Текущее время: Чт, сен 24 2026, 10:52
 Заголовок сообщения: изменение имени компютера по требованию в процессе установки SAP ERP 2005 SR2
СообщениеДобавлено: Пн, окт 27 2008, 15:19
Пн, окт 27 2008, 15:02
During SAP ERP 2005 SR2 Installation I needed change computer name from GLISRSAP_TEST to GLISRSAPTEST, because underline ("_") is not allowed into SAP server.
After renaming I tried to resume installation, but installation was broken into “Create users for SAP system” phase. How can I continue my installation with out completely reinstall SAP system?
Here is SAPINST.LOG listing:
INFO 2008-10-22 12:10:34
Copied file 'C:/Program Files/sapinst_instdir/ERP/SYSTEM/MSS/CENTRAL/AS/inifile.xml' to 'C:/Program Files/sapinst_instdir/ERP/SYSTEM/MSS/CENTRAL/AS/inifile.12.xml'.
Copied file 'C:/Program Files/sapinst_instdir/ERP/SYSTEM/MSS/CENTRAL/AS/inifile.xml' to 'C:/Program Files/sapinst_instdir/ERP/SYSTEM/MSS/CENTRAL/AS/inifile.13.xml'.
INFO 2008-10-22 12:10:35
Execute step
Component W2K_ServicePack_Check|ind|ind|ind|ind
Preprocess of component |NW_Onehost|ind|ind|ind|ind|0|0|NW_First_Steps|ind|ind|ind|ind|0|0|W2K_ServicePack_Check|ind|ind|ind|ind|2|0.
INFO 2008-10-22 12:10:50
Copied file 'C:/Program Files/sapinst_instdir/ERP/SYSTEM/MSS/CENTRAL/AS/keydb.xml' to 'C:/Program Files/sapinst_instdir/ERP/SYSTEM/MSS/CENTRAL/AS/keydb.7.xml'.
Execute step createAccounts of component |NW_Onehost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_Users_Create_Do|ind|ind|ind|ind|5|0.
INFO[E] 2008-10-22 12:10:50
FSL-02077 File system export (share) saploc does not exist.
WARNING 2008-10-22 12:10:51
Unable to get information about file \\glisrsap_test\sapmnt\TST\SYS\profile using FindFirstFile. Operating system error message: Logon failure: unknown user name or bad password.
INFO 2008-10-22 12:10:56
Nothing to do. User privileges are an empty string.
INFO 2008-10-22 12:10:58
INFO 2008-10-22 12:11:05
ERROR 2008-10-22 12:11:06
CJS-20004 Invalid password.<br>DIAGNOSIS: The password you specified for user 'XXXXX_DOMAIN\SAPServiceTST' is wrong.<br>SOLUTION: Enter the correct password.
FCO-00011 The step createAccounts with step key |NW_Onehost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_Users_Create_Do|ind|ind|ind|ind|5|0|createAccounts was executed with status ERROR .
INFO 2008-10-22 12:16:24
An error occured and the user decide to stop.\n Current step "|NW_Onehost|ind|ind|ind|ind|0|0|NW_Onehost_System|ind|ind|ind|ind|1|0|NW_Users_Create_Do|ind|ind|ind|ind|5|0|createAccounts".
 Заголовок сообщения: Re: изменение имени компютера по требованию в процессе установки SAP ERP 2005 SR2
СообщениеДобавлено: Пн, окт 27 2008, 15:57
Пт, окт 06 2006, 15:20
IMHO, that resume installation can't help to you....
[/b]
СообщениеДобавлено: Пн, окт 27 2008, 17:54
bdmalex написал:
[/b]
спасибо за ответ,можно писать на русском
I performed next steps :
1. Make all server configuration adjustments as specified in the SAP installation guide.
2. Download and install JDK 1.4x – you can use JRE 1.4.x if you aren’t going to use the ABAP add-on.
3. Install the database software.
4. Patch the database software.
5. Run SAPinst to install the CI and default DI instances.
I tried to start from beginning the last step (5), but it is not help the same error
Could you advise is full reinstallation is required ?
Thanks
СообщениеДобавлено: Вт, окт 28 2008, 07:31
Ср, окт 24 2007, 14:24
можно прошерстить в sapinstdir xml-файлы в поисках имени хоста, но, по-моему проще начать установку сначала. без удаления БД
СообщениеДобавлено: Вт, окт 28 2008, 08:42
Не вижу никакого смысла в продолжении инсталляции. Реальных шагов сделано не было вообще. Просто в инсталляционном каталоге лежат файлы с ответами на начальные диалоги установки.
Проще всего почистить его и начать все с начала.
Кстати, рекомендуется делать отдельный каталог, где будет лежать все, создаваемое инсталлятором, и запускать sapinst находясь в этом каталоге.
СообщениеДобавлено: Вт, окт 28 2008, 10:18
Thanks a lot for you response
I will try next steps:
rename c:\program files\sapinst directory
re-run SAPINST again, it will create a new directory with new parameters.
