Текущее время: Чт, сен 24 2026, 17:45
Начать новую тему Ответить на тему  [ Сообщений: 24 ]  На страницу 1, 2  След.
 Заголовок сообщения: Проблемы с J2EE
СообщениеДобавлено: Чт, сен 25 2008, 13:02
Пн, янв 14 2008, 19:11
Такая же ошибка как тут: http://sapboard.ru/forum/viewtopic.php?t=34060&highlight=devdispatcher
Не стартует java инстанция
ПОМОГИТЕ!!!!
trc file: "/usr/sap/ERP/DVEBMGS05/work/dev_server0", trc level: 1, release: "700"
node name : ID58367650
pid : 28417
system name : ERP
system nr. : 05
started at : Thu Sep 25 12:21:08 2008
arguments :
arg[00] : /usr/sap/ERP/DVEBMGS05/exe/jlaunch
arg[01] : pf=/usr/sap/ERP/SYS/profile/ERP_DVEBMGS05_saperp1
arg[02] : -DSAPINFO=ERP_05_server
arg[03] : pf=/usr/sap/ERP/SYS/profile/ERP_DVEBMGS05_saperp1
arg[04] : -DSAPSTART=1
arg[05] : -DCONNECT_PORT=62237
arg[06] : -DSAPSYSTEM=05
arg[07] : -DSAPSYSTEMNAME=ERP
arg[08] : -DSAPMYNAME=saperp1_ERP_05
arg[09] : -DSAPPROFILE=/usr/sap/ERP/SYS/profile/ERP_DVEBMGS05_saperp1
arg[10] : -DFRFC_FALLBACK=ON
arg[11] : -DFRFC_FALLBACK_HOST=localhost
[Thr 47569690643168] Thu Sep 25 12:21:08 2008
[Thr 47569690643168] *** WARNING => INFO: Unknown property [instance.box.number=ERPDVEBMGS05saperp1] [jstartxx_mt. 841]
[Thr 47569690643168] *** WARNING => INFO: Unknown property [instance.en.host=saperp1] [jstartxx_mt. 841]
[Thr 47569690643168] *** WARNING => INFO: Unknown property [instance.en.port=3206] [jstartxx_mt. 841]
[Thr 47569690643168] *** WARNING => INFO: Unknown property [instance.system.id=5] [jstartxx_mt. 841]
JStartupReadInstanceProperties: read instance properties [/usr/sap/ERP/DVEBMGS05/j2ee/cluster/instance.properties]
-> ms host : saperp1
-> ms port : 3906
-> OS libs : /usr/sap/ERP/DVEBMGS05/j2ee/os_libs
-> Admin URL :
-> run mode : normal
-> run action : NONE
-> enabled : yes
Used property files
-> files [00] : /usr/sap/ERP/DVEBMGS05/j2ee/cluster/instance.properties
Instance properties
-> ms port : 3906
-> os libs : /usr/sap/ERP/DVEBMGS05/j2ee/os_libs
-> admin URL :
-> enabled : yes
Bootstrap nodes
-> [00] bootstrap : /usr/sap/ERP/DVEBMGS05/j2ee/cluster/instance.properties
-> [01] bootstrap_ID58367600 : /usr/sap/ERP/DVEBMGS05/j2ee/cluster/instance.properties
-> [02] bootstrap_ID58367650 : /usr/sap/ERP/DVEBMGS05/j2ee/cluster/instance.properties
Worker nodes
-> [00] ID58367600 : /usr/sap/ERP/DVEBMGS05/j2ee/cluster/instance.properties
-> [01] ID58367650 : /usr/sap/ERP/DVEBMGS05/j2ee/cluster/instance.properties
[Thr 47569690643168] JLaunchRequestQueueInit: create named pipe for ipc
[Thr 47569690643168] JLaunchRequestQueueInit: create pipe listener thread
[Thr 1083185472] WaitSyncSemThread: Thread 1083185472 started as semaphore monitor thread.
[Thr 1074792768] JLaunchRequestFunc: Thread 1074792768 started as listener thread for np messages.
