Текущее время: Вт, сен 22 2026, 07:05
Начать новую тему Ответить на тему  [ Сообщений: 43 ]  На страницу 1, 2, 3  След.
 Заголовок сообщения: траблы с Oracle. Нужна F1Я ИДИЁТ, УБЕЙТЕ МИНЯ КТО-НИБУДЬ!
СообщениеДобавлено: Ср, апр 20 2005, 09:47
Ср, апр 20 2005, 09:29
ситуация такова:
слетел Oracle в <sid>ALERT.log выдает:
ORACLE V8.1.7.4.1 - Production vsnsta=0
vsnsql=f vsnxtr=3
Windows 2000 Version 5.0 Service Pack 4, CPU type 586
Starting up ORACLE RDBMS Version: 8.1.7.4.1.
System parameters with non-default values:
processes = 100
sessions = 115
timed_statistics = FALSE
shared_pool_size = 331517788
shared_pool_reserved_size= 33151778
control_files = F:\oracle\LPS\sapdata1\cntrl\cntrlLPS.dbf, F:\oracle\LPS\sapdata2\cntrl\cntrlLPS.dbf, F:\oracle\LPS\sapdata3\cntrl\cntrlLPS.dbf
db_block_buffers = 60702
db_block_size = 8192
db_block_lru_latches = 2
compatible = 8.1.7.4
log_archive_start = TRUE
log_archive_dest = E:\oracle\LPS\saparch\LPSarch
log_buffer = 1048576
log_checkpoint_interval = 300000
log_checkpoint_timeout = 0
db_files = 254
db_file_multiblock_read_count= 8
control_file_record_keep_time= 30
dml_locks = 1024
row_locking = always
max_rollback_segments = 400
rollback_segments = PRS_0, PRS_1, PRS_2, PRS_3, PRS_4, PRS_5, PRS_6, PRS_7, PRS_8, PRS_9, PRS_10, PRS_11, PRS_12, PRS_13, PRS_14, PRS_15, PRS_16, PRS_17, PRS_18, PRS_19
transaction_auditing = FALSE
sort_area_size = 2097152
sort_area_retained_size = 0
db_name = LPS
open_cursors = 800
optimizer_mode = choose
always_anti_join = hash
star_transformation_enabled= true
parallel_broadcast_enabled= TRUE
optimizer_index_cost_adj = 10
cursor_space_for_time = TRUE
utl_file_dir = D:\oracle\LogMiner
create_bitmap_area_size = 33554432
bitmap_merge_area_size = 33554432
parallel_max_servers = 4
parallel_execution_message_size= 8192
hash_join_enabled = FALSE
hash_area_size = 4194304
hash_multiblock_io_count = 8
background_dump_dest = E:\oracle\LPS\saptrace\background
user_dump_dest = E:\oracle\LPS\saptrace\usertrace
max_dump_file_size = 20000
PMON started with pid=2
DBW0 started with pid=3
LGWR started with pid=4
CKPT started with pid=5
SMON started with pid=6
RECO started with pid=7
Wed Apr 20 09:46:07 2005
ARCH: STARTING ARCH PROCESSES
ARC0 started with pid=8
ARCH: STARTING ARCH PROCESSES COMPLETE
ARC0: Archival started
alter database mount
Wed Apr 20 09:46:11 2005
Successful mount of redo thread 1, with mount id 3153002403.
Database mounted in Exclusive Mode.
Completed: alter database mount
alter database open
Wed Apr 20 09:46:13 2005
Thread 1 opened at log sequence 9563
Current log# 11 seq# 9563 mem# 0: E:\ORACLE\LPS\ORIGLOGA\LOG_G11M1.DBF
Current log# 11 seq# 9563 mem# 1: D:\ORACLE\LPS\MIRRLOGA\LOG_G11M2.DBF
Successful open of redo thread 1.
SMON: enabling cache recovery
SMON: enabling tx recovery
Errors in file E:\oracle\LPS\saptrace\background\lpsSMON.TRC:
ORA-00600: internal error code, arguments: [kcbgcur_2], [], [], [], [], [], [], []
Wed Apr 20 09:46:15 2005
Completed: alter database open
Wed Apr 20 09:46:16 2005
ORACLE Instance lps (pid = 6) - Error 600 encountered while recovering transaction (14, 91) on object 21851.
