Текущее время: Чт, сен 24 2026, 20:58
Начать новую тему Ответить на тему  [ Сообщений: 25 ]  На страницу 1, 2  След.
 Заголовок сообщения: Восстановление системы с помощью brtools
СообщениеДобавлено: Чт, май 22 2008, 12:53
Пн, янв 14 2008, 19:11
Возникла необходимость востановить систему.
saperp1:~ # su oraerp
saperp1:oraerp 51> brtools
BR0651I BRTOOLS 7.00 (28)
BR0280I BRTOOLS time stamp: 2008-05-22 13.52.31
BR0656I Choice menu 1 - please make a selection
BR*Tools main menu
1 = Instance management
2 - Space management
3 - Segment management
4 - Backup and database copy
5 - Restore and recovery
6 - Check and verification
7 - Database statistics
8 - Additional functions
9 - Exit program
Standard keys: c - cont, b - back, s - stop, r - refr, h - help
BR0662I Enter your choice:
5
BR0280I BRTOOLS time stamp: 2008-05-22 13.55.57
BR0663I Your choice: '5'
BR0656I Choice menu 11 - please make a selection
1 = Complete database recovery
2 - Database point-in-time recovery
3 - Tablespace point-in-time recovery
4 - Whole database reset
5 - Restore of individual backup files
6 - Restore and application of archivelog files
7 - Disaster recovery
8 - Reset program status
4
BR0280I BRTOOLS time stamp: 2008-05-22 13.56.13
BR0663I Your choice: '4'
BR0657I Input menu 34 - please check/enter input values
BRRECOVER options for restore and recovery
1 * Recovery type (type) ............. [reset]
2 - BRRECOVER profile (profile) ...... [initERP.sap]
3 ~ BACKINT/Mount profile (parfile) .. []
4 - Database user/password (user) .... [/]
5 - Recovery interval (interval) ..... [30]
6 - Confirmation mode (confirm) ...... [yes]
7 - Scrolling line count (scroll) .... [20]
8 - Message language (language) ...... [E]
9 - BRRECOVER command line (command) . [-p initERP.sap -t reset -i 30 -s 20 -l
E]
c
BR0280I BRTOOLS time stamp: 2008-05-22 13.56.26
BR0663I Your choice: 'c'
BR0259I Program execution will be continued...
BR0291I BRRECOVER will be started with options '-p initERP.sap -t reset -i 30 -s
20 -l E'
BR0670I Enter 'c[ont]' to continue, 'b[ack]' to go back, 's[top]' to abort:
c
BR0280I BRTOOLS time stamp: 2008-05-22 13.56.37
BR0257I Your reply: 'c'
BR0701I BRRECOVER 7.00 (28)
BR0705I Start of database recovery: vdxzakcj.drs 2008-05-22 13.56.37
BR0484I BRRECOVER log file: /oracle/ERP/sapbackup/vdxzakcj.drs
BR0280I BRRECOVER time stamp: 2008-05-22 13.56.37
BR0707I Recovery of database: ERP
BR0708I BRRECOVER action ID: vdxzakcj
BR0709I BRRECOVER function ID: drs
BR0710I Recovery type: reset
BR0655I Control menu 109 - please decide how to proceed
Whole database reset main menu
1 = Select consistent database backup
2 * Check the status of database files
3 * Restore control files and redolog files
4 * Restore data files
5 * Restore and apply incremental backup
6 * Apply archivelog files
7 * Open database and post-processing
8 * Exit program
9 - Reset program status
c
BR0280I BRRECOVER time stamp: 2008-05-22 13.57.02
BR0699I Reading log file /oracle/ERP/sapbackup/backERP.log ...
BR0730W No appropriate backup created since 2008-04-23 00.00.00 found in /oracle
BR0417E No files found for restore/verification
BR0669I Cannot continue due to previous warnings or errors - you can go back to
repeat the last action
BR0671I Enter 'b[ack]' to go back, 's[top]' to abort:
c
BR0280I BRRECOVER time stamp: 2008-05-22 13.57.10
BR0258W Wrong reply: 'c'
BR0280I BRRECOVER time stamp: 2008-05-22 13.57.31
Почему так?
СообщениеДобавлено: Чт, май 22 2008, 13:12
Вт, апр 10 2007, 14:59
Так в чем именно проблема?
BrTools не находит ни одного бэкапа, за последние 30 дней (именно столько у тебя указано в параметрах). Когда был создан бэкап, с которого хочешь восстанавливаться?
СообщениеДобавлено: Чт, май 22 2008, 13:14
Чт, окт 12 2006, 11:32
"saperp1:~ # su oraerp"
И неудивительно, что возникла =))
В этот понедельник.
И причем он не находит это в своем логе.
Бекапы нормальные, смотрю в db13 - отработали без ошибок.
СообщениеДобавлено: Чт, май 22 2008, 13:15
А как надо?
СообщениеДобавлено: Чт, май 22 2008, 13:24
А как надо?
Не видит он у тебя файла. Сам, на всякий случай проверь, есть там запись о бэкапе.
Ну, а звезда намекает тебе на su erpadm...
СообщениеДобавлено: Чт, май 22 2008, 13:29
А как надо?
Запись есть, oraerp имеет доступ к файлу лога бекапов.