[Thr 47569690643168] SigISetDefaultAction : default handling for signal 17
[Thr 47569690643168] NiInit3: NI already initialized; param 'maxHandles' ignored (1;202)
[Thr 47569690643168] CPIC (version=700.2006.09.13)
[Thr 47569690643168] *** WARNING => Maximum Java heap size specified twice (through maxHeapSize and in javaParameters) - using -Xmx2048m [jstartxx_mt. 2604]
[Thr 47569690643168] [Node: server0] java home is set by profile parameter
Java Home: /opt/IBMJava2-amd64-142
[Thr 47569690643168] JStartupICheckFrameworkPackage: can't find framework package /usr/sap/ERP/DVEBMGS05/exe/jvmx.jar
JStartupIReadSection: read node properties [ID58367650]
-> node name : server0
-> node type : server
-> node execute : yes
-> jlaunch parameters :
-> java path : /opt/IBMJava2-amd64-142
-> java parameters : -Xgcpolicy:gencon -verbose:gc -Xtrace -Djava.security.policy=./java.policy -Djava.security.egd=file:/dev/urandom -Dorg.omg.CORBA.ORBClass=com.sap.engine.system.ORBProxy -Dorg.omg.CORBA.ORBSingletonClass=com.sap.engine.system.ORBSingletonProxy -Djavax.rmi.CORBA.PortableRemoteObjectClass=com.sap.engine.system.PortableRemoteObjectProxy -Djco.jarm=1 -Xmn400m -Dorg.omg.PortableInterceptor.ORBInitializerClass.com.sap.engine.services.ts.jts.ots.PortableInterceptor.JTSInitializer -Xdisableexplicitgc
-> java vm version : J2RE 1.4.2 IBM J9 2.2 Linux amd64-64 j9xa64142ifx-20070808 (JIT enabled)
-> java vm vendor : IBM J9SE VM (IBM Corporation)
-> java vm type : <default>
-> java vm cpu : amd64
-> heap size : 2048M
-> init heap size : 2048M
-> root path : /usr/sap/ERP/DVEBMGS05/j2ee/cluster/server0
-> class path : ./bin/boot/boot.jar:./bin/boot/jaas.jar:./bin/system/bytecode.jar:.
-> OS libs path : /usr/sap/ERP/DVEBMGS05/j2ee/os_libs
-> main class : com.sap.engine.boot.Start
-> framework class : com.sap.bc.proj.jstartup.JStartupFramework
-> registr. class : com.sap.bc.proj.jstartup.JStartupNatives
-> framework path : /usr/sap/ERP/DVEBMGS05/exe/jstartup.jar:/usr/sap/ERP/DVEBMGS05/exe/jvmx.jar
-> shutdown class : com.sap.engine.boot.Start
-> parameters :
-> debuggable : no
-> debug mode : no
-> debug port : 50521
-> shutdown timeout : 120000
[Thr 47569690643168] JLaunchISetDebugMode: set debug mode [no]
[Thr 1084238144] JLaunchIStartFunc: Thread 1084238144 started as Java VM thread.
JHVM_LoadJavaVM: VM Arguments of node [server0]
-> stack : 1048576 Bytes
-> arg[ 0]: exit
-> arg[ 1]: abort
-> arg[ 2]: vfprintf
-> arg[ 3]: -Xgcpolicy:gencon
-> arg[ 4]: -verbose:gc
-> arg[ 5]: -Xtrace
-> arg[ 6]: -Djava.security.policy=./java.policy
-> arg[ 7]: -Djava.security.egd=file:/dev/urandom
-> arg[ 8]: -Dorg.omg.CORBA.ORBClass=com.sap.engine.system.ORBProxy
-> arg[ 9]: -Dorg.omg.CORBA.ORBSingletonClass=com.sap.engine.system.ORBSingletonProxy
-> arg[ 10]: -Djavax.rmi.CORBA.PortableRemoteObjectClass=com.sap.engine.system.PortableRemoteObjectProxy
-> arg[ 11]: -Djco.jarm=1
-> arg[ 12]: -Xmn400m
-> arg[ 13]: -Dorg.omg.PortableInterceptor.ORBInitializerClass.com.sap.engine.services.ts.jts.ots.PortableInterceptor.JTSInitializer
-> arg[ 14]: -Xdisableexplicitgc
-> arg[ 15]: -Dsys.global.dir=/usr/sap/ERP/SYS/global
-> arg[ 16]: -Dapplication.home=/usr/sap/ERP/DVEBMGS05/exe
-> arg[ 17]: -Djava.class.path=/usr/sap/ERP/DVEBMGS05/exe/jstartup.jar:/usr/sap/ERP/DVEBMGS05/exe/jvmx.jar:./bin/boot/boot.jar:./bin/boot/jaas.jar:./bin/system/bytecode.jar:.