может кто сталкивался?
СообщениеДобавлено: Ср, апр 20 2005, 09:55
Вт, мар 29 2005, 19:54
ээ, что в трайс файле написано? какие-то траблы с процессом smon. попробовать накатить патчи до 8.1.7.4.18 или какая там последняя версия, не помню. посмотреть на металинке.
Не откладывай работу на субботу, а секс на старость
система без базисника должна лежать! (с) Skif
СообщениеДобавлено: Ср, апр 20 2005, 10:00
вчера накатил - не помогло
система работает до тех пор, пока юзвери не запускают тр-ций, дальше дамп, что и не странно при ораклийных траблах
СообщениеДобавлено: Ср, апр 20 2005, 10:09
система отдельно стоит или как? давно началось? что написано в трейс файле который выдет оракл? можно ли поставить туда 9 оракл к примеру? какие патчи стоят на винду?
СообщениеДобавлено: Ср, апр 20 2005, 10:20
система и база на одном серваке
началось вчера
винды - 2000/ SP 4 + kb835732
9-ку поставить нет возможности - лицензия + SAP и все такое
трейс на 2,9 м со старта Оракла
СообщениеДобавлено: Ср, апр 20 2005, 10:22
что было сделано вчера-позавчера? р3 в продуктиве? бакапы на увровне файловой системы есть?
СообщениеДобавлено: Ср, апр 20 2005, 14:34
Объясните плиз, что там с лицензиями не так? Что мешает поставить Oracle 9?
СообщениеДобавлено: Ср, апр 20 2005, 14:50
система 4.0 официально вроде как не поддерживается под 9 ораклом :) да она вообще вроде как уже не поддерживается, только за отдельные деньги. хотя какая у него не знаю.
СообщениеДобавлено: Ср, апр 20 2005, 14:59
Ну, если не поддерживается, тогда в чем проблема?
Какая разница с 8-кой она у него не будет поддерживаться или с 9-кой? :))
СообщениеДобавлено: Ср, апр 20 2005, 15:02
разницы абсолютно никакой. хочет человек - пусть делает что хочет :)
СообщениеДобавлено: Ср, апр 20 2005, 15:12
Сб, авг 21 2004, 14:24
600 ошибка это практически всегда баги оракла.
надо искать пач. Возможно эта версия оракла несовместима с SP4 операционки.
Слишком старый Оракл и слишком свежий сервис пак.
Здравое предложение - перейти на 9 Оракл.
СообщениеДобавлено: Ср, апр 20 2005, 15:13
чтоб прояснить ситуацию:
1. по большому счету разницы есть лицензия - не лицензии для меня лично - НИКАКОЙ
2. если честно - искать инсталку 9-ки у меня сейчас НУ АБСОЛЮТНО не стоит ( извините за выражение) а 8-ка под рукой :)
3. а плюсы то в чем собстно?
СообщениеДобавлено: Ср, апр 20 2005, 15:23
всегда, а не почти.
надо искать пач.
если учесть что он уже ставил последнюю версию патчка на 8.1.7.4
до сегодняшнего дня работал, а с сегодняшнего перестала.
только переод надо делать поэтапно: тест, разработка, продуктив :)
СообщениеДобавлено: Ср, апр 20 2005, 15:24
я б согласился с Вашим выводом если б система не бегала под SP4 более года - без проблем. На САПе лежит только одна нотка по почти идентичному вопросу ( если интересно № 393162 ), но она касается переезда с 7-ки на 8-ку, там же патч для этой баги.
Нда-с.
делаю экспорт, потом поставлю поверху ОРУ, других идей - нету.
СообщениеДобавлено: Ср, апр 20 2005, 15:29
на самом деле 600 действительно почти всегда баг. иногда это например статистические траблы - и еще некоторые внутренние дела Оракла, которые решаются другими способами.
viva - но чудес на свете не бывает - больше года работало - вчера вдруг внутренние баги пошли - причем постоянные - на любой транзакции, если я вас правильно понимаю. Значит чего-то изменилось.
Кстати у меня не было выводов - только предположение - поскольку я не нахожусь внутри ситуации.
