Текущее время: Чт, сен 24 2026, 08:18
 Заголовок сообщения: Различия бэкапов ..
СообщениеДобавлено: Пт, ноя 28 2008, 12:17
Чт, апр 24 2008, 04:08
Whole database offline backup
Full database offline backup
чтото тут малость втупил, чем они отличаются ?
если можно то просто в двух словах объясните ))))
СообщениеДобавлено: Пт, ноя 28 2008, 12:56
Пт, авг 29 2008, 12:36
As for the difference between 'Whole' and 'Full' backup here is what the manual (Database Administration (Oracle) with SAPDBA) says:
Definitions
Complete backup is a generic term. A complete backup can be one of the following:
1. A whole backup -m all:
Backs up all database objects. This backup is not cataloged which means that you cannot
use this backup as a reference backup for an incremental backup with RMAN.
Syntax: backup_mode = all
2. A full backup -m full:
Backs up all database objects. You can make a full backup with or without RMAN. If you do
not use RMAN, then RMAN is called separately to catalog the backup. This means that you
can use this backup as a reference backup for an incremental backup with RMAN.
Syntax: backup_mode = full
In the context of the Recovery Manager this backup is a level 0 backup.
СообщениеДобавлено: Пт, ноя 28 2008, 13:24
спасибо.. понял ..