-> arg[ 18]: -Djava.library.path=/opt/IBMJava2-amd64-142/jre/bin:/opt/IBMJava2-amd64-142/jre/bin:/opt/IBMJava2-amd64-142/jre/bin:/opt/IBMJava2-amd64-142/jre/bin/j9vm:/opt/IBMJava2-amd64-142/jre/bin:/usr/sap/ERP/DVEBMGS05/exe:/usr/sap/ERP/DVEBMGS05/exe:/usr/sap/ERP/DVEBMGS05/exe:/tmp/sapinst_exe.660.1193288866:/usr/sap/ERP/SYS/exe/run:/oracle/client/10x_64/instantclient:/usr/lib:/usr/sap/ERP/DVEBMGS05/j2ee/os_libs:/usr/sap/ERP/DVEBMGS05/exe:/usr/sap/ERP/DVEBMGS05/exe:/usr/sap/ERP/DVEBMGS05/exe:/usr/sap/ERP/SYS/exe/run:/oracle/client/10x_64/instantclient
-> arg[ 19]: -Dmemory.manager=2048M
-> arg[ 20]: -Xmx2048M
-> arg[ 21]: -Xms2048M
-> arg[ 22]: -DLoadBalanceRestricted=no
-> arg[ 23]: -Djstartup.mode=JCONTROL
-> arg[ 24]: -Djstartup.ownProcessId=28417
-> arg[ 25]: -Djstartup.ownHardwareId=R0403265906
-> arg[ 26]: -Djstartup.whoami=server
-> arg[ 27]: -Djstartup.debuggable=no
-> arg[ 28]: -DSAPINFO=ERP_05_server
-> arg[ 29]: -DSAPSTART=1
-> arg[ 30]: -DCONNECT_PORT=62237
-> arg[ 31]: -DSAPSYSTEM=05
-> arg[ 32]: -DSAPSYSTEMNAME=ERP
-> arg[ 33]: -DSAPMYNAME=saperp1_ERP_05
-> arg[ 34]: -DSAPPROFILE=/usr/sap/ERP/SYS/profile/ERP_DVEBMGS05_saperp1
-> arg[ 35]: -DFRFC_FALLBACK=ON
-> arg[ 36]: -DFRFC_FALLBACK_HOST=localhost
-> arg[ 37]: -DSAPSTARTUP=1
-> arg[ 38]: -DSAPSYSTEM=05
-> arg[ 39]: -DSAPSYSTEMNAME=ERP
-> arg[ 40]: -DSAPMYNAME=saperp1_ERP_05
-> arg[ 41]: -DSAPDBHOST=saperp1
-> arg[ 42]: -Dj2ee.dbhost=saperp1
[Thr 1084238144] JHVM_LoadJavaVM: Java VM created OK.
JHVM_BuildArgumentList: main method arguments of node [server0]
[Thr 1094478144] Thu Sep 25 12:21:10 2008
[Thr 1094478144] JHVM_RegisterNatives: registering methods in com.sap.bc.krn.perf.PerfTimes
[Thr 1094478144] JHVM_RegisterNatives: registering methods in com.sap.bc.proj.jstartup.JStartupFramework
[Thr 1094478144] JLaunchISetClusterId: set cluster id 58367650
[Thr 1094478144] Thu Sep 25 12:21:11 2008
[Thr 1094478144] JLaunchISetState: change state from [Initial (0)] to [Waiting for start (1)]
[Thr 1094478144] JLaunchISetState: change state from [Waiting for start (1)] to [Starting (2)]
[Thr 1128024384] Thu Sep 25 12:21:23 2008
[Thr 1128024384] JHVM_RegisterNatives: registering methods in com.sap.mw.rfc.driver.CpicDriver
[Thr 1128024384] JHVM_RegisterNatives: registering methods in com.sap.i18n.cp.ConverterJNI
[Thr 1128024384] JLaunchIExitJava: exit hook is called (rc = -11113)
[Thr 1128024384] **********************************************************************