А под erpadm не получается
BR0252E Function remove() failed for '/oracle/ERP/sapbackup/.user.pas' at locati
on global_set-5
BR0253E errno 13: Permission denied
BR0280I BRRECOVER time stamp: 2008-05-22 14.31.45
BR0700E Fatal errors occurred - terminating processing...
BR0797I Number of restored/recovered database files: 0/0
BR0798I Number of restored/applied incremental files: 0/0
BR0799I Number of restored/applied archivelog files: 0/0
BR0706I End of database recovery: vdxzanfl.log 2008-05-22 14.31.45
BR0704I BRRECOVER terminated with errors
так скажите под каким пользователем надо восстанавливать oraerp или erpadm?
СообщениеДобавлено: Чт, май 22 2008, 13:31
Еще "звезда" намекает обновить brtools.
Восстанавливаться под рутом.
СообщениеДобавлено: Чт, май 22 2008, 13:35
под root'ом не видет brtools
saperp1:~ # brtools
bash: brtools: command not found
СообщениеДобавлено: Чт, май 22 2008, 14:55
saperp1:~ # brtools
Так-с... посмотрел доку.. все-таки подходы в зависимости от оси отличаются:)
"You have to have SYSDBA privilege to let BRRECOVER connect to the database. This means that you have to log on as ora<sid> (UNIX) or <sid>adm (Windows)."
Так что начал ты правильно.
Покажи файл /oracle/ERP/sapbackup/backERP.log
СообщениеДобавлено: Чт, май 22 2008, 16:44
saperp1:~ # brtools
online tape a----d 7.00 (28)
bdxwlfsn ant 2008-05-08 22.00.45 2008-05-08 22.32.54 0 ............... 4
4 43 0 2571 29788816 2572 29818130 ALL
bdxwvbiv ant 2008-05-10 22.00.49 2008-05-10 22.00.51 5 ............... 4
4 0 0 2577 29984816 0 0 ALL
bdxwwmqc dbv 2008-05-11 05.00.50 2008-05-11 05.18.25 1 ............... 4
4 43 0 2578 30015715 0 0 ALL
online null ----dg 7.00 (28)
bdxxheep ant 2008-05-13 09.07.59 2008-05-13 09.40.21 0 ............... 4
4 43 0 2715 31389556 2717 31404554 ALL
bdxxiasu ant 2008-05-13 13.22.00 2008-05-13 13.22.06 5 ............... 4
4 0 0 2825 32212984 0 0 ALL
bdxxibbz ant 2008-05-13 13.25.59 2008-05-13 13.59.06 0 ............... 4
4 43 0 2825 32212984 2832 32241162 ALL
bdxxjusf ant 2008-05-13 22.00.01 2008-05-13 22.48.07 5 ............... 4
4 43 0 2902 32621628 2904 32798746 ALL
bdxxmgle ant 2008-05-14 09.58.02 2008-05-14 10.31.07 0 ............... 4
4 43 0 2905 32827104 2906 32830201 ALL
bdxxosnj ant 2008-05-14 22.00.03 2008-05-14 22.32.57 0 ............... 4
4 43 0 3254 34713855 3255 34869361 ALL
bdxxtqin ant 2008-05-15 22.00.05 2008-05-15 22.32.39 0 ............... 4
4 43 0 3302 35183963 3303 35331449 ALL
bdxydmah ant 2008-05-17 22.00.47 2008-05-17 22.00.50 5 ............... 4
4 0 0 3309 35561976 0 0 ALL
bdxyexho dbv 2008-05-18 05.00.48 2008-05-18 05.17.50 1 ............... 4
4 43 0 3310 35594540 0 0 ALL
bdxynhqp ant 2008-05-19 22.00.51 2008-05-19 22.25.50 0 ............... 4
4 43 0 3316 35720274 3317 35753787 ALL
bdxysfkq ant 2008-05-20 22.00.24 2008-05-20 22.00.47 5 ............... 4
4 0 0 3436 36754542 0 0 ALL
bdxyvxmo ant 2008-05-21 16.02.50 2008-05-21 16.26.58 0 ............... 4
4 43 0 3461 37033427 3462 37064096 ALL
bdxzafzu dbv 2008-05-22 13.10.26 2008-05-22 13.24.29 1 ............... 4
4 43 0 3467 37133002 0 0 ALL
СообщениеДобавлено: Чт, май 22 2008, 16:49
Сделал update BRTOOLS 7.10 (9)
Не помогло.
СообщениеДобавлено: Чт, май 22 2008, 17:03
Чт, сен 08 2005, 13:23
На сколько я понимаю, на последнем экране выбора в brtools необходимо нажать цифру "1" и выбрать бэкап, из которого Вы хотите восстановить. Вместо этого Вы нажимаете "c"...
СообщениеДобавлено: Чт, май 22 2008, 17:07
Vadimus написал:
1 = Select database backup or restore point
7 * Restore archivelog files and flashback
8 * Open database and post-processing
9 * Exit program
10 - Reset program status
1
BR0280I BRRECOVER time stamp: 2008-05-22 18.13.43
BR0663I Your choice: '1'
Результат тотже.
СообщениеДобавлено: Чт, май 22 2008, 17:10
У тебя бэкапы - онлайн. Выбирай другой тип восстановления.
