Текущее время: Чт, сен 24 2026, 13:07
 Заголовок сообщения: Не стартует J2EE Server
СообщениеДобавлено: Пт, фев 08 2008, 13:14
Вт, авг 28 2007, 10:17
Добрый день, Господа!
CompilerOracle: exclude com/sapportals/portal/pb/layout/taglib/ContainerTag addIviewResources
CompilerOracle: exclude com/sap/engine/services/keystore/impl/security/CodeBasedSecurityConnector getApplicationDomain
CompilerOracle: exclude com/sap/engine/services/rmi_p4/P4StubSkeletonGenerator generateStub
CompilerOracle: exclude com/sapportals/portal/prt/util/StringUtils escapeToJS
CompilerOracle: exclude com/sapportals/portal/prt/core/broker/PortalServiceItem startServices
CompilerOracle: exclude com/sap/engine/services/webservices/server/deploy/WSConfigurationHandler downloadFile
CompilerOracle: exclude com/sapportals/portal/prt/jndisupport/util/AbstractHierarchicalContext lookup
[Thr 5392] JHVM_LoadJavaVM: Java VM created OK.
JHVM_BuildArgumentList: main method arguments of node [server0]
[Thr 5576] Fri Feb 08 12:57:21 2008
[Thr 5576] JHVM_RegisterNatives: registering methods in com.sap.bc.krn.perf.PerfTimes
[Thr 5576] JHVM_RegisterNatives: registering methods in com.sap.bc.proj.jstartup.JStartupFramework
[Thr 5576] JLaunchISetClusterId: set cluster id 2833950
[Thr 5576] JLaunchISetState: change state from [Initial (0)] to [Waiting for start (1)]
[Thr 5576] JLaunchISetState: change state from [Waiting for start (1)] to [Starting (2)]
[Thr 2388] Fri Feb 08 12:57:34 2008
[Thr 2388] JHVM_RegisterNatives: registering methods in com.sap.mw.rfc.driver.CpicDriver
[Thr 2388] JHVM_RegisterNatives: registering methods in com.sap.i18n.cp.ConverterJNI
[Thr 5472] Fri Feb 08 12:57:35 2008
[Thr 5472] JLaunchIExitJava: exit hook is called (rc = -11113)
[Thr 5472] **********************************************************************
*** ERROR => The Java VM terminated with a non-zero exit code.
*** Please see SAP Note 943602 , section 'J2EE Engine exit codes'
*** for additional information and trouble shooting.
[Thr 5472] JLaunchCloseProgram: good bye (exitcode = -11113)
Просмотр SAP Note 943602 ничего не дал.
Есть соображения?
СообщениеДобавлено: Пт, фев 08 2008, 14:25
Вт, авг 17 2004, 11:44
Источник данных для UME какой?
СообщениеДобавлено: Пт, фев 08 2008, 14:30
Ср, ноя 17 2004, 18:38
Что пишет в логах dev_dispatcher, dev_server0, jvm_* ? Вообще смотрим все логи от старта java инстанции.
СообщениеДобавлено: Пн, фев 11 2008, 11:56
Снес JavaAddIn и поставил заново. заработало.
Но заметил странностоь - после установки SP11 на Java ADS - перестает работать. Пока не разбирался почему, просто переустановил без патча.
СообщениеДобавлено: Пт, апр 11 2008, 07:52
Ср, фев 21 2007, 16:03
GRRinat написал:
у меня возникла точно такая же проблема, только не понятно лечение: фраза "Снес JavaAddIn" означает - удаление JavaAddIn через sapinst, а затем новая инсталляция с нуля JavaAddIn?
СообщениеДобавлено: Пт, апр 11 2008, 10:43
Пн, ноя 07 2005, 15:59
где-то попадались сообщения, будто профиль может затираться.
СообщениеДобавлено: Пт, апр 11 2008, 11:00
korchagin написал:
профиль чего? ABAP инстанции или J2EE инстанции?
СообщениеДобавлено: Пт, апр 11 2008, 22:05
J2EE, конечно (в /usr/sap/<SID>/SYS/profile/)
СообщениеДобавлено: Вс, апр 13 2008, 08:25
NikolayGr написал(а):
GRRinat написал:
В моем случае была установка ABAP+J2EE в одном флаконе, деинсталлировать ТОЛЬКО J2EE не представляется возможным. А может быть мне попробовать инсталляцию J2EE как дополнительной инстанции? Какие есть мнения?
СообщениеДобавлено: Ср, апр 16 2008, 15:02
Сперва у меня была установлена инстанция ABAP.
Потом выяснилось что планируется активное использование ADS.
Пришлось ставить JavaAddIn к уже установленному ABAP.
Соответственно удаление JavaAddIn через sapinst и повторная установка Java помогла... )))
СообщениеДобавлено: Чт, апр 17 2008, 07:31
GRRinat написал:
к сожалению, у меня не было такой возможности, пришлось целую неделю кувыркаться, зато нашел причину проблемы и решение без "хирургических" методов
СообщениеДобавлено: Чт, апр 17 2008, 10:37
ну так поделитесь опытом
СообщениеДобавлено: Чт, апр 17 2008, 11:51
korchagin написал:
Это была уникальная проблема, т.к. на сервер помимо NW было установлено стороннее ПО(конкретно JBASE) - оно все и переломало, восстановление заключалось, например, в восстановлении нужной версии явы, переменных окружения <SID>adm и т.д., хотя ошибка была точно такая же...
