Текущее время: Чт, сен 24 2026, 11:45
 Заголовок сообщения: The SAP agent daemon was not started.
СообщениеДобавлено: Ср, янв 14 2009, 11:31
Чт, фев 21 2008, 09:42
Добрый день
После останова сервера Backup и ленточной библиотеки возник ли проблемы с бекапом на серверах.
ОС - Unix
Buckup - Arcserve
Задание формируется но самостоятельно не запускается , в арксёре я его вижу в статусе Read
Если его запустить в арксёре ручками то оно отрабатывает, а самостоятельно нет.
Program: BACKINT
Parameters:
Nodename: dev
Function: BACKUP
BackupType: file
Input File: /oracle/DEV/saparch/.adzruzge.lst
Output File:
Parameter File: /oracle/DEV/920_64/dbs/initDEV.utl
Parallel sessions: 1
BKI0008I:Number of bytes to save: 713.462 MB, 15 files
Backup started....
Waiting for the SAP agent daemon to start... ..........................................................................................................................
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17408.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17409.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17410.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17411.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17412.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17413.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17414.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17415.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17416.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17417.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17418.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17419.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17420.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17421.dbf
BR0233E Backup utility has reported an error while saving file /oracle/DEV/oraarch/DEVarch/1_17422.dbf
BKI0022I: Bytes saved so far: 0.000 MB, 0 files
Exit BACKINT : ERROR
BR0280I BRARCHIVE time stamp: 2009-01-14 13.09.43
BR0279E Return code from '/usr/sap/DEV/SYS/exe/run/backint -u DEV -f backup -i /oracle/DEV/saparch/.adzruzge.lst -t file -p /oracle/DEV/920_64/dbs/initDEV.utl -c': 2
BR0232E 0 of 15 files saved by backup utility
BR0231E Backup utility call failed
BR0016I 4 offline redo log files processed, total size 118.326 MB
BR0007I End of offline redo log processing: adzruzge.cds 2009-01-14 13.09.43
в логах пишет
Backup started....
............................................BKIERR: The SAP agent daemon was not started.
Неможет стартовать SAP agent daemon , что это за демон такой . :evil:
Может кто сталкивался.
 Заголовок сообщения: Re: The SAP agent daemon was not started.
СообщениеДобавлено: Чт, янв 15 2009, 08:23
Проблема решена
После останова сервера бекапа остановилось время , когда сервер запустили время отставало на 30 минут
выставил время правильно и всё пошло.