*** ERROR => The Java VM terminated with a non-zero exit code.
*** Please see SAP Note 943602 , section 'J2EE Engine exit codes'
*** for additional information and trouble shooting.
[Thr 1128024384] SigISetIgnoreAction : SIG_IGN for signal 17
[Thr 1128024384] JLaunchCloseProgram: good bye (exitcode = -11113)
СообщениеДобавлено: Чт, сен 25 2008, 14:38
если по шагам, то проверь:
1. В ABAP пользователей J2EE_ADMIN, J2EE_GUEST, чтоб были активны и имели полномочия
2. параметры по ноте 723909 (Note 723909 - Java VM settings for J2EE 6.40/7.0)
думаю что этого хватит. :mrgreen:
ну и вот тебе еще нотка в догонку 810434
СообщениеДобавлено: Чт, сен 25 2008, 15:37
шрам написал:
На первый взгляд все хорошо
Если <я не знать русский языка> зайти браузером
http://saperp1.zpi.int:50500/index.html
Получаю
503 Service Unavailable 7.00
SAP WebAS Engine is starting...
If this state does not change within a few minutes,
please contact your system administrator.
Check the recommendations in SAP Notes: 943498, 764417
Message: Dispatcher running but no server connected!
Details: No details available
Чтение нот не дало результата :(
СообщениеДобавлено: Чт, сен 25 2008, 15:56
а что говорят логи?
брось логи мне в личку, все последние по server
СообщениеДобавлено: Пт, сен 26 2008, 06:54
Вт, авг 12 2008, 07:40
Проверьте лицензию, джава без нее не поднимается.
Для быстрой проверки можно время сервера откатить в тот момент, когда временная лицензия еще работала
ай, каррамба
СообщениеДобавлено: Пт, сен 26 2008, 07:00
Пн, сен 27 2004, 08:14
ivanovio написал:
Это неправда. Джава поднимается без лицензии на 30 минут, потом падает. Иначе как вы лицензию-то новую заведете ?
Усталость профессионалов обычно кончается смертью (с) П.Мамонов
СообщениеДобавлено: Пн, сен 29 2008, 10:58
ivanovio написал:
О какой лицензии идет речь?
Транзакция SLICENSE?
СообщениеДобавлено: Пн, сен 29 2008, 16:16
Gans91 написал:
ivanovio написал:
Да, так и есть - на 30 минут поднимается, только приложения зачастую стартуют дольше
ай, каррамба
Последний раз редактировалось ivanovio Пн, сен 29 2008, 16:25, всего редактировалось 1 раз.
СообщениеДобавлено: Пн, сен 29 2008, 16:24
2 Golosov
да, о ней
ай, каррамба
СообщениеДобавлено: Пн, сен 29 2008, 16:28
ivanovio написал:
2 Golosov
да, о ней
Лицензия до конца ноября
СообщениеДобавлено: Пн, сен 29 2008, 17:33
Пн, ноя 07 2005, 15:59
где у вас пользователи хранятся?
СообщениеДобавлено: Вт, сен 30 2008, 07:36
korchagin написал:
В продуктиве
СообщениеДобавлено: Вт, сен 30 2008, 10:12
Golosov написал(а):
korchagin написал:
В продуктиве
Да нет, я имею в виду, какой тип хранилища учетных записей использует JAS - DB, R/3, LDAP? Подозреваю, что R/3. В таком случае попробуйте заменить профиль UME на DB Only.
СообщениеДобавлено: Вт, сен 30 2008, 10:23
кстати, сперва посмотрите в defaultTraceNN.trc, что за исключение выдается. наверняка станет понятнее, что за проблема с UME.
СообщениеДобавлено: Вт, сен 30 2008, 10:27
korchagin написал:
Вот нашел в логах.
JCO_ERROR_LOGON_FAILURE User SAPJSF has no RFC authorization
