_no = 1/300/10
LOCK WP ca_blk 1
make DISP owner of wp_ca_blk 1
DpRqPutIntoQueue: put request into queue (reqtype 1, prio LOW, rq_id 18)
MBUF component DOWN
NiBufClose: clear extensions for hdl 3
NiBufSetStat: bufstat of hdl 3 changed from OK to OFF
NiICloseHandle: shutdown and close hdl 3 / socket 1600
MsIDetach: detach MS-system
EsCleanup ....
***LOG Q05=> DpHalt, DPStop ( 24456) [dpxxdisp.c 8643]
Good Bye .....
Что не нравицца?)
СообщениеДобавлено: Чт, янв 31 2008, 12:47
база MSSQL
система SAP ERP Central Component 5.0
СообщениеДобавлено: Чт, янв 31 2008, 12:59
проблема решена...надо было ещё файлик dbmssslib.dll перенести
СообщениеДобавлено: Пн, фев 04 2008, 15:00
Пт, ноя 16 2007, 22:18
Ctrelok написал:
А куда надо было перенести?...
СообщениеДобавлено: Вт, фев 05 2008, 11:25
из \usr\sap\<SID>\SYS\exe\run CI в \usr\sap\<SID>\SYS\exe\run DI.
